New 9-3 Owner. - SaabCentral Forums
Go Back   SaabCentral Forums > Saab 9-3 SportSedan/Convertible ('04+)/Combi, 2003-2011 > Saab 9-3 SS, Combi & Convertible Performance, Mods & Tuning
Saab 9-3 SS, Combi & Convertible Performance, Mods & Tuning Covers Tuning & Performance modifications for the Saab 9-3 Sports Saloon/Sedan, Combi & Convertible
Old 07-03-09
rivetsaab rivetsaab is offline
My Saabs: 2006 9-3 2.0T
Default New 9-3 Owner.
Hi all, I just picked up my 2nd Saab, an 06 9-3. I had a question on performance upgrades for this generation Saab. I am looking to do exhaust, intake, ecu and a blow-off valve. Where is the place to go for that?
Cheers,
rS
Old 07-03-09
yspaik's Avatar
yspaik yspaik is offline
My Saabs: MY03 Vector - Sold| 2011 Accord Coupe V6
Welcome! Upgrades depend on the engine you have - 9-3 2.0T or 9-3 aero with the 2.8 V6 turbo
Best bet would be www.genuinesaab.com for general upgrades
Old 07-03-09
AlbertaDrew's Avatar
AlbertaDrew AlbertaDrew is offline
My Saabs: 06 2.0T STG 1 (SOLD) - 88 Vert Project
I hate to be "that guy" but use the search button, there are a million threads that can answer your questions....
Old 07-03-09
I have the 2.0T, does not look like there is much. The standard intake, ecu and exhaust. I was hoping for MBC, IC and things of that nature.
Old 07-03-09
93_vector 93_vector is offline
My Saabs: 2003 9-3 Aero SS
1. BOV you cannot do on the saab.
2. Bigger intercooler probably isn't necessary unless you have huge power. Intercooler can probably come later.
3. Intake will not do anything, except make the current dump valve (BOV-ish type sound) louder. If anything you may loose power, unless it is shielded from the rest of the engine bay.
4. BSR Stage 1, 2, 3 packages may be worth looking in to. Good gains in power and giant gains in torque. Stage 1 starts at $600-700 USD.
5. If you look around the performance forum, you will also find the 'WILDER' mod, which involved a device he makes (and you can make), to trick the ecu so you can run more boost (20ish psi). This requires a manual boost controller also to get some good gains. The 'smart performance' boost controller is discussed as well in a thread. This is by far the cheapest performance mod.
6. Dump pipe - helps the turbo spool up faster, worthy mod. Search function
Old 07-03-09
idontknow idontknow is offline
My Saabs: 2003 9³
You might have better luck searching for downpipe rather than dump pipe
Old 07-03-09
Ah good to know these things. Thanks, I will check out the staged setup.
Cheers
