Just how much of a nightmare would it be to retrofit air conditioning to my 900? Would the cost be prohibitive?
I'm thinking "big nightmare" and "yes" to each of those questions, respectively. |
| Sponsored Links | ||
Advertisement | ||
Hi Matthew,
just a list of items you need in order to confirm your thought (and I can possibly forget some of): A/C radiator Evaporator Condenser Compressor Expansion Valve Additonal pulley Hoses A/C cutout switch (together with the T pipe is nearly 120 Euro OE in Italy) A/C switch Relays Additional Raditor Fun (if not already installed) Just the idea to start installing all of these items makes me freezing I don't want to think about the expense. Hope the above will convince you to give up. Armando |
That list sounds about right . . .
Is it just me or do Saabs have the weakest A/C ever? Everyone I know with a c900 has had their A/C broken for as long as they can remember! Probably cheaper to put in a sunroon if you don't already have! :wink: |
Thanks for the replies folks.... 'fink I'll knock this idea on the head pronto. On a car already equipped with air con, I wonder if it's feasible to upgrade that to a more modern system from a newer Saab... (probably not Last edited by Matthew; 26-08-06 at 05:58 PM. |
You also need the wiring loom if not already present on the car, the flap to close the cold air intake when switching to recirc mode (plus motor) and the upper water pipe with relocated thermo switch.
Oh, and the cost for someone to charge the system up and check for leaks. |
I have recently been considering retrofitting a newer compressor that puts a bit less load on the engine. |
This idea is still rattling around in my head.
There's an independent Saab garage in the South West who'll retro fit air conditioning to a C900 for Ł600. Ł350 for the kit, and Ł250 for fitting. Probably plus VAT. Does that sound reasonable?
The path of my life is strewn with cowpats from the devil's own satanic herd |
That sounds like it's about right.
In 1984 a kit cost about $1000 and took 5-8 hours (depending on how many you'd done) to install on a new car.
Corporations are people! If you prick them, do they not bleed? If you tickle them, do they not laugh? If you poison them, do they not die? |
Is the retro-fit a difficult/nasty/tedious job?
I am sure somebody with as much spare time as yourself will find it a doddle
Not too sure about the dodgy south west specialist though |
And also... just take a vacation to the USA or something, heck, I'd give you a complete aircon kit, just pull it out of the car
Are you going to Sweden?
The path of my life is strewn with cowpats from the devil's own satanic herd Last edited by Matthew; 25-06-07 at 04:36 PM. |
It was tedious, but straightforward. With all new parts on a new car, they always worked perfectly.
Occupant comfort in car to a large degree depends on moving large amounts of air to achieve the number of air changes required for a vehicle in full sun. This means having a large surface area for the air vents to keep the air velocity down to reduce noise, and the C900 dash doesn't have anywhere enough vent area. Having said that, my A/C works fine to achieve comfort, it is just noisy in the cabin. Good thing I have a vert as you are already used to the noise level, but when I drive my Mercedes ML I have to check the tacho to see if the engine is running |
How to fit 9000 ACC into C900? That's a question. First You have to find a suitable place for control unit. It is 1 1/2 DIN (I think), so mybe remove an old ventilation knobs and make a big hole under radio opening... Try to measure it. Now I have to go, but I will return after cca. two hours... |
I was pondering this problem as well. In 95 degree heat and high humidity, the top stays on and the ac is just adequate. It stops blowing cold when the car is stationary.( At least mine does) I remember the 92 9000 had a second condensor in the back and I was considering if it was possible to add a second condensor and fan in the central storage bin, run the lines through the unused steering access and join then together with couplings from the 92 9000. Then cover everything with two black directional vents. Possible?
Tom |
IMO you are best with just getting both fans to operate with A/C on. This will improve performance at the condenser. With a second unit you are really just making more problems.
You may have a weak charge in the system, may need more gas!
I tend think that the C900, and maybe any SAAB really, is a warm car, as in, the materials used are very cosy and warmth related. So when the car is exposed to heat, say in Australia here, the warth retention really works and then makes the A/C seem ineffective etc.. Once the heat soak is neutralised the A/C in my car is more than adequate. I think tinted windows definately helps too.
------------ ODE to the N\A "I have not TURBINE to compress my buttocks, O lord, Pity will be thine when thoust can crap on with boost. We of the 'N\A - N\A' knowst nil of the pulling glory, Yea, to post, thy blight the day of those who pressurise their pipes, Alas, suck be mine that my chariot breathes, Strike me down for mine is an unworthy existance" |
Ok, I am back again...
let's leave question of fitting 9000 ACC, it is for Tuning section, and speak about fitting original AC system into C900. When You look on the list from Armando, You need also recirculation flap, together with its vacuum servo, solenoid for this servo and thermostat. First point should be check of wiring, because to make a new wiring is the hardest part of the job. Start at the switcher row, remove twoo blank covers and try to find two connectors, one is for AC switch, second is for recirculation flap. They should be wired at this order: AC switch: Terminal 4 - yelow/red (two wires, one of them goes into term. 7) Terminal 5 - black (two wires) Terminal 7 - yelow/red (two wires, one of them goes into term. 4) Terminal 8 - blue Recirculation switch: Terminal 4 - yelow/red (two wires, one of them goes into term. 7) Terminal 5 - black Terminal 7 - yelow/red (two wires, one of them goes into term. 4) Terminal 8 - grey Next check is wiring for recirculation solenoid. You should find wires near ventilation air intake, for GB cars at drivers side... One of them is grey (from recirc. switch term. 8), second one is black (earth). There should be also next two wires, for thermostatic switch. They are blue/white and green/white. Sorry, but I have to go away again, so later... maybe someone else will continue sooner then me. |
the ventalation system in the c900 is outstanding. The air volume excahnge is 100litres per minute at fan setting 1 when all duct seals are in good working order.The A/C system in the c900 is just too weak for r134A, something lese is needed. I have r134a in my blue car and I used ot say it worked great but it isn't amazing. IN moderated Vancouver is is fine, in California it is a little hard to use. Plus the power drain on r134a is just ridiculous, r-12 is THE GAS TO HAVE! however r-12 makes holes in the ozone, some people disregard this and say "so what", shame on you people, please stop depleting our ozone. we need to dispose of the gas and use something else. who knows what tho....
does a 1993 c900 or 1994 c900 vert use a factory r134a? 9000 went r134a iun 1992. I wonder if the later c900s had it?-then that would be the system to have. A Saab without A/C is just worng, it isn't an economy car, it needs ot be working to enjoy the way the car was meant to be! plus the defogg on rainy days is awsome!
Fun times: Classic Saab 900 Turbo Convertible, Porsche 911 Last edited by woywitka; 22-03-07 at 11:36 PM. |
| Sponsored Links | |
Advertisement | |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
