| Saab 9-3 SS, Combi & Convertible Performance, Mods & Tuning Covers Tuning & Performance modifications for the Saab 9-3 Sports Saloon/Sedan, Combi & Convertible |
Ok sooo Just got back from Autocrossing.
Even with the Alignment my car still understeers, going in and coming out of turns. Its bad with ESP off and even worse with ESP on. What kind of solutions can I do here ? Maybe get some camber bolts for the front and adjust them extreme ? Also in terms of XWD and ESP ESP cuts the crap out of your engine power if it detects you pushing it to hard and doesnt like it, but when its off how does the XWD react ? Any info on this would be great for the autoxing season
New Whip 2011 9-4x Aero XWD My TurboX 02/08/2009 - 8/26/2012 RIP 3" Downpipe and Midpipe: http://www.youtube.com/watch?v=wZ3nPLrEeRk Last edited by kanundrum; 28-03-09 at 06:31 PM. |
| Sponsored Links | ||
Advertisement | ||
esp kills the power, I have found that many times.
understeers? under acceleration???
Never heard of it!
Transport: '08 Saab 9-3 Turbo X '03 Yamaha YZF-R6 Turbo (yes, turbocharged.) |
lmao funny. In my Scion all I had to do was remove the front sway and voila oversteer
New Whip 2011 9-4x Aero XWD My TurboX 02/08/2009 - 8/26/2012 RIP 3" Downpipe and Midpipe: http://www.youtube.com/watch?v=wZ3nPLrEeRk |
remove the sway bar?
damn did you upgrade the rear as well? to the op - possible rear sway bar upgrade? tighter end links. that will help the rear end come around more. idk what's available for your car.
2007 mazdaspeed3 13.97 @ 104.23 |
Nothing I think
The car does understeer, but it's more driver than car, likely.
Sounds like you are going into the corners too hot, in autox it's usually the case that you "slow down to go faster" If I drive "fast" and really push the car (in autox) I often do much slower than if I am composed and easier on the car/go pedal.
2003 Saab 9-3SS | silver | slow | coil-overed |
I hope you're also not riding around the track on factory rubbers as well. |
I agree with the above comments. Probably you are entering the corners to fast and accelerating to early or to heavy out of them.
But it is important to remember that most street cars will understeer at the limit because it is safer and easier to control to an average driver. Typically, front engined front wheel drive cars will understeer more because of the heavy weight in front. It's just physics. I would recomend you to play with the tire pressures a little (it's cheap). Ussually more pressure to the front than the rear will decrease understeer. And try some trailbraking when entering a corner. That also help to reduce understeer. |
Aren't those all season tires? As the other guy said, play with tire pressure. Jack up the tire pressure to artificially strengthen the sidewall, I would usually run 42-44 if I am on crappy tires (sorry, A/S are crappy tires) Running summer tires (Azeni 615s) I usually run 35-38psi. Trail braking will work. Another tactic that takes awhile to grasp is, going hard, lifting off the gas abruptly, stabbing the brakes and rotating the car. This upsets the balance of the car and allows it to rotate easier as it induces oversteer. It can take awhile to get this right.
They make PZero Nero All seasons. http://www.tirerack.com/tires/pirelli/pirelli-tires.jsp
its the PZero Nero Summer Tires not the All Seasons
Combined with Turning Traction Control off and Playing with Tire pressure, my time did improved by 3 seconds but I think no where near what my time should be
FWD with a heavy nose can definitely be a liability on the autox course. To really compete, you'll need stickier tires, unless you stay in street tire, and even then some RE-01R's or similar will be better.
To decrease understeer without fitting a larger rear sway (which will bump you into another class), I'd try running the aforementioned 36-38 psi in the front (try some chalk on the tire to see if you're rolling onto the sidewall, increase pressure until you do not) and something like 42 psi rear. Fiddle around until you get a little better rotation in the rear. Try "slow in fast out." This is how I have to drive my Subaru STI; that car is heavily front biased (in terms of weight) and charging the corner will simply result in "epic understeer" as you say. Going in slow and easing into the gas, at full by the apex or just beyond, will result in much faster corner exits. I suspect the Saab will drive better this way, too. Definitely turn off ESP. I wouldn't characterize our 9-3 Aero SC as having "epic understeer" at all, so likely some small changes in pressures and driving will help a lot. |
I have a 9-3 XWD (TurboX) but coming from my FWD scion I know what you mean in terms of everything haha.
Just come into the turn slow, get into the throttle a tad earlier than apex to spool, and then put it down. Let XWD sort out the traction. If it's anything like the STI you will be much faster this way. Tweak the tire pressures, too. |
| Sponsored Links | |
Advertisement | |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
