OK here's the drill. Clutch has pressure, then two or three pumps later clutch has no pressure. Wait five seconds, clutch has pressure again, two or three pumps later it's gone again. Etcetera, etcetera.
What's gone wrong? Master? Slave? Flexible link? Or (fat chance!) will a bleed fix it?
Whale oil beef hooked |
| Sponsored Links | ||
Advertisement | ||
Sounds like contaminated fluid or a perished seal. Best hope is its contaminated fluid. Try bleeding it
Does the clutch engage if you keep the pedal depressed?
http://www.saabcentral.com/forums/sh...ad.php?t=49918 Any fluid leakage?
The path of my life is strewn with cowpats from the devil's own satanic herd |
Perished O ring in slave , internal leak past seal . Loosing any fluid ?
Thanks for the input, SAAB friends. There's no fluid loss; my bet is it's the master. Will do more investigating on the weekend and try Alex's clever test.
Did I mention that when I went to pop the bonnet after making it home yesterday, the latch mechanism decided to stop working? One of those days...
Thought I would bleed the system first. Hooked up the trusty inner tube, loosened the bleed screw, pumped up the tube ... nothing. Took the bleed screw out ... no fluid escaping, under pressure or not. Why? Can a failed master, or slave, prevent fluid from flowing to he bleed screw?
( Decided to change the front brake pads while the car was laid up. Darn it, left CV boot was torn, so whipped out the axle. This old Aero is turning into a project car!)
I'm lazy, just tell me what's wrong..........
Global Financial Crisis Global warming Ongoing conflicts in troubled parts of the world Fire Floods People losing jobs and-....... Oh sorry,............ the CAR......?
------------ ODE to the N\A "I have not TURBINE to compress my buttocks, O lord, Pity will be thine when thoust can crap on with boost. We of the 'N\A - N\A' knowst nil of the pulling glory, Yea, to post, thy blight the day of those who pressurise their pipes, Alas, suck be mine that my chariot breathes, Strike me down for mine is an unworthy existance" |
Adrian Soon to be living life on the road in an old VW http://WhereverTheRoadGoes.com |
is the flexi rubber in the clutch line balloning when pressurising?
SaabHearted |
I went ahead and pulled the master cylinder since it's an easy job. Will overhaul that and see if it works but I suspect I'll soon be tackling my first slave repair.
Its the master - these leak internally; if you were losing BF(brake fluid), then in all likelihood, it would be the slave..
Clutch hydraulics are the same as the brakes, but brakes very seldom leak BF..KOW
The earthworm '96 900S, Automatic Those who think in the past will have no future. 173K miles in the good ole USA |
Not much time to tinker today but I did take the master cylinder apart. Seals looked OK (will replace them anyway) but everything was coated with a gunky brown ooze so will give it a good clean.
I mentioned earlier that I couldn't get fluid to come out the bleed hole when trying to do a pressure bleed. Maybe the clutch line is also gunked up with bad old fluid? Tomorrow I will use a syringe to try to pump some clean fluid through the lines and out the bleed screw. Maybe I should start with a solvent -- will brake cleaner do any harm?
Yeah, took the bleed screw right out and poked around a little but no flow.
I'm presuming you've slackened off the various unions in the line, one by one, from master to slave, and checked that you've got fluid coming to each?
Darn, not enough tinkering time lately, what with work and kids.
Just time today to rig up a little clutch system back flushing kit, consisting of a big syringe hooked up to the bleed screw via clear PVC. Pumped clean brake fluid back through the system and out the metal line where it joins the master cylinder (which my loyal readers will know has been removed for a rebuild). The fluid first came out black and nasty, then gradually, over five or six syringes full, ran nice and clean. You bewdy! Now to get myself a master rebuild kit, put it back together and see if I've got a working clutch again.
Special .. Good stuff re fluid ..
Put a kit thru both ... whilst doing is good .. Be horrid to button it all up and then have to do slave .. for the sake of a few dollar seal kit .. |
Aah well, it will be a good learning experience -- one of the few jobs I haven't yet had to do on a 900.
PHP Code:
Just becareful not to *nick * the new seals , I Use PBR rubber grease. |
| Sponsored Links | |
Advertisement | |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
