Pinch Protection problem..window won't stay up! - SaabCentral Forums
Old 11-04-09
93vector's Avatar
93vector 93vector is offline
My Saabs: 2003 Saab 9-3 Vector
Angry Pinch Protection problem..window won't stay up!
2003 9-3 Vector
Anyone know how to solve this pinch protection problem....both driver's and passenger front have been giving me problems...close window and it will go back down. It is intermittent, but is a real pain.
I know how to override this by holding the pinch protection button while putting the window up....but would like to fix the problem!!
Thoughts??
Old 11-04-09
Ridenbaugh Ridenbaugh is offline
My Saabs: Was 2004 9-3.
Did you already try to recalibrate the windows? If not do a search and you will find directions on how to. If you can't get that to work, some people say to unplug the door electronics in the door jams then try to calibrate. From what I hear this usually is the fix for the problem. Good luck!
Originally Posted by 93vector View Post
2003 9-3 Vector
Thoughts??
Old 12-04-09
JonV JonV is offline
Saabista
My Saabs: 03 Vector
Is it raining?
Old 12-04-09
ArmySaabman's Avatar
ArmySaabman ArmySaabman is offline
My Saabs: 2006 9-3 Aero
Pull the fuse to the front windows. Keep out for like 10 min. Put the fuse back in. To reset all you need to do is roll the windows up and down three times in a row and then you should hear a confirmation beep.
If you have not gotten your answer already.
2003 9-3 Vector
Thoughts??
Owning a Saab is like having a European Vacation everyday! Just sit back and enjoy the ride.
Old 12-04-09
Saabista
My Saabs: 03 Vector
I'm gonna lay odds it's just a binding problem, check the rails/guides/tracks or whatever you want to call them for crud and a simple reset will correct it. It's not necessary to disconnect anything, but if it will make you feel better just unplug the harness from the door.
To reset Pinch Protection, as explained in the Manual. Raise and lower the affected window(s) twice holding the switch in the appropriate direction, on the second closing hold the switch up until you hear the ding/chime. See p.100-104 or 130 in your manual depending on the version.
Rain, Snow or Ice can create enough resistance to trigger pinch protection, as can debri in the guides..
Old 12-04-09
VectorSport150 VectorSport150 is offline
New Member
My Saabs: Vector Sport 150 TiD
Default Pinch Control Reset
easiest fix is turn ignition off, disconnect the door electrics(slide top up to unplug) & leave for ten seconds, plug it back in and close door, turn ignition on then reset pinch control as in the manual by putting windows up and down 2 or 3 times until you hear the beep - all will be good again
Old 15-04-09
93vector's Avatar
Worked like a charm!!! Thanks alot
Old 05-06-10
Cdim7 Cdim7 is offline
New Member
My Saabs: 9-3 Aero Combi
Default Thanks!!!
I was having the same problem and this forum helped me correct it. Disconnecting the door electronics for 30 seconds and then reconnecting did the trick!
Old 05-06-10
Saabista
My Saabs: 03 Vector
Try it without disconnecting the door, fuse or battery, it will work 99.9% of the time. You only have to disconnect Power if you need to reset the complete Door Module.
And you only have to raise and lower twice.
Over the years the simple trick has been made more complex and wordy my well meaning posters. If you disconnect the battery to reset one window, you've got to reset all the Windows.
This is how simply the Manual puts it :
Fully open and close the windows
at least twice. You will hear a chime after
successful calibration.
Old 05-06-10
adolan20 adolan20 is offline
My Saabs: 2003 Saab 9-3 Arc
JonV, isn't this your favorite question?
2003 Saab 9-3 Arc
Old 05-06-10
Saabista
My Saabs: 03 Vector
Old 06-06-10
Last_saab_standing's Avatar
Last_saab_standing Last_saab_standing is offline
My Saabs: 2005 9-3 ss aero
Talking
this is the worst picture i ever seen on the web!!!
bruins suck!!!!
go habs go!!
olé olé olé olé!!!!!!!
Old 07-06-10
orion7144 orion7144 is offline
You can not do it this way if your window trips the anti pinch. It just goes up then auto down a few inches so it will never calibrate. The only way to fix this problem is to reset the module.
Old 07-06-10
Saabista
My Saabs: 03 Vector
Wrong, Just hold down that rear button with the X while you reset, the one that deactivates the rear windows, it disables the anti-pinch while you re-calibrate.
P. 101 of the Manual (03-05)
1 Make sure the ignition is ON.
2 Press and hold the "X" button on the
driver’s door while operating the window
in question.
3 Close the window in question.
The pinch protection will be active the next
time a window is operated.
Old 07-06-10
That has never worked for me.
in question.
Old 07-06-10
Saabista
My Saabs: 03 Vector
I would say to that, you are having actual Module or switch problems, not just re-setting issues. The "X" button disables Pinch Protection so the window will close completly.
Old 08-06-10
mdTurboX's Avatar
mdTurboX mdTurboX is offline
My Saabs: 2004 9-3 Aero 6sp Man
I had the same issue last week and I pulled the fuse. This seemed to reset everything and now the windows are back to normal.
2005 Saab 9-3 Linear - Sold
2008 Saab 9-3 Turbo X - Sold
2004 Saab 9-3 Aero 6sp Man
Old 01-01-11
beren's Avatar
beren beren is offline
My Saabs: 2008 Turbo-X; Manual
Having the same issue, but recalibration does not seem to work. I never get a "ding". I tried the fuse as well. That didn't work either. I kept it out for about 20 minutes.
I guess I will try yanking the door connection and see if that works. I couldn't get the plug out today when I was trying.
Old 02-01-11
mr.shadow mr.shadow is offline
My Saabs: 9-3 ss 2.0t 16T-jzw,bsr,ets intercooler
you need reprogram units :ddm, pdm, rrdm, rldm - new sofware fix problem witch anti pinch
bye
Old 02-01-11
beren's Avatar
What do those letters mean? I'll try the door plug first.
I also notice that my car's fuses do not match the diagram in the owner's manual. I have fuses in sockets that the manual says should be empty. Strange...
