SAAB Owners Club (UK)
Home Saab Pictures Saab Classifieds Saab Dealer Listings Saab Forum
Go Back   SaabCentral Forums > Saab 9-3 Sports Saloon/Sedan/Convertible/Combi > Saab 9-3 Sports Saloon/Sedan, Combi & Convertible Workshop
Old 13-04-09, 01:30 PM
extremezx9 extremezx9 is offline
New Member
My Saabs: 2003 9-3 Arc, 2007 9-7 5.3
Default 2003 9-3 wont start
I have a 2003 9-3 Arc. Went for a drive when I attempted to come home the car does not start now. I have fuel pressure, it does not turn over. I get a slight click when I turn the key. I was able to push jump start the car and get home. Any help would be greatly appreciated.
Thanks,
Old 13-04-09, 01:51 PM
stevedol's Avatar
stevedol stevedol is offline
Moderator
My Saabs: MY08 9-3 Aero 2.0T Convertible
Sounds very much like your battery has died, this is a common issue with the original batteries on these cars, there are multiple threads on this highlighting the variuos syptoms, many of which don't obviously point to a dead battery, but 9 times out of 10 it is the cause.
My 9-3 won't start, but battery voltage is fine
Click Click..Help Please
2000 93 SE convertible - bought 2003 - traded in 2004 for
2003 93SS Aero - bought 2004 - traded in 2007 for
2006 93Sportcombi diesel MY07 - bought 2007 - Hirsched, stage1 175BHP, pedals & dual exhaust, Kenwood DNX5220 multimedia satnav - traded in 2010 for,
2007 93convertible MY08 - bought 2010 2.5yrs old
Old 13-04-09, 03:28 PM
meisme33's Avatar
meisme33 meisme33 is offline
My Saabs: 2003 9-3 Arc, BSR Stage 1, K&N Drop-in
I JUST had my battery die on my 2003 9-3 Arc last Thursday. Same symptoms: click click, won't turn over... had the battery changed (dealer charged me $208 installed) and all is well. In hindsight I could have gotten the battery changed cheaper elsewhere, but I was getting my suspension looked at 8 days short of my warranty ending and it was convenient.
Old 13-04-09, 03:30 PM
MooF's Avatar
MooF MooF is offline
My Saabs: 03 SS, BSR PPC, Magnaflow exhaust
Often time is money ... but yes you can get a better price on the battery elsewhere, and installation is usually DIY. Some people don't like playing around with batteries though and then of course there are disposal concerns.
Old 13-04-09, 07:42 PM
New Member
Thanks to the replies. I spent some time going over the issues and troubleshooting it.
1.) Battery ( as defined by most might need to be replaced ) not so the battery brand new this past winter but pulled it and had it test be on the safe side. Came back positive.
2.) Under the clutch pedal there is a clutch sensor. I pulled the switch and jumperd the connection to see if the sensor was bad. No luck still nothing.
3.) To the starter. Once I crawled under the car it was plain to see the cable from the wiring harness to the starter was corroded off. Causing no connection to the starter.
The cable is a multi powered cable that feeds more than the starter and intermeshed with-in a series of other cables to complete the harness. I am going to attempt to splice back the wires and create a new connection. The full harness cost is 145.00 then the full day of pulling the old one out and installing the new one.
I will post a picture of the issue and my attempt to fix the problem.
Old 14-04-09, 01:16 AM
PECo412 PECo412 is offline
I changed the original battery on my 2003 9-3 Arc automatic for the first time, today. I got the group 48 battery from the dealer for about $140 and have to return my old battery tomorrow. You need a socket wrench with an extension long enought to unbolt the battery from the case. There's a bolt and clip at the bottom of the battery case at the front. I can't remember the size of the bolt, but the bolts holding the contacts to the posts are 10 mm.
Old 14-04-09, 06:34 PM
brianl703 brianl703 is offline
My Saabs: 2006 93 2.0T
The retailer who sold you the new battery doesn't take the old one back? They do here.
Old 15-04-09, 01:23 AM
Yes, they do. I'll drop my old battery off at the dealership tomorrow. Incidentally, the dealer charged me $124.95 for the new one.
Tags
battery, dead
copyright © 2003 saabcentral.com, All rights reserved - website by WDD serviceshttp://www.whiter.co.uk - valid xhtml - valid css
SaabCentral is an independently run website and is not affiliated in any way to Saab Automobile AB
