| Saab 9000 Performance, Mods & Tuning Covers Tuning & Performance modifications for the Saab 9000 |
While constructing the shopping list for the big turbo, I came to realization that it would be great to have a database of sorts where people with the tunes 9000s would basically fill out the info on what exactly they did, what they are happy with and what they are not. First I think this would be great for people who just got a 9000 and want to tune it. Second it is great for all other tuners because this way you actually know WHAT works. And I think this can be better the sites like CarDomain because we can make it very specific. So, Ill make a form and fill it out, and anyone who thinks this is a good idea can just copy it and fill it out themselves. Feel free to add anything.
Model: Saab 9000 CSE turbo. Year: 1995 Turbo: T25 (if modified turbo with personal A/R, trim, etc, please note it) Pistons: Stock Rods: Stock Crank: Stock Block: Stock Head Bolts: Stock Head Gasket: Stock Head Valves: Stock Head work: None Valve Springs:Stock. Lifters: Stock Hydrolic. Cams: Stock. Exhaust Manifold: Stock T25. Intake tubing(like to throttle body, from filter to turbo):stock. Downpipe: JT 2.5inch Exhaust: JT 3 inch. Sports cat. Intake: Drilled air box, K&N filter element. Blow off Valve: Atmospheric Forge, Yellow spring. Wategate/WG actuator: Forge, Green spring. In the turbine housing. Intercooler: ETS Front Mount Intercooler. ECU tune: Maptun Stage 3 Tune. MAP sensr: Stock. Boost Control: Stock APC valve. Turbo Pressure: 17-18 psi. Torque mount bushings: both poly. Bottom mounts: solid rubber. Oil: Mobile 1 15W-50 Full Synth(for summer) Fuel Pump: Stock. Fuel injectors: Stock. Fuel Rail and Lines: Stock Flywheel: Lightened SPEC. Clutch: SPEC 6 puck with SPEC pressure plate. Tranmission Gearset: Stock, Ericksson rebuild. Transmission LSD: Stock. Tranny mount: Poly. Gear shift lever: Stock unmodified. Oil: Valvoline 10W-30 mineral oil. Front Brake Discs: Zimmerman cross drilled. Rear Brake Discs: Zimmerman cross drilled. Front Brake Calipers: Stock. Rear Brake Calipers: Stock. Suspension Shocks: Koni Adjustables. 1 turn from full stiff front ones, 0.5 turn from fully stiff rears. Springs: B&G Lowered springs (40mm drop from stock CSE) Strut Brace Front: none. Strut Brace Rear: none. Sway bar front: stock. Sway bar rear: stock. Bushings: all polyurethane. Wheels Brand: Stock Wheels Offset: Stock Bolt pattern: Stock Hubcentric adapters?: No Wheel Size: 15. Tires Brand: Falken Something Tires Size:205/60 R15 Other custom mods:none. Horsepower range: 230hp on gtech, add 15% for drivetrain loss+air resistance,etc about 265hp at the crank. Best mod: they all are good Worst mod: Well, the zimmermans have REALLY small cracks around the holes. THe breaking is great though. I tried to make it as comprehensive as possible. If anyone sees any holes, please fill in. Thanks, Klim
The only way to measure true happiness is in terms of boost 270hp/396ft/lb. Maptun stage 3 ECU, JT 3 inch downpipe, cat and the rest of exaust, k&n filter. Last edited by mulik51; 09-10-08 at 07:33 AM. Reason: Add info. Totally neglected the head mods. |
| Sponsored Links | ||
Advertisement | ||
Ok - Here is mine to kick off the idea. I like this specific list as you never see it exactly. I've added brake pads, lines, fluid.
