| Saab 9-5 Workshop Saab 9-5 Workshop (1997 to 2010) Technical Forum |
The star shape on the head of the screw is not catching my torx screw cause its warn... any suggestions or ideas how to resolve this...? tried pliers, what else?
Thanks
Regards,
| Sponsored Links | ||
Advertisement | ||
Try pliers or maybe a flat head the same size at the star key and give it a wack.
Depending on where it’s located, maybe if it had a hack saw black cut down enough to use a flat head screwdriver just take your time... Good luck j |
If there is space, use a vice grip, small one. $%#% those torx head
How much room do you have to work? Maybe try something like this?
There is a "replacement for displacement".... It's called "forced induction". |
I have had this problem several times on my car and i use a left hand drill bit to make a small hole in the bolt and then an easy out.
www.homedepot.com NOTE* make sure to drill far into the screw head and screw the left hand screw bit as far in as possible... or it'll snap like a twig, when your working it out. Otherwise, then your left with a screw head that is threaded, and has a reinforced drill bit through the center... you can think about a hack saw at this point. I ended up taking pliers and ripped the O-ring off the turbo manifold. I also went through 7 drill bits. good luck
Regards,
No I use a standard left hand drill bit and bore a small hole and then use a tool called an easy out. The reason for left hand drill bit is to keep from running the screw further in while boring hole.
Interesting, this type of drill bit was unfamiliar to a home depot employee... then again..... not comment. thanks
Regards,
google left hand drill bit and screw extractor, sears or home depot will not caryy these. Industrial supply is best bet, they will break but not as easy.
| Sponsored Links | |
Advertisement | |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
