Clutch master cylinder diagram/pictures - SaabCentral Forums
Old 9th November 2008
supremedalek's Avatar
supremedalek supremedalek is offline
My Saabs: 88 900 turbo convertible x2 (Red+White)
Default Clutch master cylinder diagram/pictures
Does anyone have good schematics of the clutch master cylinder? I bought the Scantech rebuild kit and it seems to have two extra pieces. Also, I am trying to find out which of the rubber fittings is the check valve/plunger?
I am fighting with mine for quite a few days/weeks and just cannot see what I am doing wrong...
My
i am inspired. i will replace my windshield... with an intercooler. swedishK
racerx0140's Avatar
racerx0140 racerx0140 is offline
My Saabs: 1992 Saab 900
is it the kit that just has o-rings and stuff cause i had to rebuild mine and i think i tok pics o the project. so if it is i might be albe to help you
Exactly. I cannot believe how a simple item like that is giving me so much trouble. Fluid is going through it but I am just not building pressure when I pump.
My
racerx0140's Avatar
have you tied pressure bleeding the clutch? that helps get air out of the system.
racerx0140's Avatar
also what side of the car are you doing this from the engine bay or under the dash
MrJay MrJay is offline
Rebuilding the master cylinder was the easy part bleeding the clutch was a nightmare! Theres a guide on fixmysaab.com I did it by taking the master cylinder out though so I could check and clean it properly I just undid the hydraulic hose, removed the fluid feed pipe then all you need to do is remove the pin from the clutch pedal and the 2 nuts and out it comes
racerx0140's Avatar
that's a lot of work to bleed it but good that you cleaned it. so supremedalek you have all the air out of the line and sill no pressure? check the slave cylinder.
Old 12th November 2008
Ok, how I manage to finally bleed the bloody clutch system. I decided to, since Saab made airplanes, I might as well try bleeding it the same way we do airplanes. So, reverse bleeding I did:
And, that seemed to have worked. Man! I learned my lesson: if I ever have to bleed the clutch again, this is the way I will do it. Now, I just have to find out why I do not have 5th and reverse since I changed the transmission mount. But, that is another episode.
My
Old 13th November 2008
TheRedBaron's Avatar
TheRedBaron TheRedBaron is offline
My Saabs: 1990 900 turbo
That "extra piece" in the rebuild kit actually helps the master cylinder seals work better (well it is in itself a seal). It goes on the end of the rod, after you put the first seal on, it's like a "cap" with a washer underneath. Then, you can see by pressing on it that when pressure is applied, the seal pushes outward, increasing pressure against the master cylinder wall.
The faster you go, the more you see.
racerx0140's Avatar
supreme thats the same way i did mine at first i had to barrow that setup off of a shop then i bought my own it works so well
Old 20th January 2011
girovago girovago is offline
New Member
My Saabs: 9000 2.3 cse lpt
Default saab 9000 Clutch Master cylinder rebuilding
Hello. Continuing, after some years, with this issue, I guess someone will have found the solution, no? I am now with this: changing my pump seals clutch. I do not know the job that I can give those extra pieces. Especially this larger, I find no way to make it go, I do not know exactly in what position. Is anyone kind enough to have solved the problem. Many thanks if anyone responds. Greetings from Spain.
ianrobbo's Avatar
ianrobbo ianrobbo is offline
My Saabs: 1989 T16S T5
Garage
I bought the Scantech master cylinder repair kit from PFS. Mine, too, had extra parts (but not the same extra parts as yours!)
I used the ones I needed (the two seals and the brass(?) washer), and didn't use the rest. I believe that there is an earlier master cylinder which is slightly different, and as the Scantech seal kit is sold as an 83 to 94 kit, I assumed that the extra parts were for different master cylinders?
Can anyone confirm that there are different clutch master cylinders?
New Member
Probably yes. I find no other reason.
Thanks for your response.
Regards
PD: and it worked?
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
