Forged pistons - SaabCentral Forums
Go Back   SaabCentral Forums > Classic Saab 900, 1979-1993 & 94 Convertible > Classic Saab 900 Performance, Mods & Tuning
Classic Saab 900 Performance, Mods & Tuning Covers Tuning & Performance modifications for the Classic Saab 900
Old 14-03-02
Janne Selinummi Janne Selinummi is offline
Default Forged pistons
A guy at a Finnish performance bulletin board claimed that the forged Mahle pistons
(as used in all Saab Turbo models) are not reliable when running more than 1 bar boost.
He said that at that kind of boost level, the pistons wouldn't last very long.
Is that completely bull$hit? I mean, not all you people driving around those heavily modded c900s have some custom racing pistons, or...????
Can I use my T8 APC pistons to run 1.4 bar of boost?
Old 15-03-02
Fan-TC Fan-TC is offline
Well i have never experienced any inherrant weaknesses with the Saab Spec pistons (unless you allow detonation).
One excellent Mod i once saw was a 2.0L 9000 turbo motor that had been stripped and rebuilt with stock low K's rods and crank and used very early model low compression pistons (bout 7:1 with 16v head i think). This was then put back into the 9000 (cause of its strong gearbox) and was fitted with a turbo from an early 930 Turbo porsche and 9000 IC (2bar Boost).
I never rode in the car but with the aftermarket engine management it ran beautifully, although slightly laggy.
It ran a high 12 quarter mile on slicks (owner disapointed) before it was destroyed by a big tree.
However these were Second Hand Saab Spec pistons suporting 2bar (400hp+) without breakage.
Old 15-03-02
Eric van Spelde Eric van Spelde is offline
Yes, this is complete bullsh*t. Apart from unlikely and unfortunate coincidences that mostly involve a complete drainage of engine oil, the only likely way you'll break a stock Mahle piston on a Saab is allowing your engine to knock.
Old 17-03-02
Alanb Alanb is offline
Didn't Raul destroy his pistons (or was it bent rods?) by running at 30psi?
In my experience these pistons can take a hell of a lot so long as knock is kept at bay.
Alanb
Old 17-03-02
Well, IIRC the reason he got to 30 psi in the first place was him removing the APC system...
Old 17-03-02
Smackrazor Smackrazor is offline
My Saabs: '92 Green 900 Turbo wSPG Kit
And secondly his car was completely unmodded besides that :smile:
Old 30-06-04
Matthew's Avatar
Matthew Matthew is offline
Saab Mad
My Saabs: 900 S Aero Turbo, 9-5 Aero
What is the weight difference between a cast and forged pistons? Assume they're for the same application.
Old 30-06-04
Alex's Avatar
Alex Alex is offline
My Saabs: 3dr c900 T16RA, 9-5 Aero Estate
Not sure what the weight differences are but on the Mk1 Impreza the WRX used cast and had a 7000rpm limit the WRX STi used forged and had an 8000rpm max.
Old 30-06-04
nutcase's Avatar
nutcase nutcase is offline
My Saabs: 1978 99T in black; 1983 99GL in Beige
All I know is an equivalent forged item will be heavier than the cast version.
Old 30-06-04
Alex's Avatar
But due to the superior material properties available when forging something, less material thickness needs to be used so the item can be made lighter.
Old 30-06-04
4saabstoomany's Avatar
4saabstoomany 4saabstoomany is offline
My Saabs: 86 900T
those after market forged pistons are a pain anyway. Don' you have have to let your car warm up a while to let the pistons expand so they don't jar around in teh cylinder? or something.
Old 30-06-04
nutcase's Avatar
I'm not doing very well today! Just nosed through my A series books and you're right. I got it the wrong way round again!
Old 02-07-04
My Saabs: 86 900T
we'll let it slide today nutcase
so whats the verdict? are they worth the hassle?
Old 02-07-04
ejenner's Avatar
ejenner ejenner is offline
Banned
My Saabs: 900 Carlsson, 99t, 99 T16, 900 t16 vert
I was looking at a site yesterday http://www.thedodgegarage.com/the_reliant.html where a guy had decided to wrench some extra performance out of some really ugly (IMO) American car. He was using the thing for drag racing and it explains how he managed to melt a piston.
He explains that this happened because he fitted a new intercooler which allowed lots of air into the system and effectively reduced the octane in the fuel. These pistons were stock cast pistons and not forged. He was running 21-30 psi with extra injectors which was getting him 12.6 @ 108mph over the 1/4 mile. He replaced with forged pistons and managed to get his time down to 10.5 @ 130 mph. This required lots of mods tho... It was an interesting read.
Old 05-07-04
rally900's Avatar
rally900 rally900 is offline
Default Re: Forged pistons
I don't want to burst your bubbles here guys but...
...all stock saab pistons, turbo or otherwise, are CAST not forged. However i have never had any problems running up to 18-20 psi and even ran one engine at 22-25psi for 100,000 miles before the bottom end started getting soft (rings, and the bottom end had 250k at that point).
However I have heard many instances of piston melt from running high boost with improperly tuned engines. But yeah, forged pistons are worth it. and you don't have to go aftermarket- there are a number of stock cars that came with forged pistons from the factory. the escort cosworth for one. and yes, the pistons fit, with just a touch of machine work.
james
team saabworks
Old 05-07-04
ejenner's Avatar
Banned
Everyone on here believes the pistons from the Turbo cars are forged. How do you know they aren't?
I only think they are because so many people mention it so often..
Old 05-07-04
Matthew's Avatar
Saab Mad
The stock pistons are most definitely cast. Every authorititive source on the subject has stated clearly that to be the case.
For the 0.8bar boost that a stock T16 uses, forged pistons simply aren't required.
Old 05-07-04
nutcase's Avatar
I thought the rumour was the 99T pistons were forged? Of which I have no idea about. The manual lists teh dish depth and diaemter, but just has a - for weight (the others are listed).
Old 06-07-04
rally900's Avatar
When ordering replacement Mahle pistons all 99/900 applications are spec'd with cast pistons. As was pointed out, the stock boost levels do not warrant using a forged piece. The factory specs also list cast pistons as the only option for pistons.
james
team saabworks
Old 06-07-04
aeroman aeroman is offline
My Saabs: 900 T16s / 9.5 aero
I broke an engine because of detonation, the car was a 900 turbo 16 with just a 3.3fpr and a mbc (so the apc was disconected) the pressure of the turbo was about 1.25bar, I broke this engine at 220 km/h, I used to drive this car as a crazy guy. When I think about it I think that the pistons of the 900 are very strong!!
now my car is running with still the MBC and a very high boost pressure (1.5bar) but with lots of others mods to prevent detonation:
air/water intercooler
aquamist water injection and 1mm injectors
27lb/h injectors
3.3fpr
2.3 head cylinder
Now no problems and I am still runing it so hard!!
