Instant power for 20p anyone?? - SaabCentral Forums
Go Back   SaabCentral Forums > Saab 9000 > Saab 9000 Performance, Mods & Tuning
Saab 9000 Performance, Mods & Tuning Covers Tuning & Performance modifications for the Saab 9000
Old 12-08-03
aeroT16 aeroT16 is offline
Default Instant power for 20p anyone??
Whilst at our local dealers a while ago the chief technician was telling us that when the Saab turbos first came out it was a fun tweek to put a v.short length of Bic biro pen (with pilot holes drilled into it) into one of the APC pipes to act as an instant bleed valve. You adjusted it by simply covering/ uncovering more of the holes until it didnt overboost. Sounded crazy but i am sure we all have old pens under the sofa cushions! Tried it on my 89 9000 carlsson and the difference is staggering - it made 199bhp at the wheels on the rollers. Now I am quite sure that someone is going to list 10 good reasons why this system isnt a good idea - but the technicians at the rolling road said its basically a crude bleed/ dawes device and if the car is set up with fuelling checks etc then it isnt a harmful mod to do. All for 20p if you cant find an old pen lying around!! Old skool tuning tip for you to ponder!! Maybe worth running past the technical gurus on this forum...........
Old 15-08-03
tandino tandino is offline
Been there done that...........
On a di/apc 9000 youve got a margin for error in that timing will be retarded if knock is present.
Not a good idea on a C900 as you will be defeating the APC by doing this mod.
Still a cheap way to more power if a little dangerous on an APC only car.
Pete.
Old 16-08-03
rage's Avatar
rage rage is offline
I`ve seen C900`s with a hole drilled into the apc where the middle pipe goes on. Just slide it back until you get the required amount of boost.