Model: Saab 9000 Aero. Year: 1996 Turbo: GT3071r 0.64 Ported WG and polished Pistons: Stock Rods: Stock Crank: Stock Block: Stock Head Bolts: Stock Head Gasket: Stock Head Valves: Stock Head work: None Valve Springs:Stock. Lifters: Stock Hydraulic. Cams: Stock. ( Moving to 260 9.2 soon.) Exhaust Manifold: Tubular header (chuckBFs one). Ported out. Intake tubing: 63mm delivery pipe to throttle body Downpipe: JT 3" all the way from turbo. Custom JT. Exhaust: JT 3 inch. Metallic race cat (Dynatech powercat) Intake: ITG big foam JC60-86 3" stainless intake pipe(custom) Blow off Valve: Forge, standard spring (unknown) Wategate/WG actuator: Forge, Blue spring. 1bar base Intercooler: Allard 50mm stock shape. ECU tune: Home brew with help. MAP sensr: 3bar GM Boost Control: T7 APC Fuel pump: Walbro 255lph Injectors: Siemens Deka 630s Turbo Pressure: 24 psi peak on initial map Torque mount bushings: Bulkhead stock, Engine end Red poly. Bottom mounts: Stock Oil: Mobile 1 0W-40 Full Synth(for summer) Flywheel: Standard Clutch: Sachs standard friction plate. Sachs uprated PP Tranmission Gearset: Standard with 3.85 final drive Transmission LSD: Quaife LSD Tranny mount: Yellow poly Gear shift lever: Stock unmodified. Oil: Amsoil slickety slick. Front Brake Discs: Brembo plain standard. Rear Brake Discs: Brembo plain standard. Front Brake Calipers: Stock. Rear Brake Calipers: Stock. Front Brake pads: Ferodo DS2500 Rear Brake Pads: Ferodo DS2500 Brake Lines: Braided all round Brake fluid: RBF600 Suspension Shocks: Koni Adjustables. 1 turn from full stiff front ones, 1 turn from fully stiff rears. Springs: Abbott slightly lowered springs Strut Brace Front: Strut Brace Rear: none. Sway bar front: SAS + SAS bushes Sway bar rear: SAS + SAS bushes Bushings: Purple poly butterfly up front Wheels Brand: Stock Wheels Offset: Stock Bolt pattern: Stock Hubcentric adapters?: No Wheel Size: 16 Tires Brand: Goodyear Eagle F1 GSD3 Tires Size:205/55 R16 Other custom mods: Horns moved out of airflow, Catch can intalled, throttle body coolant loop deleted. Horsepower range: No idea. 385bhp crank? Aiming for 400ish with mild cams. Best mod: Line in for ipod. Worst mod: None. Spent too many hours checking everything. For real bhp, should have bought 264 cams instead of tubular header. Last edited by skint; 09-10-08 at 08:33 AM. |
At least somebody liked the idea
Klim
The only way to measure true happiness is in terms of boost 270hp/396ft/lb. Maptun stage 3 ECU, JT 3 inch downpipe, cat and the rest of exaust, k&n filter. |
Have updated mine with fuel pump and injectors.
