How to replace neutral safety switch? - SaabCentral Forums
Old 4th May 2009
mstueve mstueve is offline
New Member
My Saabs: 2002 9-3 SE
Default How to replace neutral safety switch?
After reading a lot of the posts in this forum I'm about 99% sure I need to replace my neutral safety switch. I've found the part online for $289 and given that the part alone is already fairly pricey I was considering replacing it myself to try to save some $$. I'm not overly mechanical, but I can follow directions. I've done some basic stuff in the past (fixed a leaking power steering reservoir, removed the radio to install a Sirius FM direct adapter) but that's about it. How involved is it to replace the NSS, and is there any online resource that could walk me through it (preferrably with photos)?
Thanks in advance,
Matt
Old 4th May 2009
earthworm's Avatar
Saab Sage!
Replace ?
Clean and relube ?
http://www.saabcentral.com/forums/sh...d.php?t=148772
http://www.saabcentral.com/forums/sh...d.php?t=144496
The earthworm
'96 900S, Automatic
Old 4th May 2009
hkayssi hkayssi is offline
My Saabs: 1997 900S
What makes you think it's the NSS??? What sysmptoms and did you try to bypass it to confirm that???
http://bellsouthpwp.net/m/a/mattiaso...Auto/trunk.htm
if the car isn't turning over it may be something alse too so confirm this before you start replacing parts
http://www.saabcentral.com/forums/sh...d.php?t=109861
The NSS can also be repaired
http://www.saabcentral.com/forums/sh...d.php?t=105574
Old 4th May 2009
New Member
Thanks for the replies, I will check out the links. My wife took it on a short errand this morning, about a 15 minute drive. She ran into a store and came out a few minutes later, and the car wouldn't start. Good electrical, but no crank whatsoever (we've already had the crank sensor replaced about 4 months ago). Upon our Saab mechanic's advice, she put it in neutral, and it started right up. I read a lot of similar stories on these forums and the common response was that it's the NSS
Old 4th May 2009
earthworm's Avatar
Saab Sage!
Originally Posted by mstueve View Post
Thanks for the replies, I will check out the links. My wife took it on a short errand this morning, about a 15 minute drive. She ran into a store and came out a few minutes later, and the car wouldn't start. Good electrical, but no crank whatsoever (we've already had the crank sensor replaced about 4 months ago...(This has nothing to do with cranking, as its a position sensor). Upon our Saab mechanic's advice, she put it in neutral, and it started right up.Everyone in the trade knows this one, and if the current to the solenoid still flows when the shifter is in, shall we say, P + 0.2 or N -0.2, then we know that the cable adjustment is off.. I read a lot of similar stories on these forums and the common response was that it's the NSS
This is an easy one, as we have a no-crank due to, apparently, a bad NSS..
I don't think Saab set out to design the NSS to be "serviceable", but it had to be "able to be assembled"...which, in a way, is much the same thing....
But, is the cable adjustment correct ?
There is little room for error here...
The earthworm
'96 900S, Automatic
Old 4th May 2009
New Member
Thanks again for the help. As I mentioned, I'm not at all a mechanic, so a lot of what you've said and pointed me to is over my head. And now that you mention it, I realize the crank sensor wasn't responsible for the cranking (why would anyone think that, given its name), but we had it replaced due to the car stalling while idling and not starting up again.
I may just ask my mechanic to check the cable adjustment. I would attempt to bypass the NSS via Frank's suggestion but don't know where the relay is located (the manual says under the instrument panel next to the steering wheel, but I don't see anything, even after removing the panel), and once there I wouldn't have a clue how to find the proper pin and I don't want to make things worse.
Old 4th May 2009
My Saabs: 1997 900S
http://www.geocities.com/ng900set/El...l/relays1.html
Old 4th May 2009
john bernard john bernard is offline
My Saabs: 1995 900SE convert. V6
To get to the relay holder you have to remove that panel that is above your legs when you're in driving pos. The relay holder is a little white tray not far from the fuse holder.Saab's instructions for the location of that relay holder are quite dismally poor. Pin numbers are on the relays themselves, but you have to look closely to find them
EZRYDR
Old 1st May 2013
jwear21 jwear21 is offline
New Member
My Saabs: Saab 93 SE Turbo Convertible
I am having this EXACT same issue... I realize this was posted nearly 4 years ago, but did you find any solution that might help us out?
-jw
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
