t5 suite ...... getting there ...need bin file - SaabCentral Forums
Go Back   SaabCentral Forums > Saab 9000 > 9000 Performance, Mods & Tuning
9000 Performance, Mods & Tuning Covers Tuning & Performance modifications for the 9000
Old 14th February 2009
krawczuk krawczuk is offline
My Saabs: 1998 9-5 2.3 turbo , TD04, 3 inch dump,
Default t5 suite ...... getting there ...need bin file
hi, tried to get bd32 running on me duo core pc with xp , kept getting " cant reset mcu ???? " or sumthin like that , i used a bdm adapter from ebay.
then i finally got a old 400mhz laptop running with windows me ..... got it up and running straight away !!!!!! dumped the bin etc....
but what i need now is a orig bin file from a 1994 2.3ltr turbo auto ......
the ecu that i have is a t5 b204 , and i want to flash it with the correct bin so that i can use it on my b234
can any body point me in the right direction for the correct bin file ?
or email me one ? krawczuk@adam.com.au
thanks,
mark k
smap smap is offline
My Saabs: SAAB 9000 CSE 1996
thanks,
mark k
Hi
Just look in the folder binaries from the directory of T5Suite.
C:\Program Files\Dilemma\T5Suite\Binaries
your BIN should be there or just make a backup of the BIN of your original ECU and then change it (this is the best way)
shinobidice's Avatar
shinobidice shinobidice is offline
My Saabs: 1997 Saab 9000 CS
I'll second the "Make a copy of your own"
It's really difficult to actually mess anything up, and when you run the bd32 dumpT5 (bin) command, it just copies off the bin.
I had an issue with trying to find a compatible bin file, I ended up getting a check engine light because it wasn't the right program for my car even though it appeared to be.
I'm a happy owner of a T5 Stage 1 9000 CS (+ boost controller) car!
John Z Williams John Z Williams is offline
Vendor
My Saabs: JZWTUNING.COM 10 Sec Saabs
I agree, make a copy of your own so you always have it and can put it back to stock at any time and then modify your own base version.
I have had some trouble using other bin files from the list on ecuproject, corrupt bytes, etc.
The biggest issue is using the wrong sw version and finding out the purge matrix is wrong, etc.
In 1996, the ng900 had something like 9 different sw versions, its the tuffest year to get right. I don't even try anymore, I just find out what the exact sw version is for the car I want to tune and use that sw as the base, its the safest best way to do it.
good luck,
John
Old 15th February 2009
L4staero L4staero is offline
My Saabs: 97 9000 AERO 460hp , 06 9-3 Aero 390 hp
Hi there I made a spreadsheet etailing all ecu numbers I could find with there boost figures, markets and year models here
http://forum.ecuproject.com/viewtopi...&sd=a&start=20
I think you need to be a member to download them unfortunately.
They are very helpful for determining your base software etc
Maybe someone can host them for me
I figure you need sw 4300828
I hope this can help some dudes
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