Suggest that future plans are banned as anyone can make a list of goodies they want. Actually making, buying, fitting is another matter. In fact - I don't have my cams yet so they should be removed! |
Klim
Model: Saab 9000 CD Turbo
Year: 1990 Turbo: T25 Pistons: Stock Rods: Stock Crank: Stock Block: Stock Head Bolts: Stock Head Gasket: Stock Head Valves: Stock Head work: None Valve Springs:Stock. Lifters: Stock Hydrolic. Cams: Stock. Exhaust Manifold: Stock T25. Intake tubing(like to throttle body, from filter to turbo):stock. Downpipe: Stock Exhaust: Swedish 2.5" Sports Exhaust Intake: Drilled out Airbox with Stock Filter Blow off Valve: Stock Dump Valve Moved. Wategate/WG actuator: Stock Intercooler: Stock ECU tune: Stock MAP sensor: Upgraded to larger size. Boost Control: Stock APC valve. Turbo Pressure: 10-12 psi. Torque mount bushings: Stock Bottom mounts: Rubber Oil: Saab Dealership changed Fuel Pump: Stock. Fuel injectors: Stock. Fuel Rail and Lines: Stock Flywheel: Stock Clutch: Stock Tranmission Gearset: Stock, but new 70k miles ago. Transmission LSD: Stock Tranny mount: New, Rubber. Gear shift lever: New, stock. Oil: Stock Front Brake Discs: Stock Rear Brake Discs: Stock Front Brake Calipers: Stock. Rear Brake Calipers: New Stock Suspension Shocks: Stock Springs: Stock Strut Brace Front: none. Strut Brace Rear: none. Sway bar front: stock. Sway bar rear: stock. Bushings: Stock (For Now) Wheels Brand: New Stock Wheels Offset: Stock Bolt pattern: Stock Hubcentric adapters?: None Wheel Size: 16 Tires Brand: Good Year Tires Size:Not sure. Other custom mods: All new Leather seats plus other interior mods. Moved Dump Valve from near turbo up higher. Horsepower range: I'd say around 175hp, not sure though. Best mod: Even though it's not really a mod, I'd say the redo of my Interior. Worst mod: Not sure, none I'd say. As far as engine mods, I don't have much done right now as I am not rich, but I hope one day I can beef up the horsepower. I am mainly focusing on making it look as nice as it can.
AIM: hyperspaztik49 Skype: Justin.Graeff |
Model: Saab 9000 Cs Aero
Year: 1994/5 Turbo: garrett gt 3071 .86 ar Pistons: Stock Rods: shot peened and match weighted Crank: Stock balanced Block: Stock Head Bolts: Stock Head Gasket: Stock Head Valves: +1.5mm ex +1mm inlet Head work: stage 3 (race ) ported Valve Springs:80% uprated Lifters: Stock Hydraulic. Cams: 264's I think Exhaust Manifold: Maptun tubular manifold Intake tubing(like to throttle body, from filter to turbo):3 " yleee pipe Downpipe: maptun 3" Exhaust: custom 3" SS Intake: 4" with ITG MC60 Blow off Valve: synchronic Wategate/WG actuator: Stock Intercooler: Mapun 50 mm ECU tune: Stage 7+ custom tune maptun MAP sensor: 3 bar map Boost Control: Stock APC valve. Turbo Pressure: 1.9 bar Torque mount bushings: Poly Bottom mounts: solid Oil: royal purple 0/20 Fuel Pump: bigger walbro I believe ..came with the maptun stage 6 kit Fuel injectors: 630cc Fuel Rail and Lines: Stock Flywheel: lightened 20% Clutch: Sachs uprated pressure plate Tranmission Gearset: Maptun 6 speed with 4.05 FD Transmission LSD: quaife LSD Tranny mount: poly Gear shift lever: stock. Oil: royal purple synchromax Front Brake Discs: Ap 330 mm discs Rear Brake Discs: Stock Front Brake Calipers: AP 4 pots. Rear Brake Calipers: Stock Suspension Shocks: Koni adjustable ,almost full soft at the front and almost full hard at the back Springs:Rok Strut Brace Front: chrome Strut Brace Rear: none. Sway bar front: stock. Sway bar rear:sas 1" Bushings: Stock Poly Wheels Brand: team dynamics pro race 1.2 Wheels Offset: 25 mm Bolt pattern: Stock Hubcentric adapters?: None Wheel Size: 17 Tires Brand: toyo t1r Tires Size:235 40 zr 17 Other custom mods:custom turbo outlet pipe Horsepower range: 485 hp last dyno (maybe a touch more with the outlet pipe mod Best mod: tubular manifold next mod torque control arm on rhs of engine to help torque twist
9000 aero stg 7 266k miles 500 hp six speed ! 9000 cs 2.0 stage 6 350 hp track slag 900 t16s classic 184k 9-3ss 2009 turboX sportwagon 69,000 miles Last edited by ylee coyote; 11-10-08 at 05:13 AM. |
