interior light sensor? - SaabCentral Forums
Old 1st March 2009
toplessFC3Sman's Avatar
toplessFC3Sman toplessFC3Sman is online now
My Saabs: '06 9-3 2.0T
Default interior light sensor?
I was just wondering if our cars have a light sensor that changes the back-lighting of the instruments and screens depending on how light out it is. I've noticed that in dim-light that the nav and SID screens will dim occasionally and then return to full brightness, and was wondering if it was because of a sensor of this type. Thanks SC!
Old 1st March 2009
Mihai's Avatar
Mihai Mihai is offline
My Saabs: '04 9 Aero
Yes, it's the one from the top of the fascia, under the windshield. It's called Sun sensor.
Old 1st March 2009
Cosmicflash Cosmicflash is offline
My Saabs: '09 9-3 SS Aero XWD
At night turn on your interior lights and watch the display brighten then dim when you turn off the interior lights.
03' SS Linear Cosmic Blue, 109k mi., gone
06' SC Aero Auto Fusion Blue, BSR tuned, 94k gone.
09' SS Aero XWD Auto
Carbon Gray, Black Premium Leather, VTuned, 30% tint.
Old 1st March 2009
so its that black half-circle that the alarm light is around on the windshield side of the SID? I couldnt find it in the haynes manual, and i just want to make sure that the lights dimming and brightening is normal. I noticed it dimming and brightening intermittently when i was driving around dusk with the lights on.
EDIT: didnt see the pic the first time. thanks a lot!
Old 1st March 2009
The Saab Newbie's Avatar
The Saab Newbie The Saab Newbie is offline
My Saabs: 2007 9-3 Aero 6 Speed Manual
Here you go
Jeff
Old 1st March 2009
Wow, thats a record! Three replies and not one "Search a Bit"
LOL
Jeff
Old 1st March 2009
mcscholz mcscholz is offline
My Saabs: 2006 93 2.0T AUTO 152k Miles
Default thanks for the post
i was sitting in my car the other day and noticed the same thing. I figured something was getting ready to fail. glad to know it is supposed to be doing that.
Old 1st March 2009
cadcamjim's Avatar
cadcamjim cadcamjim is offline
My Saabs: 2006 9-3 Sportcombi 2.0T, 5-M/T
Although that is the solar sensor pictured on top of the dash, I believe it's function is to provide feedback to the ACC. The light sensor for the display lighting is on the face of the radio. If you look at the Select knob on the face of the radio, you'll see a small circle maybe 1/8" in diameter at approx. the 11 o'clock position relative to the select switch. Try shining a flashlight at that spot and you'll see what I mean. Note that only the led display screens are adjusted; not the actual i/p backlighting.
Old 1st March 2009
Mihai's Avatar
WIS says:
Instrument lighting:
ICM controls the instrument and button illumination with the help of:
Brightness control buttons (rheostat function) on SIDC.
Light sensor on rear of SID that measures the ambient light from the front.
ICM uses these values when calculating a suitable brightness for the instrument and button illumination. ICM transmits the bus message "Instrument illumination, rheostat value" with a value between 0-100% on the I-bus.
The brightness control comprises a +/- switch that provides ICM with information on the driver's choice of instrument illumination. SIDC transmits the current button press to ICM, which increases or decreases the rheostat value accordingly.
A PWM signal from SIDC on pin 4 to ICM pin 14 indicates the button (+/-) that has been pressed. This signal is a 5V 960Hz square wave with pulse ratio 40% for the up button (+) and 60% for the down button (-). See the SID control panel table.
The light sensor that measures brightness from the front is fitted to the back of SID together with the alarm LED.
The light sensors have a measuring range between 0 and 40000 Lux.
I'll test it tommorow by covering the solar sensor
Old 1st March 2009
aerojon's Avatar
aerojon aerojon is offline
Smile
there are 2 sensors..
that's to do with this sensor...link removed before i can't edit post
Is still running factory oe coils with Hirsch tune..
Old 1st March 2009
wow, very informative! Glad to know its not a malfunction, just the car doing what its supposed to. Thanks a lot guys!
(yea, no "search NOOB!" responses, SC is awesome!)
Old 2nd March 2009
Mihai's Avatar
I tested this morning and... the interior lights dim only if both sensors say about the same thing. I had to cover both sensors in order to see a change on ICM.
Old 2nd March 2009
idontknow idontknow is offline
My Saabs: 2003 9
haha i thought my radio face was starting to peel, didnt know that was a light sensor
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
