2000 9-5 bucks at certain RPM - SaabCentral Forums
Old 17-01-09
garyfisher95 garyfisher95 is offline
New Member
My Saabs: 2000 9-5
Default 2000 9-5 bucks at certain RPM
car bucks at 2700-2900 RPM in every gear. Accelerates smoothly up to that point, then feels like a fuel cut. Checked for throttle limp mode but the cable is still independant of the whole assembly, and disconnected the battery for 30 minutes to reset the check engine light. The check engine light comes back on immediately. Ive searched the forum but an O2 sensor seems the only other thing mentioned. If i simply unplugg the o2 sensor can I check to see if the vehicle operates correctly or will running the car like that damage something. And is there a way to check the codes without going to the dealer? Thank-you.
Old 17-01-09
MacNoob's Avatar
MacNoob MacNoob is offline
My Saabs: 01 9-5 Wagon (RIP); 05 9-5 Aero (gone)
Why did you reset the CEL before reading the code? Autozone used to read codes for you, or you can buy a cheap OBD reader for around $50 that will work fine.
Old 17-01-09
MI-Roger MI-Roger is offline
My Saabs: 2008 9-5 Aero Sedan, 2006 9-3SC 2.0T
Default Check for vacuum leaks
And also check for loose connections at the Turbo By-Pass Valve. My BPV suddenly popped loose this past summer on an urban freeway at rush hour, resulting in the car bucking and surging like crazy.
I thought my 2000 was dead, it was a no cost fix.
Old 21-01-09
New Member
My Saabs: 2000 9-5
got codes pulled.....p1312, p1334, p0336
