Mods can this be stickied Please!!!!!! In the "How To" section ofcourse!
I went ahead and took pictures while I replaced the EVAP purge Valve solenoid last night. I figured since I haven't been the only one to do this repair I might as well make a "How To."
First off, the reason I replaced the EVAP Purge valve is because my car threw a P0496 Code. There was some talk about this in this recent thread: http://www.saabcentral.com/forums/showthread.php?t=123758&highlight=evap+purge . I posted some WIS instructions and a fellow SaabCentral Member did the repair and I finally ordered my part and followed suit.
The Purge Valve is listed as Part # 12593761 and the part that arrived at my house was a Bosch unit with #12611802 printed on it. YERASIMOS also had that experience in the aforementioned thread.
Tools needed:
-Fingers
-10mm Socket
Once I finished my Check engine light immediately disapeared. Others had the same experience.
Good Luck, and Remember: (*lame disclaimer*) This is a demonstration of my experiences and I cannot be held responsible for any problems or issues that arise if you attempt the repair.
Anyway, Now on to the How To part. I will post the WIS instructions and the Pictures that I took.
Now some pictures from my experience.
Part:
Step1. Remove the Upper Engine Cover
-Take the Oil fill cap off and the pull up on the Black plastic cover.
Tools needed:
-Fingers
-10mm Socket
Part:
