9-5 tire size? - SaabCentral Forums
Old 10th December 2008
ethanv88 ethanv88 is offline
My Saabs: 2000 9-5 lpt 213,000 mi 02 9-5Lin 96K
Garage
Default 9-5 tire size?
my 2000 9-5 has 205/55/R16
and i was wondering if a 205/60/R16 will fit without rubbing in the fenders? i would like to put a bit taller tire on 1 because they are cheaper 2 because my speedometer is about 4 mph fast
thanks
Ethan
djrpowell's Avatar
djrpowell djrpowell is offline
My Saabs: 2.0t -> Arc (2004) 220/Estate (2007) 210
Should you have 225/55/16 on an Arc etc..
That is what I had as standard, you can also have 215/55/16 is my memory is correct!
Check your manual.
04 2.0t 220BHP Arc Abbott Stg 1 +17" (93 Alloys)
56 2.0t 210 BHP Vector Sport Est Hirsch Stg 1
Mike J Mike J is offline
My Saabs: 2003 9-5 Aero Wagon 5-spd
Try this:
http://www.1010tires.com/tiresizecalculator.asp
I'd Give My Right Arm to Be Ambidextrous
halegan halegan is offline
My Saabs: 2004 9-5 Aero Wagon
I just put some 215-55/16 snow tires on my Aero...no rubbing even with the lower suspension...you should be fine.
Old 11th December 2008
SaabScott's Avatar
SaabScott SaabScott is offline
My Saabs: 2006 9-7X 5.3i
thanks
Ethan
Neither of those are the right size tire for your 9-5.
In 2000, the stock size was 215/55-R16.
Instead of changing the side wall ratio, I would suggest you put the right size tire on the car.
Also, there is a 4% varience allowed on the speedo so you will likely never get it bang on.
President,
The Saab Club of Canada
2006 9-7X 5.3i
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
