9-5 Aero 2002 Engine Mounts - SaabCentral Forums
Old 13th October 2008
R J Chalklin R J Chalklin is offline
My Saabs: Saab 9-5 Aero HOT 2002
Default 9-5 Aero 2002 Engine Mounts
Can somebody give me a comprehensive guide to how many engine mounts there are on my car, also where they are positioned. I think they need replacing as I'm getting vibration through the cabin, but not sure which one or more will need to be renewed.
Thanks in advance.
valbowski1980's Avatar
valbowski1980 valbowski1980 is offline
My Saabs: None now
Garage
You have two hydro mounts (one near the serp belt and one near your shift linkage behind your engine). You also have a solid rubber mount under your battery for the gearbox. Lastly you should have a torque arm in the front of your engine which is connected to the same bracket as your solid rubber gearbox mount.
See here for a pic
How many miles on your car? I replaced all but the rear and at 134K they were pretty shot.
There is a "replacement for displacement".... It's called "forced induction".
raquettelaker2's Avatar
raquettelaker2 raquettelaker2 is offline
My Saabs: 2008 Turbo-X, 1994 c900 CommEd
Here they are. Plus there's the torque rod mount at the front of the transmission. That makes a pretty nice improvement also.
See here for a pic
I've got 200k on my Aero but new engine fitted at 143k, so I guess it's time for a change of mounts to make it smoother. By the way I've aldready put a new torque arm on it.
Well you can't get more comprehensive than that..thanks as always..you are all total stars.
My Saabs: None now
Garage
Not sure but I would guess that mounts should live longer than 57K. Were they not changed when the new engine was fitted?
No they were not replaced when the engine was changed, so I guess they are originals.
My Saabs: None now
Garage
If they are the originals then I would certainly replace at least the right and left mounts. This is a fairly easy DIY job that took me about 40 minutes to sort out.
SaabBlackMan's Avatar
SaabBlackMan SaabBlackMan is offline
My Saabs: 07 9-3 Aero V6
You had to Prop the engine right? I am guessing that the mount under the batter is the Transmission Mount?
Saab Blackmista.
My Saabs: None now
Garage
Yes,
Not only that but you may need to lift the engine a bit higher to compensate for the new mounts not being squished. A hydro floor jack will do this very well.
My engine sits 1/2 inch higher on the right side now
My Saabs: None now
Garage
What I find really weird about this (WIS) is that the solid mount (left) actually looks nothing at all like the one in the pic above.
Old 2nd March 2011
MrSmith's Avatar
MrSmith MrSmith is offline
My Saabs: 2001 9-5 Aero
Question
yes, I know this is a historic post but thats what the search is for right?? but anyway... are these three the only mounts in the saab 9-5??? i have a 2001 Aero sedan. mine is an Automatic and i want to get some for mine. and a few directions would help me install.
Old 2nd March 2011
Jssaab Jssaab is offline
My Saabs: 2000 9-5 Parts, 2003 Aero Hirsch "Clone"
And torqu rod mount on the front of the transmission
Old 2nd March 2011
firehawk618 firehawk618 is offline
My Saabs: 2001 9-5 aero
4 mounts total. Front, rear, left, right.
Old 3rd March 2011
MrSmith's Avatar
thank u, are these difficult to replace. I see the image above about 3 but weres the fourth
Old 3rd March 2011
indy500's Avatar
indy500 indy500 is offline
My Saabs: '04 9-5, '04 9-3, '06 9-3, '07 9-3
Look at post number 2 and click the link. Enter your car year, etc and then select 'Engine Mounts' in the pull down. Assuming the same as mine, the picture shows where the engine mounts are and for a 2004, the relevant numbers in the figure are 1, 7, 10 and 16.
I haven't changed these, but in general you have to get weight off of them as described above, and then replace the part. Remeber that right is passenger side for the US
Old 4th March 2011
MrSmith's Avatar
I have changed mounts on a dodge before, but this is a different beast. the one under the battery seem simple, but the others I need to look at carefully. im told that the two under the car really dont wear as much. i just ordered the top two. hope they are all needed at the this time.
Old 9th March 2011
usaabn usaabn is offline
My Saabs: 72 99E/82 900T/88 900S/02 95-Aero/08 93
I think I'm getting that same Vibration in the front. 2.3 Aero w/125k miles. Anyone have an idea on parts / labor as to cost?
Old 9th March 2011
first-saab first-saab is offline
My Saabs: '99 9-5 V6, 200k+mls, '08 9-3 Aero Vert
New mounts is worth every penny as it gives a "smoother" ride. I did all 4 some time back and will say that the left, right and front was very easy. Do a search, you will find good info on the site.
The rear on the V6 cannot be done without dropping some parts down there as you cannot get the mount out once the bolts are loosened. I believe the 4 cyl has more room around there.
Old 10th March 2011
D.M D.M is offline
i have a question on that hydraulic mount.
In the wis picture look one way (like in my car),
But on ebay pics it looks different will it fit?
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
