Cam Cover Leak - SaabCentral Forums
Old 10-12-08
Xeo01 Xeo01 is offline
My Saabs: 9³ JZW Stg4 16T Custom
Default Cam Cover Leak
Has anyone had an oil leak come from the cam cover? It is on the passenger side and is very very small but every once in a while when I am under the car I see a line of oil coming from the cam cover and going all the way down past the drive belt. Do I just need to replace the gasket?
Old 11-12-08
woody93 woody93 is offline
My Saabs: 2006 9-3 2.0T
Depending on location of the leak, you might just be able to pull off the vavle cover and reseal it with RTV. This is all going on the assumption that its leaking for a corner where the valve cover changes shape to go up over something instead of just a flat run across the engine. Also, when you do pull off the valve cover, you may as well check the gasket. I'm not sure how much they cost, but you might just reaplce it while you're at it. Just remember, gaskets alone will not stop leaks. Even the manufacturers dab RTV in the corners where gaskets can't make a good seal.
Old 11-12-08
JonV JonV is offline
Saabista
My Saabs: 03 Vector
Just had it done last month.
Old 11-12-08
Was your's leaking on the passengers side as well?
Old 11-12-08
Saabista
My Saabs: 03 Vector
yes..............
Old 11-12-08
Thank you. I'm going to go order a gasket.