Year: 1997 Turbo: SAABflight TD04 hybrid Pistons: Stock Rods: stock Crank: Stock Block: Stock Head Bolts: Stock Head Gasket: Stock Head Valves: std Head work: std Valve Springs:std Lifters: std Cams: std Exhaust Manifold: std Intake: TIG filter to std inlet to home made 2 1/2" inlet to throttle Downpipe: JT almost 3" but not quite Exhaust: Hirsch SS almost 3" but not quite Intake: open airbox Blow off Valve: forge Wategate/WG actuator: collins 31 ( better than forge) Intercooler: just intercooler 3" thick universal, it works ECU tune: originally saabflight adapted now via T5 suite MAP sensor: 3 bar map Boost Control: Stock APC valve. Turbo Pressure: 1.6 bar Torque mount bushings: Poly Bottom mounts: std Oil: anything synthetic and regularily changed, kinda like millers Fuel Pump: bigger e-bay special, as good as walbro half the price Fuel injectors: 418cc at moment but 630cc ready to go in Fuel Rail and Lines: Stock Flywheel: std Clutch: spec stage 2+ Tranmission Gearset: 3.61 today 4.05 tommorrow as and when the syncho,s go Transmission LSD: not yet but now have one Tranny mount: poly Gear shift lever: stock. Oil: millers Front Brake Discs: Brembo 325mm Rear Brake Discs: Stock Front Brake Calipers: Brembo 4 pot Rear Brake Calipers: Stock Suspension Shocks: sometimes Bilstien sprintline, sometimes koni Springs:kiliens at moment - SAS rear spring poly spacers fitted, helps a bit on comfort and shifts a bit of weight fwd for traction Strut Brace Front: chrome Strut Brace Rear: none. Sway bar front: SAS 1" Sway bar rear:sas 1" Bushings: Stock Poly Wheels Brand: team dynamics Wheels Offset: 25 mm Bolt pattern: Stock Hubcentric adapters?: None Wheel Size: 17 Tires Brand: goodyearF1 typically, or toyo snowproxy Tires Size:215 45 zr 17 Other custom mods: custom centre grill inlet mod. where No. plate used to be = improved airflow to IC air temp sensor now reading inlet air temp sensor ( allows indication of IC and turbo boost efficiency) knock LED, love this one, gives a blink on start up and the odd blink when i,m going daft, good combustion safety check indicator. JAW wide band decoder - cheap and cheerfull but a bit sensative wide band lambda fitted into downpipe next to the flexy Catch tank engine breather remove throttle body hot water circ. and heater plate Horsepower range: 350 crank last dyno, target is 370 Best mod: harmonising the bits you have, T5suite has got to be the best development to enable this, but overall its the engine, built like a brick **** house next mod fit LSD, 3" TIG inlet and allards IC,
you don,t need eye's to see, you need vision |
Model: Saab 9000 2.3 CSE Auto Turbo
Year: 1992 Turbo: T25 hybrid 360 deg bearing, unknown specs Pistons: Stock Rods: Stock Crank: Stock Block: Stock Head Bolts: Stock Head Gasket: Stock Head Valves: Stock Head work: None Valve Springs:Stock. Lifters: Stock Hydrolic. Cams: Stock. Exhaust Manifold: Stock T25. Intake tubing: 3'' Downpipe: Stock Exhaust: Custom freeflow, de-cat pipe, cherry bomb center box, kakimoto SS backbox from Mitsubishi Evo VIII Intake: HKS Mushroom SPF Blow off Valve: Forge standard Wategate/WG actuator: Forge with 14-18PSI spring, think is blue Intercooler: Stock ECU tune: Abbott racing fuel and DI upgrade MAP sensor: stock Boost Control: HKS EVC Turbo Pressure: 14 - 25 psi Torque mount bushings: Poly Bottom mounts: Poly Oil: Indy Fuel Pump: Stock. Fuel injectors: Stock Fuel Rail and Lines: Stock Transmission type: auto gearbox Front Brake Discs: Zimmerman X-drilled stock size Rear Brake Discs: Zimmerman X-drilled stock size Front Brake Calipers: Stock Rear Brake Calipers: Stock Suspension Shocks: New O.E. Saab Aero hnadling package Springs: as above Strut Brace Front: none. Strut Brace Rear: none. Sway bar front: stock. Sway bar rear: stock. Bushings: Polybush all round Wheels Brand: League 037 Wheels Offset: ET40 with 10mm Wolfrace hubcentric spacer f+r Bolt pattern: Stock 4 x 108 Wheel Size: 17'' Tires Brand: Fronts - Fulda Carat Exelero Rears - Michelin Pilot Primacy Tires Size: Front - 215/45/17 Rear - 225/45/17 Other custom mods: Mitsubishi Evo 8/9 roof tip aero fins. HKS turbo timer. HKS 60mm BAR boost gauge dash top moutned. Mocal 52mm lb/square and 52mm BAR gauges A pillar mounted. Later spec elec window switch array. US license plate frames f+r. Mesh front grill. HID kit. Chrome bulbs in clear front indicators. LED bulbs in smoked side repeaters. Earthing kit. Stealth police lights. 