Fan 2 speed resistor - SaabCentral Forums
Go Back   SaabCentral Forums > Saab 9000 > Saab 9000 Workshop
Saab 9000 Workshop Saab 9000 (1985-1998) Technical Forum
Old 04-09-03
alain-saab9000 alain-saab9000 is offline
New Member
Default Fan 2 speed resistor
Hello,
I'm looking for the spec of the radiator fan (2 speed) resistor for a 9000cse 1996 2.0 LPT with ACCII.
Mine is brocken (see image) but there is no vendor and info on it.
Thank you
Alain
Old 04-09-03
duesenberg duesenberg is offline
Bonjour Alain
May be this link could help You:
http://216.78.172.20/electrical_syst...anresispg1.htm
duesenberg
Old 04-09-03
New Member
Thank you duesenberg,
but it's pricing at near 150 €/$ and 320 €/$ for the complete fan motor in France... So I'm looking for the part itself or bulk at a better cost.
Alain
Old 04-09-03
I understood it, but if You look at this link You may found out that in this information this ballast resistor is somehow described (although only its resistance - 0,22 ohm +-5%)
I thought You may use this info to find resistor with same characteristic and much cheaper to replace SAAB OE one.
Regards
duesenberg
Old 04-09-03
New Member
Oups didn't realise that the spec was in it..
So Ballast resistor - 0.22 ohm +-5% 12v.
Thank you very much for your help !
Alain
