Exploded Diagram Of... - SaabCentral Forums
Old 24th February 2009
99S9-5BV6's Avatar
99S9-5BV6 99S9-5BV6 is offline
My Saabs: 99 9-5 v6 3.0L
Default Exploded Diagram Of...
Need the exploded or electronic diagram (WIS?) of:
1999 v6 3.0 L 9-5 saab
oil cooler and thermostat area to figure out where seal rings go from oil pipes oil cooler.
oil filter housing and connecting oil pipes to figure out where seal rings go.
turbo charger and connecting manifold to the front of turbo, to find part number for the O-ring that connects the two. (see diagram)
thanks
Regards,
  • 99S9-5BV6
Old 27th February 2009
99S9-5BV6's Avatar
http://www.saabcentral.com/forums/sh...d.php?t=150093
http://www.saabcentral.com/forums/sh...d.php?t=149609
Regards,
  • 99S9-5BV6
Old 28th February 2009
Al's Red Wagon's Avatar
Al's Red Wagon Al's Red Wagon is offline
My Saabs: 1999, Cayenne Red 9-5, 2.3 Wagon
hiros's Avatar
hiros hiros is offline
My Saabs: Saab 95 Aero M00
Cool AL, you have EPC running again.
99S9-5BV6's Avatar
Thumbs up
On the inlet exhaust system
The seal (23) is in fact the same as the fuel filter seal. (smaller of the two sizes)
(24) which is NLS, (no longer in stock) can in fact be replaced with the larger copper washers, like those used to replace banjo bolts on OIL COOLER. (see picture cooling system) 4621413.
If I am not mistaken, these copper washers can also be used (recommended by the surgeon general) to replace (14) (see picture inlet exhaust system.)
Do we have the part number for 14 to confirm?
Thanks Al, I'll have to go back and throw some fuel filter washers on the oil filter housing tube instead of the copper ones. Unlike the feeds to the turbo (copper) I suspected this but wasn't sure.
gotta get me one of those EPC's!!!
Regards,
  • 99S9-5BV6
#14 = 110 16 289 - sealing ring...
99S9-5BV6's Avatar
110 16 289 = An oil drain plug gasket ?
Source = www.thesaabsite.com
Wait...is the oil drain plug gasket = the suggested copper washers for oil cooler..... ???
Brilliant !!!!
Regards,
  • 99S9-5BV6
that's an affimative on the sealing ring. I've found that as time has gone by, more of the bolts and washers have become multi-use...
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