260mm Momo mahogany steering wheel. 82 deg thermostat. Horsepower range: Was rolling roaded at 1.2 BAR with original standard t25, de-cat pipe, standard exhaust, HKS SPF filter, standard ecu chips;257 bhp. Now with Abbott chips, 1.5 BAR, full freeflow exhaust, I'd hazard a guess at 270+. Wheelspins at 80mph+ if too much throttle. And it's an auto. Best mod: getting the ecu sorted. Worst mod: Stealth police lights. Last edited by UK9K; 20-10-08 at 08:20 PM. Reason: Typos |
Year: 1995 Turbo: Holset HX35w w/16cm internally gated exhaust side Pistons: Stock Rods: stock Crank: Stock Block: Dirty...and Stock Head Bolts: Stock, new style Head Gasket: Stock Head Valves: Stock Head work: Stock Valve Springs: Stock Lifters: Stock Cams: Stock Exhaust Manifold: old 9000 T3 style with 1" spacer between discharge and the turbo (otherwise the compressor hits the manifold Intake: 2.75" Aluminum tubing from IC to TB, Silicone couplers and T-bolt clamps as well Downpipe: 3" made by me Exhaust: 3" made by me - one stainless muffler in the rear Intake: K&N drop in w/ holes in the airbox Blow off Valve: Forge 001 Wategate/WG actuator: Internally gated turbo, Holset 19psi actuator Intercooler: CX Racing (china made), big bar and plate core, 3" deep, other dimensions about the same as stock. ECU tune: Custom mapped with T5 Suite MAP sensor: Stock Boost Control: Currently running base boost, but I'm wired up for T7 BPC valve Turbo Pressure: 19psi (1.3 bar) at the moment (base boost) Torque mount bushings: Poly Bottom mounts: Stock - probably failed Oil: Shell Rotella T 15w-40, changed often! Fuel Pump: Walbro 255, type 341 Fuel injectors: 630cc Siemens Dekka Fuel Rail and Lines: Stock Flywheel: std Clutch: spec stage 2 Transmission Gearset: Not currently broken...and stock Transmission LSD: Mmmmmmmm, nope Tranny mount: poly Gear shift lever: rattles a bit - its stock Oil: Penzoil Synchromesh Front Brake Discs: Brembo, stock size, blank face Rear Brake Discs: Stock Front Brake Calipers: Stock Ate garbage w/ EBC Redstuff pads Rear Brake Calipers: Stock Ate garbage w/ Axxiss Ceramic pads Suspension Shocks: Bilstein HD Springs: Jamex Strut Brace Front: none Strut Brace Rear: none Sway bar front: Ssssssssssssstock Sway bar rear: Stock Bushings: Poly Wheels Brand: Stock SuperAero or Ronal ???s Wheels Offset: Hmmm, have to check! Bolt pattern: 4x108 Hubcentric adapters?: Hubcentric spacers needed for the ronals Wheel Size: 16 Tires Brand: Dunlop Dizezza Dz101 and Falken Azenis 615 Tires Size:225/50 16 and 215/45 16 respectively Other custom mods: Not a whole lot. Schroth 4pt harness, a bunch of DOM steel tubing for a nicer harness bar and rear chassis bracing. Removed all AC components, removed all sound deadening + rear seat. Also an Innovate wideband to be sure I'm not leaning things out too much! Horsepower range: was 270whp and 320lb.ft (at the wheels) before the big turbo and injectors were installed. I'd assume it's well over 300whp now. Very fast up top, not as fast down low. Best mod: (Also the worst) is the big turbo. Its really fun, and out of hand, but at the circuit track I don't think its as usable as the smaller TD04 I had before. next mod: More tuning, getting the T7 boost control valve 100% functional and adding more boost to the equasion! After that, I'll need to think outside the box better brake and suspension solutions. Also, after having driven a very lightweight 9000 I think I'll scrap a bit more of the interior and lighten things up about as much as possible.
