who uses 5th gear? - SaabCentral Forums
Old 09-02-09
007saab 007saab is offline
My Saabs: 07 9-3sc 60thA
Default who uses 5th gear?
i've got a 6sp manual and almost never use 5th gear. If I'm accelerating to fwy speed I use 3rd and 4th and just jump to 6th. Any cruising speed around 50mph and maybe I'll use 5th but it never lasts. Anyone else ignoring a gear?
Old 09-02-09
PoisonBeef PoisonBeef is offline
My Saabs: 1999 9-3
i tend to skip 4th....
(5spd manual)
Old 09-02-09
AKS AKS is offline
My Saabs: 2006 93 2.0T
me too, it gets annoying sometimes in traffic
Old 09-02-09
afinley's Avatar
afinley afinley is offline
My Saabs: '04 9-3 Aero 6-speed
i use 5th gear when i'm in town, like in 45mph zones. some time though i will go from 3rd to 6th, depending on how fast i need to go, and how quickly i am getting there.
Old 10-02-09
rogan's Avatar
rogan rogan is offline
My Saabs: 2003 9-3 Vector 2.0T
I use it quite a bit as I drive on a long stretch of road that's 45/50.
-Rogan
Old 10-02-09
brace up brace up is offline
My Saabs: 2008 Saab 9-3
i use it whenever im shifting out of 4th...
ill use 6th if im cruising on the freeway but ill keep it in 5th if im casually passing people (which i do a lot)
Old 10-02-09
cusi03 cusi03 is offline
My Saabs: 04SS ARC
in my 5spd i use it quite often...must be nice to have a 6spd gearbox.
Old 10-02-09
AeroCombi AeroCombi is offline
My Saabs: 2006 9-3 Aero SC 6MT
I tend to try to keep it in the gear that leaves the revs at/around 2000 RPM, which at about 50 mph = 5th gear. Usually though, that's just on the hwy until traffic clears and then it's 6th. For most acceleration I go through 1-2-4-6 or sometimes 1-2-5. So I'd say 3rd is the gear I tend to use the least.
Old 10-02-09
2.0T XWD's Avatar
2.0T XWD 2.0T XWD is offline
My Saabs: 9-3 2.0T XWD
I will often skip 5th when heading up to 6th, but will always shift down through all the gears.
Old 10-02-09
Wulf Wulf is offline
Banned
My Saabs: 2011 Saab 9-4X 3.0i
I never really understood the need for the 6-speed transmission. What's the advantage over regular 5-speeds?
Old 10-02-09
navygz19's Avatar
navygz19 navygz19 is offline
Banned
My Saabs: 1990 c900 coupe, 2005 9-3
Fuel economy for one thing. MB likes to toot that their new 7 speed slushbox is "xx%" more fuel efficient than 5 or 6 speeds. It gives the engine the ability to maintain a lower speed at all times.
I would venture to say in a manual it's not much more than a personal appeal. Turbo spool-up is probably a bit faster in a 6 speed.
My last car was a 6 speed and I loved it. It had much shorter gears which made for more downshifting preferences. My 5 speed that I have now has much longer gears and I would assume a bit more lag at lower RPM's in a downshift.
Old 10-02-09
the.hatter's Avatar
the.hatter the.hatter is offline
My Saabs: '04 9³ 2.0T, 5MT
i dont think the final gear ratios are that different between the 5 and 6 speed so fuel economy differences are probably negligible.
ive got the 5 speed but ive never really been one to skip gears when i shift. maybe i would if i had the 6 though.
Old 10-02-09
rideboarder's Avatar
rideboarder rideboarder is offline
My Saabs: 2007 Saab 9-3
I use 5th gear quite a bit in my area, since I drive on roads with a 45mph speed limit. So 6th is just a bit too much, but 5th seems to work great for that.
Old 10-02-09
afinley's Avatar
the main advantage of more gears is that they all can be closer together with the same final drive ratio. it makes for a smoother ride, and allows the gears to better match the powerband of the car
Old 10-02-09
Double_0_7 Double_0_7 is offline
My Saabs: '04 9-3 Aero, Dark-Greyish Colorization
-Rogan
+1...i use 5th for anything in the 40-50 range. it won't stall in 6th, but you can't accelerate to pass people either.
I almost always skip whatever gear is directly before the one i plan to stay in, lol. quick accel is fun. So I often go 1,2,3,5...or 1,2,4...or 1,2,3,4,6...because rapid acceleration through fourth then cruising in 6th is a lot more fun than casually accelerating through all 6 gears.
Old 11-02-09
the.hatter's Avatar
yea but the downside (it sounds like to me) is you 6-speeders have too many gears to go through so you end up skipping one
thus making it a 5-speed lol.
Old 11-02-09
2.0T XWD's Avatar
Ha - at least us 6-speeders will still have 5 working speeds when 1 gear fails (and enough threads should warn us that this is an inevitablity ...) our poor 5 speed brothers will only have 4, so we'll have the last laugh ... (I hope) The 6th gear may deliver some theoretical benefit, but I still remain to be convinced. More has to be better!!!
Which gears will fail first though, and why does no one complain about failed reverse gears? In fact, why do we only have 1 reverse gear?
Old 11-02-09
the.hatter's Avatar
ha well put .
quick sidetrack - how do you like the XWD system with the 2.0T? ive read some concerns that people were afraid the extra weight and drive-train loss would bog the car down, making it too slow in straight acceleration. bet the handling is lights out though.
Old 11-02-09
TXTurbo's Avatar
TXTurbo TXTurbo is offline
My Saabs: 07 9-3ss Titan Gray
Ditto for skipping 5th. I drive long distances frequently, so after shifting from 4th on the freeway I go right into 6th!
Old 11-02-09
lexington01 lexington01 is offline
My Saabs: 07 9-3 SS Aero BSR (RIP). 2012 Wrangler
That's funny. My friend (who has a 5 speed and wishes he had 6 gears) always makes fun of me for skipping 5th. I thought I was the only one!
