Vibration during idle - SaabCentral Forums
Old 31st March 2009
jwwells's Avatar
jwwells jwwells is offline
My Saabs: 2000 9⁵ 5-speed Stg1 207K Miles
Default Vibration during idle
Hey All
Just got a new Aero which has a strong vibration during idle. The vibration is only during idle and if I shift into neutral at a stop light is gets better, but the vibration doesn't go away. If while at the stop light I rev the engine to about 1100 rpm the vibration goes away.
I am thinking it is an engine mount, but anybody else have these symptoms and can suggest a solution?
Thanks
2002 Cosmic Blue Aero Sedan Auto 93K miles
2000 9⁵ Black 2.3 5-Speed TD-04, ECUproject Biopower Tuned Stage 1- 196K miles
2001 9⁵ Black Auto Aero Wagon
Old 31st March 2009
jweict jweict is offline
My Saabs: 2001 Saab 9-5 2.3 LPT Sedan
I had the same problem on my 2001 Saab 9-5 and changed the engine mounts. Now I don't have any vibrations. I did it when the car had about 101k miles.
Old 1st April 2009
hiros's Avatar
hiros hiros is offline
My Saabs: Saab 95 Aero M00
Yep that is correct, the mounts are designed to absorb the high vibration level at low rpm below 1000. It is an indication of mounts deterioration when you start having high vibration level transmitted to the body at low rpm.
Old 1st April 2009
chk chk is offline
My Saabs: 2001 95 wagon
I have that idle vibration on my 126K 01. I went to eEuroparts and find a RH (passenger side) mount, a Rear Engine mount, but no LH (driver's side) mount. So I assume there isn't one? And is this a DIY job for a beginner?
Thanks
Old 1st April 2009
jwwells's Avatar
Yes the Right Engine Mount is a DIY, the left side of the engine has the Transmission and there are two transmission mounts that you can replace.
Old 1st April 2009
hiros's Avatar
There are two other engine mounts, the left hand mount and torque rod. Both are different based on either manual or auto tranmission.
If you are based in the states, try also GS (Genuine Saab), RMeuropean, from Europe, try PFS.
All of them can be done as DIY, I have done all 4 with the rear one being most difficult. But after you do the right and left hand mounts, it should provide some clearance relieve on the rear mount to remove and replace it.
Old 1st April 2009
raquettelaker2's Avatar
raquettelaker2 raquettelaker2 is offline
My Saabs: 2008 Turbo-X, 1994 c900 CommEd
In my personal experience, engine mounts do not make a amazing difference in idle vibration. It's really just the nature of the beast of the 4-cylinder engine. Before you go spending all the money on mounts, go test drive a 9-5 with fewer miles and see how yours compares. My '04 only has 35k miles and it shakes like crazy at idle in drive. I just accept it though, it doesn't bother me much.
Old 2nd April 2009
Moekazi Moekazi is offline
My Saabs: 2003 9-5 Aero
My 2003 Aero vibrates at idle, too. I've swapped out the short belt for the long belt and new pulleys. I've swapped the left, right, and front (dogbone) transmission mount. It's gotten a little better, but it's still there.
One thing about the mounts, i was pretty surprised how much they sagged. The new mounts raised the engine at least 1/2". Everything else on the car seems pretty well done, but the mounts... they must have been assigned to the Engineering interns.
Old 2nd April 2009
TigerSilhouette TigerSilhouette is offline
My Saabs: 9-5 SE V6
You guys should also use the Tech2 to increase the idle speed. The tech 2 allows increments of 10 RPM up to a maximum of 50 RPM increase over the base idle. I have noticed that on the 4 cylinder engines, increasing the idle by 50 RPM gives a smoother idle. Try it out!
Lawrence
Old 2nd April 2009
Tailspin's Avatar
Tailspin Tailspin is offline
My Saabs: '03 9-5 Aero, 08 9-3, '89 C900LM
If you cant figure out of the mounts are worn out, take it to a mechanic, theyll tell you right away. I took out my transmount and it passed visual inspection. It turned out to be completely seperating under torque. Not the same problem, but sometimes they look ok and arent.
24hrs of LeMons SAAB 900 project:
Updated 12/7/14
The Q took a hard hit last race but managed to still finish well, a triumph to the spirit of this old bbq'ing jalopy. Will it be able to recover from the frame bending accident? Will it ever manifold BBQ again??
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