2001 325XiT - slow / 1995 9000 Aero - 426whp / 1999 9-3 - stage 3 / 1973 99LE 1994 900 V6 - Team Cougar Bait - 24 Hours of Lemons |
Model: Saab 9000 aero
Year: 1993/4 (private plate so uncertain. LOL) Turbo: TD04 Pistons: Stock Rods: Stock Crank: Stock Block: Stock Head Bolts: Stock Head Gasket: Stock Head Valves: Stock Head work: None Valve Springs:Stock. Lifters: Stock Hydrolic. Cams: Stock. Exhaust Manifold: Stock Intake tubing(like to throttle body, from filter to turbo):stock. Downpipe: Stock. Custom 3" pipe under way... Exhaust: de-cat, rear box replaced with 2.5" pipe Intake: Pipercross induction into inner wing. Blow off Valve: Play between Forge and very tired Bailey (vents really easily and sounds awesome!) . Wategate/WG actuator: Forge Intercooler: Stock ECU tune: Running T5 suite stage 3 (in readiness for downpipe) MAP sensor: stock.Boost Control: Stock APC valve. Turbo Pressure: 1.3-1.4 bar. Torque mount bushings: Stock Bottom mounts: Rubber Oil: Semi synthetic Valvoline top of the shop stuff Fuel Pump: Stock. Fuel injectors: Stock. Fuel Rail and Lines: Stock Flywheel: Stock Clutch: Replaced with stock Saab unit Tranmission Gearset: StockTransmission LSD: Stock Tranny mount: Stock Gear shift lever: stock. Oil: Stock Front Brake Discs: Stock Rear Brake Discs: Stock Front Brake Calipers: Stock. Rear Brake Calipers: Stock Suspension Shocks: Koni adjustables (modified rears) Springs: Hirsch (firm and low) Strut Brace Front: none. Strut Brace Rear: none. Sway bar front: stock. Sway bar rear: Piggy back Bushings: Stock Wheels Brand: Move between 16" carlsson, 16" super aero and 17" Milano Wheels Offset: 17" run at et35 Bolt pattern: Stock Hubcentric adapters?: None Wheel Size: 16" /17" Tires Brand: Michelin pilot sport and Dunlop sp9000 Tires Size:205 55 16 215 50 17 Other custom mods: Subtle smoke on all lamps, tinted windows all round, copying Normans's moving of air temp sensor into intake, intake and DI painted in matt hi temp red paint, after market 2 bar boost gauge,saggy sunroof liner,... Horsepower range: Dyno power run (in May) at 254bhp Best mod: Second hand suspension package. Its low, mean and handles well! Worst mod: Anything I break when trying, what I foolishly think will be, " a good idea" ... Oh, and the 6" flexible ducting for the filter. A bargain from BnQ. Crushed it every time I parked nose into a kerb! The future - play around with intercooler, 3" downpipe under construction, chase 300bhp!! May look longer term into non-turbo gearbox for closer ratios... Til then - Just keep enjoying thw Saab
I can't edit, so I'll just update with this post.
