Dump Valve fitting - SaabCentral Forums
Old 15-03-09
Oddball Designs Oddball Designs is offline
My Saabs: '99 93 FPT Convertible
Default Dump Valve fitting
Sorry for the delay in uploading the pics as sated previously
Hi i have a '99 93 2.0 Turbo just bought a "noisy" dump valve but it wont make any noise just wndering if anyone knows where i m going wrong.
Paul
Old 15-03-09
npower's Avatar
npower npower is offline
My Saabs: 99 9-3 2dr / 07 9-3 combi
Check your vacuum source and make sure the piston on your forge is lubed and clean if you bought it used. Is yours and auto by chance?
99 9-3 2DR W/ MODS
07 STI FP GREEN
WWW.URBAN-AUTORSPORT.COM
Old 15-03-09
Will do, apart from that does it look to be fitted correctly. No its manual the wife can only drive autos s i made sure i got a manual
Old 15-03-09
npower's Avatar
Yep looks right, I have the same unit. I found my vacuum line was cracked once that was fixed it worked well. Just make sure your in boost hard then lift, I know mine is not really loud at light throttle or low boost like some of the import cars you hear around town, if that makes sense.
G
99 9-3 2DR W/ MODS
07 STI FP GREEN
Old 16-03-09
coldskiesfullofblue's Avatar
coldskiesfullofblue coldskiesfullofblue is offline
My Saabs: 1999 Saab 9-3 SE
Is the BOV's piston adjustable? If so, it could be adjusted too tightly for your setup and not expelling your boost. Be careful! If it's not opening the pressure isn't leaving and your turbo/Motor will pay dearly. Then you will too to fix it.
Old 16-03-09
You could also remove the recirculator hose and plug off the intake hose. What you have done serves the purpose but not having that hose looks better
Old 16-03-09
Darren900's Avatar
Darren900 Darren900 is offline
My Saabs: 2000 9-3 T7 5-Speed 5-Door
Paul
Do you have a list of your mods somewhere? For example, is that your ECU next to the battery? What are those things that look like injectors near the oil filler cap? What's the black cylindrical object where the brake booster would be on a LHD car?
Old 16-03-09
Yes i will do that once it working properly
Old 16-03-09
Talking
Its an LPG conversion so the car runs on Gas
Old 17-03-09
Darren900's Avatar
Ahhh.. cool.
Old 17-03-09
JonRush01's Avatar
JonRush01 JonRush01 is offline
My Saabs: 2001 9-3 HOT 5 Sp. Midn. Blue
Very cool
Try using a different spring if the interchangeable ones were included. If you take it apart you might find the source of the problem if its related to the BOV. Everything looks right from what i can see though. Good luck
