steering wheel mod - SaabCentral Forums
Go Back   SaabCentral Forums > Saab 9000 > Saab 9000 Performance, Mods & Tuning
Saab 9000 Performance, Mods & Tuning Covers Tuning & Performance modifications for the Saab 9000
Old 23-08-03
2fast2furious 2fast2furious is offline
Default steering wheel mod
ive seen some custom steering wheels that you can put in a saab, but does anyone know if its possible to take the steering wheel from the brand new 9-3 and 9-5 and swap it with the existing steering wheel, ps my car is a 95 9000 cse
Old 24-08-03
Simon's Avatar
Simon Simon is offline
Administrator
My Saabs: I've had a few...
I'm nor sure, but I would have thought the hubs are different.
Old 01-09-03
jim_mcghee's Avatar
jim_mcghee jim_mcghee is offline
My Saabs: M98 9-5 2.0l LPT
I would have thought that the electrical connections also would be different
Old 01-09-03
triggrhaapi triggrhaapi is offline
For those of us with non-airbag cars, it's a snap, for others, however, it's not. One thing you might have to worry about is the number of sensors and the voltages of the sensors used in the newer saabs versus those used in older airbag 9000s. In miatas (only airbag wheel replacement I know, sorry) the first gen uses the same connectors but the airbag is not electrically compatible. You can also simply disable the airbag completely and simply switch to an aftermarket non-airbag wheel. Of course then you'd have two problems:
1) depending on your skills as an electrician, you might have an annoying SRS light to contend with
2) Your insurance would go up as you get a credit for having an airbag in your car.
Old 03-10-03
zingZACH's Avatar
zingZACH zingZACH is offline
My Saabs: 99 Viggen, 88 SPG, 90 900S, 73 Sonett 3
LOL.... here is a last resort.... well... actually.... I think the 9000's have the SRS light where the door indicators are.... right? well. i was going to say.. if you had a classic 900.. just take the SRS light bulb out.. although you probably could do the same on a 9000 (but much trickier). The classic 900 has the SRS bulb right near the speaker, so it is very easy to remove. I did this to my c900T.... the light was flashing and bothering me a lot, so i removed it... took bout 10 sec to do. lol... This is only until I get the SRS reset (I accidentally disconnected the SRS cable or something when taking the Instrument Cluster out of my car, and you must have the TECH2 to reset it. Oh well). Also, you may be able to get the SRS light deactivated by your local dealership. I am not sure though, I dont know much about 9k's. Good luck! 8)
Old 04-10-03
Rhich's Avatar
Rhich Rhich is offline
My Saabs: 1993 Sleeper
As far as I can tell there are way to many differences between the wheels and hubs….
Not to mention electrical connections and what not….
Not saying it can’t be done… but would imagine a lot of work would be involved in doing it….
The 9000’s really don’t have a “hub” like the 900’s or the 9-3’s which may make the wheel sit higher or lower in relation to the stock location on the column….
Old 20-12-03
Wolverine Wolverine is offline
Just to point out, you'd have a third problem as well -- you'd have no airbag, and thus have significantly less protection in case of an accident. (There's a reason they're put in.)
This can actually be illegal in some places as well, I believe.
(I would love to get that sport wheel advertised in the new Saab materials, though...)