I got 426hp and 429lb.ft at the dyno on 11/1/08. Quite a bit more than I had expected!
yeah i saw that the other day on TSL, great stuff man, your car is awesome
Model: Saab 9000 Turbo
Year: 1991 Turbo: Td04-15t-6cm2 Pistons: Stock Rods: Stock Crank: Stock Block: Stock Head Bolts: Stock Head Gasket: Stock Head Valves: Stock Head work: None Valve Springs:Stock. Lifters: Stock Hydrolic. Cams: Stock intake, 85 900T exaust cam Exhaust Manifold: Stock Intake tubing:stock Downpipe: JT 3inch Exhaust: Custom made 3 inch (by me) with magnaflow racecat and muffler Intake: K&N cone filter Blow off Valve: stock 9-5 BPV Wategate/WG actuator: Spring added for 10PSI base boost Intercooler: stock ECU tune: SD red series APC and LH fuel EPROM MAP sensor: Boost Control: Stock APC valve. Turbo Pressure: 22PSI (spikes 28PSI) Torque mount bushings: Stock Bottom mounts: solid rubber. Oil:Napa 10w-30 Fuel Pump: Stock. Fuel injectors: Redtops from a T5 9k Fuel Rail and Lines: Stainless fuel rail Flywheel: Stock Clutch: stock needs upgrade Tranmission Gearset: Stock 4:45 final drive NA gearbox Transmission LSD: Stock Tranny mount: stock Gear shift lever: Cutdown unit from a 97 9k AERO is being removed and replaced with stock Oil: Napa Sythetic Front Brake Discs: Stock Rear Brake Discs: Stock Front Brake Calipers: Stock. Rear Brake Calipers: Stock. Suspension Shocks: Springs: Aero suspension. Intrax have been removed Strut Brace Front: none. Strut Brace Rear: none. Sway bar front: SAS 1 inch Sway bar rear: SAS 1 inch Bushings: Stock Wheels Brand: Stock Wheels Offset: Stock Bolt pattern: Stock Hubcentric adapters?: No Wheel Size: 16 Tires Brand: BFgoodrich somethings Tires Size:205/50/16 Other custom mods: Full Aero interior Swap. Horsepower range: 290bhp Best mod: Interior is really nice and comfy Worst mod: the shortened shifter Thats about it |
Model: Saab 9000 CS Turbo
Year: 1995 Turbo: GIK GT28BB Pistons: Stock Rods: Stock Crank: Stock Block: Stock Head Bolts: Stock Head Gasket: Stock Head Valves: Stock Head work: None Valve Springs:Stock. Lifters: Stock Hydrolic. Cams: Stock. Exhaust Manifold: Stock T25. Intake tubing: 2.5'' deliverypipe. Downpipe: 3'' BSR Exhaust: 2.5" BSR Intake: Open airfilter Blow off Valve: Forge. Wategate/WG actuator: Upgraded, 0.8 bar Intercooler: Abbott ECU tune: T5Suite Custom tune stage V MAP sensor: 3 bar. Boost Control: Trionic 7 valve. Turbo Pressure: 25 psi. Torque mount bushings: Stock Bottom mounts: Hydrolic Oil: synthetic Fuel Pump: Stock. Fuel injectors: Bosch green giants. Fuel Rail and Lines: Stock Flywheel: Lightened Clutch: Abbott pressure plate Tranmission Gearset: Stock. Transmission LSD: Stock Tranny mount: Stock Gear shift lever: Stock Oil: Stock Front Brake Discs: Stock Rear Brake Discs: Stock Front Brake Calipers: Stock Rear Brake Calipers: Stock Suspension Shocks: Stock Springs: Stock Strut Brace Front: none. Strut Brace Rear: none. Sway bar front: stock. Sway bar rear: stock. Bushings: Rear arm bushing powerflex Wheels Brand: Brio 17'' Wheels Offset: Stock Bolt pattern: Stock Hubcentric adapters: None Wheel Size: 17 Tires Brand: Pirelli zero nero Tires Size: 215x45x17'' Other custom mods: Aero interior. CarPC with digital dashboard running through CANBus interface. Mods to come: Wideband O2 with (hopefully) autotune function. Mods condsidered: Holset turbo. 630/750cc injectors. Horsepower range: 350bhp, 580Nm. Best mod: Digital dashboard Worst mod: Lowering springs, undone.
