My car eats thrust bearings.... - SaabCentral Forums
Old 26-02-09
900 Turbot's Avatar
900 Turbot 900 Turbot is offline
My Saabs: 1995 900 Turbo SE; 2001 93 Turbo SE
Default My car eats thrust bearings....
One year on from a front suspension overhaul I'm getting that grunchy grinding/knocking from my RHS suspension on slow right hand hard turns that tells me the thrust bearing has gone...again...
Does anyone else get through thrust bearings at this rate? This will be my third in 4 years
I have Bilstein shocks and 205/45/17 tyres (standard bushes & springs), so I guess it gets hammered more than your stock item, but taking the suspension off once a year is doing my nut.
And now for the stupid question....you know what its like - you take everything to pieces and the phone rings and you can't remember which way up things were ten minutes ago - so here goes...just to make sure...is this photo of the thrust bearing the right way up (i.e. flat side down?)
http://www.saabcentral.com/forums/at...id=11620&stc=1
Old 27-02-09
earthworm's Avatar
earthworm earthworm is online now
Saab Sage!
I think 90% percent of us go at least 90K miles on these thrust bearings......Something else is wrong,
Overtightening.....know the specs and why
Misassembly......if the phone rings, do not answer!
Bad parts, somewhere, and at times, not evident..
The earthworm
'96 900S, Automatic
