| Saab 9-5 Workshop Saab 9-5 Workshop (1997 to 2010) Technical Forum |
hi, brought a 9-5 griffin to replace my 9-5 2.3. but the sid on it had the pixels going. so i thought swap it with the one on my 2.3. so fitted it, turned car on and it started saying service check and bonged five times. i know how to reset the service warning, which i have done. but have no idea why it is bonging.
any clues? thx. |
| Sponsored Links | ||
Advertisement | ||
Either way, the divorces and marriages need to be done
i didn`t think the sid had to married or divorced? thought that applied to cd player and radio.
Fasten your seatbelt and turn on ignition afterwards....
I was pretty sure most of the "computer" and stereo equipment short of speakers needed to be married to the car. I was under the impression that the ECU, SID, Radio, CD Changer and TWICE unit all needed to be married, possibly others. If not, how is the dealer gonna gouge you on Tech2 services?
point taken, but when i swapped the sids on my cars the one i put in the old one works ok(no bonging??), thats why i wonder about the marrying it up. any other ideas.
SIDS are nto married. Did you replace it with the smae version SID? THere is a compatibility problem IIRC.
If not it might be a audible warning that is on in this sid ( like seat belt as gghh has indicated) After it stops boinging scroll through the menus and see what "alarms" are set. |
SIDs are not married, but they must be programmed for chassis type, tires, engine type and so on. One Programming option is seatbelt warning on/off.....
tried what you said regarding seatbelt and you are right it is a seatbelt warning, is there a way to turn it off.
tech2 programming....
just repair your old SID its so easy just use a pen rub the ribbon and use some card and screw it down
http://www.saab9-5.com/howto/sidrepair.htm |
| Sponsored Links | |
Advertisement | |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
