saab 900 convertible roof - SaabCentral Forums
Old 23rd April 2009
marcb marcb is offline
New Member
My Saabs: 96 sabb 900 convertible
Default saab 900 convertible roof
hi all new to this
ive got a 96 saab 900 convertible and i have problems with the roof as follows
undo latches and press the hood down button the tonneau cover goes up and then the rear screen goes up then the roof starts to go back untill it gets half way then it says check hood and thats it it stays there and wont go up or down
i would be grateful of any help
thanks
Old 23rd April 2009
Eric in Lockport, N.Y.'s Avatar
Eric in Lockport, N.Y. Eric in Lockport, N.Y. is offline
My Saabs: '95 900SE 2.5L V6 'VERT "resurrected"
Before opening the roof latches, did you open the trunk and lower the boot well? Just a guess........
Old 23rd April 2009
saab_chemE saab_chemE is offline
My Saabs: 99 9-3 conv, 01 9-3 conv
have you checked the convertible top fluid? and do you get an error message on the sid when it stops?
Old 23rd April 2009
oh.....check hood
Old 23rd April 2009
Originally Posted by saab_chemE View Post
have you checked the convertible top fluid? ?
No fluid on a '96. It's an electric motor nightmare.. ( I can say that, 'cause I have one)
If won't move either way, and it's in the air, try turning the key off and back on, and/or feel around the top bow to see if the microswitches might be sticky. Also try tapping your flat hand into the bottom of the top well (where the top folds down into).
Old 23rd April 2009
saabchilten's Avatar
saabchilten saabchilten is offline
My Saabs: '96 900SE 2.0t Convertible a.k.a. Aeron
what does tapping the boot for the top do. you're suspecting the microswitches in that area? if i recall, it's either microswitches or programming. go for the simpler of the two.
"and when the sun shines...you can peel off the rest of your inhibitions"
Old 23rd April 2009
Originally Posted by saabchilten View Post
what does tapping the boot for the top do. you're suspecting the microswitches in that area? .
Yup.........
Old 23rd April 2009
yes, i had to ask that. just checked the diagnostics pdf, and the potentiometers were mentioned, but, again, try the microswitches first since they are a lot simpler.
Old 24th April 2009
sankuspr's Avatar
sankuspr sankuspr is offline
My Saabs: 2005 9-5 Aero Sedan. Chilli/charcoal MT
hello, i've been having some 5th bow motor trouble. I'm not going to go into the problem right now because i already have a planned course of action (thanks to this site). However, could someone walk me through the steps on how to check/ top-up the hydrolic fluid. With pics if you could manage. I've heard some explanations but i'm afraid i just don't know the termonology so half the time i don't know what people are talking about. Thanks.
Old 24th April 2009
see if you can find it or start a new thread to get some pics. your question is totally different and relates to a totally different top system. i think having a thread like that with pics available would be really helpful for several people too.
Old 24th April 2009
john bernard john bernard is offline
My Saabs: 1995 900SE convert. V6
marcb
If the top is still up in the air, lower all four windows. Lower the backrest of the rear seat. Kneeling on the backrest,just a couple of inches to the left of that large opening to the luggage compartment, look for a slit in the trim panel, about 5 in. long. Behind that slit, look for a red handle. Pull that handle down til it is horizontal. That should release the top so you can pull it down to the windshield and latch it if that is what you want to do. You should also be able to move the tonneau cover and the fifth bow. I don't know if the tonneau cover will latch, but the fifth bow won't latch. Push that red handle back up to vertical.To latch the fifth bow you need to find and read a thread about two or three months ago by flyhop. This will require removing plastic push clips to release and get behind that trim in the luggage comp. It is also possible to access the tonneau mechanism including the tonneau latch lever near the tonneau motor on the right side
EZRYDR
Old 25th April 2009
New Member
thanks for all the advice guys
im taking it to get reset on monday and see what fault codes its got
Old 26th April 2009
sankuspr's Avatar
NVM i started a new thread where someone told me that they didn't have hydrolic sytems till the 9-3. And after reading all of this thread i realized this was said before i made my post. - Woops.
Old 6th June 2010
naringal naringal is offline
New Member
My Saabs: 2001 saab 95
Default roof problems
I had similiar problems with mine and a chance hint from a Saab techo was all I needed to rectify the problem simply. the hint is: if you remove the battery terminals for 24 hours then the ecu for the roof will reset to factory defaults. Works a treat if all other components are in working order.
ps I had just sraightened the tonneau cover motor mounting plate and restored clearance to <32 mm and renewd pin in universal joint( with a roll pin)
Old 8th July 2010
saab-900-turbo saab-900-turbo is offline
New Member
My Saabs: Saab 900 Turbo Convertible
Default Saab 900 Turbo Convertible
I have a saab 900 convertible just put a new roof on it its not working i put all my motors on the roof and micro switches the old roof was working before i changed it it just leaks any ideas as i dont know any help is welcome cheers
Old 8th July 2010
'97 Saab SE Turbo's Avatar
'97 Saab SE Turbo '97 Saab SE Turbo is online now
Saabista
My Saabs: Black on black '97 Saab 3-door SE Turbo
Is it leaking through the roof material or at the window seals?... Ron
Old 9th July 2010
New Member
IT was leaking changed the whole roof as it had been cut the new roof i put on wasd working on the car it come off it is as if there is no power getting to the motors
Old 3rd May 2011
mikey babe mikey babe is offline
New Member
My Saabs: saab 900 convertible
Default roof prob
hi i have a saab 900 convertible n reg,and the roof,windows and stereo have stoped working.ive checked the fuses which are all ok i have spoken to some pepole who have suggested the ecu?If any one can give me some advice id really appreciate it thanks mike.
Old 3rd May 2011
What year is the car?
Old 3rd May 2011
jakejm79's Avatar
jakejm79 jakejm79 is offline
Saabista
My Saabs: 1999 9-3 Convertible
Probably a MY 1996.
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
