Cheap key blanks - SaabCentral Forums
Old 21st February 2009
hkayssi hkayssi is offline
My Saabs: 1997 900S
Default Cheap key blanks
Ok guys I finally found a place that sells cheap key blanks for the NG900. I have a locksmith that cuts them for me for $5.00. Beats paying $68 at the dealer
http://www.locksmithstore.com/catalo...=00&pn=S32YS-P
Unfortunately I bought a key a couple of months ago for $25 at a locksmith
This is the blank for a 9-3
http://www.keylessride.com/order/quo...&frid=852B2FB8
And they sell remotes too but more expensive than ebay.
http://www.keylessride.com/order/quo...&frid=994967BC
Ero's Avatar
Ero Ero is offline
My Saabs: '01 9³SE
Wow sweet
Will these work with a 9-3?
My Saabs: 1997 900S
Originally Posted by Ero
Wow sweet
The 9-3 has a chip so you will be able to open the doors tailgate and such but won't be able to start the car. It would help if you drop the key inside the tailgate before you close it.
I'm presently looking for a 9-3 key blank so I'll let you know if I find one cheaper than the dealer
Ero's Avatar
Ero Ero is offline
My Saabs: '01 9³SE
I think I have made two threads asking whether it does or does not have that chip, and this is the first definitive answer I've gotten. Thank you
Do you think it's possible to get this blank key done and then get an aftermarket fob to simulate the chip inside the genuine key?
My Saabs: 1997 900S
I think I have made two threads asking that already, and this is the first difinitive answer I've gotten. Thank you
The fob will only work to arm and disarm the car alarm; the chip is integrated in the key to stop the immobilizer when you put the key in the ignition. The only way you could make this key work is to get a used remote key (it has the chip and alarm) you program the all in 1 remote and use the cheap key with it but that isn't an elegant solution. I'm looking for a chipped key now for the 9-3. I'll let you know if I find one
Ero's Avatar
Ero Ero is offline
My Saabs: '01 9³SE
appreciate it
I've thought of the two-key approach (dont care about elegance, it'd be a spare set), but two things were stopping me: finding a cheap blank, and whether the chip in the fob(if there is a chip...i wasn't sure back then) is always active, or a current is run through it when you insert the key to activate it.
Cheap blank is taken care of, now wondering about the second question.
My Saabs: 1997 900S
appreciate it
The all in 1 key has both the alarm and immobilizer chips so you need not worry about that. You need to buy & program the all in 1 key as well as buy and program the blank. Also make sure the key shaft is identical. My locksmith told me they were by comparing the 9-3's key and the NG900's
The regular 9-3's key only had the chip and the banana fob had the alarm chip only. so you can't use the ng900 blank with the 9-3's banana fob.
Why not just wait to see if I can find the chipped key? My locksmith told me it's available as an aftermarket as well but more expensive obviously.
Ero's Avatar
Ero Ero is offline
My Saabs: '01 9³SE
Now I'm confused.....
I meant buy a used all in one key and reprogram it to work with my car, then buy/cut one of the cheap blanks you posted above and use it on the same keychain as the used key. That would let me start the car with the blank, and the immobilizer should be disabled due to the all in one key being present and properly programmed.
I'm patient (hell not like i have any money now anyway ), just throwing ideas out there.
My Saabs: 1997 900S
That would work
Ero's Avatar
Ero Ero is offline
My Saabs: '01 9³SE
yay!
so that answers my question - the chip in the all in one key that talks to the immobilizer is always active, so if it comes into proximity of the lock, it will turn off the immobilizer.
My Saabs: 1997 900S
Forget the key. I just found a 9-3 blank key for $25
Ero's Avatar
Ero Ero is offline
My Saabs: '01 9³SE
your google-funeral is unsurpassed sir
Old 22nd February 2009
1stepabove's Avatar
1stepabove 1stepabove is offline
My Saabs: Saab 9-3 '07, Previously owned '99 9-3
assuming one were to buy one of these blank keys for a 9-3, and purchased one of those remotes on ebay,
how much will a dealer ship charge to program the remote
and
carve key (or program the actual key ) or can it be taken to a locksmith,
*Dan H.
Saab 9-3 1999 , Convertible, Stick
Midnight Blue, 216k miles!
So much goes into a SAAB, I love it!!
My Saabs: 1997 900S
My dealership charges $24.95 to program the key.
You need to find a locksmith that does road assistance. Those have the necessary cutting tools. The one I found, charges $5 per key to cut.
Rogozhin's Avatar
Rogozhin Rogozhin is offline
My Saabs: 1994 Aero, Stage 3, BCBECU. Viggen Sold.
Thanks for the link HK!
My Saabs: 1997 900S
Hi Rogo, you need another spare too? Is it for the new 9-3 or the Viggen?
Old 11th February 2010
bullyd's Avatar
bullyd bullyd is offline
My Saabs: 2 97 900S Auto 90K & 150K+
These will work with a 1997 900S?
Thanks
My Saabs: 1997 900S
Thanks
This one would
Old 15th February 2010
bullyd's Avatar
Originally Posted by hkayssi View Post
thank you.
did you have to register for this site? i tried and they denied me registration.
My Saabs: 1997 900S
No I didn't. I didn't buy one from them. I just searched using the part number on the blank I got for X5 that price The blank cost me $15 (same key made by the same manufacturer and same part number) I guess their mark up was high! Cutting the blank was $5 or $10 I can't remember.
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
