Hello all!
1991 900 5-speed 16V NA.......saturday went to check coolant level, found it low and a nice thick froth of oil on top of the coolant. No coolant in the oil, no loss of power, no smoke, etc. and no overheating yet....doesn't have an oil cooler either. Anything else to check or is it as I fear, head gasket time? Also how come it's not the other way around, coolant in the oil? Is the head more likely to be cracked? Thanks and cheers to all - |
| Sponsored Links | ||
Advertisement | ||
I'm really sorry to hear that Hu. It sounds like a HG to me.
Both oil pressure and coolant pressure are relatively low compared to the compression in the cylinders. I've only done two head gasket jobs on 900s and on disassembly it was obvious that the failures occurred next to a cylinder / water jacket in both cases. The high pressure from compression broke through the gasket, forcing oil, fuel, and combustion gases in the water jacket. Give it time and water will find it's way into the oil too. Another thing to look for is air bubbles in the coolant reservoir tank. The engine should be hot and running when you check. Try varying the rpms. The bubbles of course are caused by the cylinder pressure leak. Also, when you start the car up look for white smoke out the tail pipe. When you shut a hot engine off, of course there's no compression pressure, but the coolant pressure rises and forces coolant back into the cylinder. Hence the white smoke tainted with anti-freeze smell. It will take a while to deal with it, but don't *** out too much. (I just found out that *** is a bad word. Over here it just means depressed. What does it mean across the pond?) My first HG was on the 87 900S. My wife noticed it was running hot and so decided to head straight home. The head was so distorted it couldn't be straightened or machined, so I found one at Pick 'N Pull for $60, had it tested (perfect), and put it on. (Your head is likely in excellent condition and Saab valves last forever.) Throughout the process I kept doubting myself. We've put over 100k miles on the car since I did the HG and it's running great with over 310k miles. That's 500k kilometers! Take heart. Your car still has lots of life left in it.
Steve Corgan, The Saabster 89 SPG Edwardian Gray, 90 SPG Talladega Red, 91 900 Turbo Beryl Green Vert Last edited by Steve Corgan; 04-05-09 at 09:52 AM. |
even when you have changed it there always seems to be an oil film in the water top up bottle so don't panic once it's been done, if you still see it there
22saabs |
drain coolant, and refill.
See if it comes back, dont panic yet. K |
I appreciate your help! Cheers-
My 93 has this issue as well. Removed and cleaned the coolant tank and the oil returned. I have no doubt the head gasket is bad. Since the coolant isn't showing in the oil and the cash for the gasket kit, head bolts, head bolt socket, and mercedes coolant isn't showing in my wallet, I still drive it on short trips. I am looking forward to changing it when the time comes.
With your '93 with a B212 engine, be prepared for pitting at the coolant passages. The longer you go with a blown gasket, the longer you'll be exposing the block to acidic coolant. If you haven't been to Townsend Imports' site already, try here for more information on pitting, head bolts durability, and headgaskets: http://townsendimports.com/Web/2poin...ock_repair.htm http://townsendimports.com/Web/engin...sket90016v.htm http://townsendimports.com/Web/cooli...der/2.1jbw.htm |
| Sponsored Links | |
Advertisement | |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
