Neutral safety Switch? - SaabCentral Forums
Old 9th April 2009
Marc996's Avatar
Marc996 Marc996 is offline
My Saabs: '00 9-5 Aero Wagon
Default Neutral safety Switch?
I did the search read what I could but...
Before I order the somewhat pricey part here is what happens..
Car wont start sometimes
Happens usually when the car is warm
No sound at all from the starter.
If I move the Automatic shifter back and forth and let the car sit for a few minutes it will eventually start.
Seem like the culprit?
Thanks!
Marc G
00 9-5 Aero Wagon*02 Porsche 911 Carrera (996)*86 Porsche 911 Carrera *04 Audi Allroad 2.7T 6 Speed
Old 9th April 2009
Skunkape Skunkape is offline
My Saabs: 2000 9-5 G.F., 04 9-5 Aero..both wagons
It sounds like the culprit. Have you tried the bypass trick?
I replaced the switch on our 2000 lpt wagon at about 98,000 miles. Rowing the gear lever a few times would fix it for a month or 2, but I finally bit the bullet and repalced it.
BTW the one for the 5 speed transmission is $550...could be worse
Old 9th April 2009
Marc996's Avatar
Thanks, I think I missed the bypass info?
Marc G
Old 9th April 2009
walmark's Avatar
walmark walmark is offline
My Saabs: 9-5 SE Wagon '00 155K
Search the forums, it's there somewhere. Basically, the way it works when you turn the key is the computer will verify if everything is ok (if key is accepted, transmission in neutral or park, etc, etc) before activating the starter relay. Bypass trick is based on direct jumping the starter relay. You wire the relay into a button-push type of switch which you use to start the car. This bypasses the computer decision program and directly applies current to the starter (like in a race car).
The downside is that you have to be careful not to accidentally push the button while the car is in motion. Your key starter has a protection that will not allow for starter to be activated when engine is running. Bypass button has no such thing and you can grind the starter/crank gears.
Old 10th April 2009
toxicavenger's Avatar
toxicavenger toxicavenger is offline
My Saabs: 2006 9-5 Sedan, 2006 Sportcombi
you can pour water on the NSS when the problem occurs to see if it will start. also the temporary bypass is to use a really thin paper clip and bend it into a U shape. then insert one end of it into the thick white wire (on the NSS plug) slot and the other end into the thickest black wire slot. then see if it turns over. if your car starts then you do need a NSS.
Old 10th April 2009
stalknace's Avatar
stalknace stalknace is offline
My Saabs: 2000 9-5 Aero Estate
I have one that I will sell you. Send me an email of PM if interested. I replaced mine but didnt need to so now i have an extra.
Old 10th April 2009
saabcog's Avatar
saabcog saabcog is offline
My Saabs: 2000 SAAB 9-5 2.3t BSR Stage 1
I put off replacing mine for a year, I would move the gear selector up and down until things were working again. It always seemed to act up when I had guests in the car, which was embarrassing. I decided to replace it the day the car went into limp mode on the highway. Best money I've spent on this car yet.
Old 13th April 2009
Marc996's Avatar
Best price for the part?
eEuroparts.com?? $280
Marc G
Old 13th April 2009
unless if you buy it used eeuroparts has the best new part price out there.
Old 13th April 2009
oh one thing you might beable to drill the rivets out of the housing and rebuild it like on the 900's. which is sanding all the contacts and putting new grease in the switch.
Old 13th April 2009
chk chk is offline
My Saabs: 2001 95 wagon
I just replaced mine. I would pull the battery and clean and spray marine water proof lubricant around it, run the shifter back and forwards and it would work until I drove in the next rain storm. It seems a strange and exposed place to put something that has electrical contacts. I ended up replacing it (eEuroparts). I downloaded some instructions and it took me 2 hours total.
Old 23rd April 2009
Marc996's Avatar
Replaced mine yesterday, the write up I found was perfect! Under 1 hour and I was done.
One thing, the write up said to leave the car in Neutral because the new part ships in the Neutral position, the one i got was in the Park position.
eeuroparts is great, had the part in a day!
Marc G
Old 28th June 2009
jmac jmac is offline
Just installed mine (also from eeuroparts). easy instalation, 1 hour, works like a dream. I used the paperclip bypass until the part came and it worked just fine, just make sure you use jumbo paper clips because when i used a smaller grade clip, there wasn't enough current getting to the starter and so it took some jiggling before it would start. replaced it with the jumbo kind and never had the problem again (i've also heard of taking safety pins and poking them directly into the wire if you're having trouble jaming the paper clips in).
My neutral safety switch came in neutral but if your car happenes to be in park its no big deal, just twist the switch clockwise two clicks (basically to the far right till it doesn't turn anymore) and thats the park position. install and you're laughing!
Old 30th June 2009
Maine Maine is offline
My Saabs: '04 9-5 Arc/'99 9-5 SE/2000 9-5/'97 900S
Let's say I had a 9-5 on its last legs and this switch keeps being problematic, is there any reason why I couldnt just keep the paper clip in place and not replace the part? I realize that its a saftey item, but I also do not want to spend $270-300 on a part for a car that is on its way to retirement.
Thanks for any input.
Old 30th June 2009
Also, will this jumper turn out the transmission light (only code is for this switch).
Old 30th June 2009
I'm not sure about the transmission light but like I said, I had the paperclip in mine for quite a while and it worked great. If I was planning on retiring the car soon, I would have probably just left it in there and saved mucho $$$. Plus, its not that bad of a safety concern considering the car has to be in park anyway before you can remove the key from the ignition, so in other words the car should be in park everytime you start it.
Old 1st July 2009
Well, so much for the bypass. Before I could even do it my check transmission light came on, and the indicator lights on the dash telling me what gear I was in stopped working.
Sounds like I need to shell out some cash for the switch afterall.
Old 1st July 2009
http://www.saabusaparts.com/catalog/...roducts_id=861
$249 !
Old 1st July 2009
you can splice into the wires and run a toggle switch off of it. or try and rebuild it buy drilling out the rivets, clean everything out of it, relube and clean all contacts to see if that will work too. it might but I haven't had time to try it on my because I am overseas working right now. good luck bro!
Old 4th August 2009
Nathan 9⁵'s Avatar
Nathan 9⁵ Nathan 9⁵ is offline
My Saabs: '01&'03 9⁵ 3.0t '04 9 2.0T '06 97
Which car was this on? The '99, '00 or the '04? My '03 has a transmission light on and is missing the M mode, but everything else is working fine.
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
