OVERRIDING "KEY NOT RECOGNIZED" MESSAGE //urgent// - SaabCentral Forums
Old 19th January 2009
xanzilla xanzilla is offline
New Member
My Saabs: 2001 Saab 9-5 3.0
Default OVERRIDING "KEY NOT RECOGNIZED" MESSAGE //urgent//
When i put the key in the ignition of my 2001 9-5 3.0 Wagon, it gets to the on position, but will not turn further, and that message appears on the SID, and the car will not start. I do not need to permanently fix it, simply to TEMPORARILY OVERRIDE it so that the car will start.
Thanks in advance,
Xan
SaabScott's Avatar
SaabScott SaabScott is offline
My Saabs: 2006 9-7X 5.3i
Ummm ... not sure if you really grasp the security features built into a Saab ...
You can't just "override it" or anyone would be able to steal these cars.
President,
The Saab Club of Canada
2006 9-7X 5.3i
New Member
well i was thinking there could be something that would only be accessable if you were inside the car and the alarm wasnt armed. its just that i saw in another thread a guy said something about overriding it but didnt elaborate on how to do so, so i was trying to figure that out
MainLineSaab's Avatar
MainLineSaab MainLineSaab is offline
My Saabs: 2003 Saab 9-5 Linear, 2006 BMW 330Ci
I actually do believe there's a way to do it. Possibly by holding down the unlock button on the remote while trying to start. It's in the manual. Look it up.
Honestly, people seem like they can't read their manuals. We wouldn't have half of the traffic on these forums if people read the damn things. Not sure if that's good or bad.
Support our soldiers
New Member
actually i did read this section in the manual and there is nothing in their about what you just mentioned. thanks though!
Sorry to make you the victim of my rant.
This is directly out of the Immobilizer section of my 2003 manual:
Electronic starting interlock
(immobilizer)
When the key is inserted in the ignition, a
signal is sent to the receiver. If the signal is
verified, the engine can be started.
Each time the key is removed from the ignition,
the electronic immobilizer is activated.
This means that the car cannot be started
without the correct key inserted in the ignition
and the immobilizer thus deactivated.
If a fault is detected (e.g. in the transmitter)
”KEY NOT ACCEPTED” will appear on the
Saab Information Display (SID).
In this case, you can still start the car if you
turn the ignition key to ON and press one of
the buttons on the key (providing that the
receiver gets the right signal from the key).
Take the car to an authorized Saab dealer to
have the system checked.
The LED double-flashes when the car is
immobilized.
Good luck.
Jssaab Jssaab is offline
My Saabs: 2000 9-5 320hp, 2003 Aero Hirsch "Clone"
maybe not on 01 ( they had the fob I think)
gghh gghh is offline
My Saabs: BMW 530D Touring xDrive
same with a MY01
woywitka's Avatar
woywitka woywitka is offline
Guest
My Saabs: '87 900 T16 vert, 911 SC,914,W123 Diesel
Inser the key, turn, press a FOB button. Start and enjoy.
Old 20th January 2009
luv2drinkcoke's Avatar
luv2drinkcoke luv2drinkcoke is offline
My Saabs: Suzi - 2001 95 Arc 2.3t Auto
This is what my MY01 manual says as well.
(immobilizer)
immobilized.
Good luck.
Old 21st January 2009
9000Trubble's Avatar
9000Trubble 9000Trubble is offline
My Saabs: MY05 9-3 TiD SS, MY08 9-3TTiD SC
I had this problem on my 98 SE and used it foir a while before investigating, I eventually traced the fault to a very small broken wire under the rubber gator around the ignition key slot, once soldered back together I never had any more trouble from it
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
