Timing belt/chain: When to change? - SaabCentral Forums
Old 5th March 2009
rg627 rg627 is offline
Default Timing belt/chain: When to change?
Hi
My 9-3 Aero 2.0T Auto is approaching 93,000 miles, on what I presume is a standard timing belt/chain.
At 80,000 the mechanic informed me that it did not need changing yet.
What mileage should I change it at?
Cheers
Russ
Old 5th March 2009
AKS AKS is offline
My Saabs: 2006 93 2.0T
we have timing chains, no need to replace.
2009 BMW 323i Premium Package
2008 Mercedes-Benz CLK550 Cabriolet
2004 Saab 9-3 2.0T Arc
Old 5th March 2009
even at near 100,000 miles?
Mine is starting to sound a little rattley at idle.
Cheers
Old 5th March 2009
CallipNCSUsaab's Avatar
CallipNCSUsaab CallipNCSUsaab is offline
My Saabs: 2003 93SS Arc
the serpentine belt the manual states at 60k. Mine looked fine but I ended up changing it at 76k.
Old 5th March 2009
MooF's Avatar
MooF MooF is offline
My Saabs: 03 SS, BSR PPC, Magnaflow exhaust
+ 1 to the AKS post.
chains, in theory, aren't replaced. Belts are...
that rattling you're hearing could be a number of things. Do you have a manual tranny? Could be clutch plate thingy-majigger. Try depressing the clutch all the way and see if the rattle disappears.
If its auto, then could be something exhaust related. These cars rattle non-stop
Old 5th March 2009
JonV JonV is offline
Saabista
My Saabs: 03 SE 5 Spd
Cheers
There is a TSB on timing change noise, it has to to with sludge...how often do you change your oil?
Old 5th March 2009
JMarkert's Avatar
JMarkert JMarkert is offline
My Saabs: 2004 9-3 linear
In the ng900 (and I suspect SS's, given the similarity of the motor) you could check the chain health by taking the chain tensioner out and seeing how far it had ratcheted out. I'm sure the WIS will give a spec, can any WIS owners confirm this?
Mostly, I agree with the others who note that the chain should be OK for well over 100K, and most of us will never have a need to replace one. However the ng900 folks do have failures and it's worth ruling out. To read more, search on "rattle of death" in the ng900 forum.
Old 6th March 2009
Cosmicflash Cosmicflash is offline
My Saabs: '09 9-3 SS Aero XWD
Both engines have a timing chain--no service interval. Pretty much the life of the engine.
03' SS Linear Cosmic Blue, 109k mi., gone
06' SC Aero Auto Fusion Blue, BSR tuned, 94k gone.
09' SS Aero XWD Auto
Carbon Gray, Black Premium Leather, VTuned, 30% tint.
Old 6th March 2009
JBob's Avatar
JBob JBob is offline
My Saabs: 2003 9-3SS 2.0t Vector, Steel Grey (OOW)
"Both" engines? There are more than 2 over here
To clarify, the petrol (gasoline) engines use a timing chain. As suggested above, I'd get them to check the top tensioner as it may require adjustment. Chains normally give plenty of warning that they are failing, unlike timing belts (though this is not always the case - VW VR6 engine for example). As Cosmic says, there is no fixed change intervals for timing chains, and in fact they can last the lifetime of the car without trouble.
Although the OP was asking about the 2.0T, for info, the diesel engines do have a timing belt and not a chain, and the change interval is every 60K miles I believe.
Old 6th March 2009
phred923 phred923 is offline
My Saabs: 2004 9.3 Linear (CPO)
I had some noise as well, ended up being the tensioner not "fully engaging" which was causing chain to bang against the guards, thus damaging them. Luckily still under warranty (CPO) so all was covered, and even changed the belt while they were in there, for the cost of the belt only.
Old 7th March 2009
cheers guys.
The car is an automatic, petrol.
It's mainly at idle you can hear it rattle.
Oil is changes at 10,000 miles. Plus change it last week and its still rattling a bit.
I guess you could describe it as similar to a diesel engine noise (from inside the car) but a lot quieter.
Thanks
Old 7th March 2009
JMarkert's Avatar
OK, well I agree that it's definitely worth checking out. It could be something minor, maybe an accessory or shield that rattles when cold. Check on the ng900 forums, perhaps someone has posted an audio file with chain rattle. Because their cars are older, they're more likely to have experience with this. The motors are reasonably similar.
Old 7th March 2009
cheers guys
I will have a look
Old 12th November 2010
mikester540 mikester540 is offline
My Saabs: 2004 9-3 2.0t
Talking
I apologize for posting to a very old thread--
but I came across this and I have a similar issue (hindrance more so.)
I recently purchased a 2004 Saab 93 2.0t Linear @ 58k miles... and it has the same 'rough idle' almost diesel sounding noise that 'rg627' mentioned. It doesn't sound like a diesel truck outside of the car, but inside it has a very distinct diesel idle sound.
Any idea on what it could be?
Thank You and sorry for bringing up such an old post.
Mike
TunnanXWD TunnanXWD is offline
My Saabs: 280-XWD Aero & a 2.0 XWD
Have you tried a new muffler?
On yer' wife. They tend to rattle on and on about nothing at all.
mechone mechone is offline
Default timming chain hydraulic tensioner
It is more than likley the tensioner is seized quite common,it can come apart and be cleanned, but you must be careful your timming dosn't jump.
It's the big nut 1 1/8 on passenger side of engine at rear.
Old 13th November 2010
9-3Anniversary's Avatar
9-3Anniversary 9-3Anniversary is offline
My Saabs: 2007 9-3 Aero V6
Garage
Are V6's the same with the timing chain as well?
Brian Spearman
MY07 9-3SS Aero V6 Six Speed Titan Grey
Saabista
The 2.0T/t 93SS has two Internal timing chains designed to last the life of the engine..... the Serpentine Belt should be changed every 60K and the tensioner adjusted or replaced.
kimvette's Avatar
kimvette kimvette is offline
My Saabs: 2005 Saab 9-3 Linear
Cheers
You need a tensioner - unless you have been driving your car REALLY hard, the timing chain should last the life if your cylinder walls and piston rings. It takes a LOT of torque or a lot of outright abuse to stretch a timing chain. I would have the chain tensioner checked.
Old 14th July 2014
Doranso Doranso is offline
New Member
My Saabs: 93 vector 1.8t cabriolet
Hi, This may be an old post but new to me, I'm trying to determine if my
93 Vector 1.8t cabriolet 07 plate with 40,000 miles has a timing belt or chain
If belt can anyone advise the replacement period, is it 7 or 10 years
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