Trionic suites website |
Model: Saab 9000 Aero (manual, non-TCS)
Year: 1994 Turbo: TD04-15T Pistons: Stock Rods: Stock Crank: Stock Block: Stock Head Bolts: Stock Head Gasket: Stock Head Valves: Stock Head work: None Valve Springs:Stock Lifters: Stock Cams: Stock Exhaust Manifold: Stock Intake tubing: Stock Downpipe: 3'' JT Exhaust: 3" JT, de-catted Intake: ITG filter, open airbox Blow off Valve: Stock Wategate/WG actuator: Stock Intercooler: Stock ECU tune: T5 Suite stage 3 MAP sensor: Stock Boost Control: Stock APC valve Turbo Pressure: 1.4-1.45 BAR Torque mount bushings: Poly Bottom mounts: Stock hydraulic (new OE) Oil: Indy Fuel Pump: Stock (new OE) Fuel injectors: Stock Fuel Rail and Lines: Stock Flywheel: Stock Clutch: Stock Tranmission Gearset: Stock. Transmission LSD: Stock Tranny mount: Stock Gear shift lever: Stock Oil: Stock Front Brake Discs: Black Diamond grooved/drilled Rear Brake Discs: Stock (new OE) Front Brake Calipers: Stock Rear Brake Calipers: Stock Front brake pads: Black Diamond Predator Rear brake pads: Genuine Saab (new) Brake lines: Stock Brake fluid: Indy Suspension Shocks: Stock Springs: Stock Strut Brace Front: None Strut Brace Rear: None Sway bar front: Stock Sway bar rear: Stock Bushings: Stock Wheels Brand: Smith's Wheels, 17" Wheels Offset: ET38 Bolt pattern: Stock Hubcentric adapters: None Wheel Size: 17 Tires Brand: Bridgestone Potenza RE050A front, Avon ZZ3 rear Tires Size: 215/45/17 front, 225/45/17 rear Other mods: HKS 60mm boost gauge, Fusion CA-IP500 ipod headunit, Pioneer TS-E series speakers front and rear, screen mounted aerial, late spec steering wheel/electric window switch pack, silicone hoses Mods to come: Poly transmission/torque arm bushes (already got upper engine ones done), Goodridge brakelines, de-badging, Forge dump valve, front strut brace Horsepower range: Car's never seen a dyno in my ownership, but I'd hazard a guess at 270-280bhp Best mod: Boost gauge. Deeply cool Worst mod: Poly upper engine mounts-didn't realise the work involved getting them in and ended up costing me an arm and a leg getting them fitted |
Year: 1997 Turbo: Stock TD04 Pistons: Stock Rods: stock Crank: Stock Block: Stock Head Bolts: Stock Head Gasket: Stock Head Valves: Stock Head work: Stock Valve Springs: Stock Lifters: Stock Cams: Stock Exhaust Manifold: Stock Intake: Stock Downpipe: Stock Exhaust: Stock (one of the stock mufflers blew out all its stuffing on the dyno on 8/1/09, now it sounds a bit more raspy) Intake: Stock w/drilled-out airbox Bypass Valve: Forge FMCL007PA Wategate/WG actuator: Stock Intercooler: Stock ECU tune: T5 Suite stage 2 MAP sensor: Stock Boost Control: Stock Turbo Pressure: 18psi max (showed 17.x psi on dyno... hot day) Torque mount bushings: Poly Bottom mounts: Stock, also probably dead Oil: Valvoline 5w-30... time for a change. Fuel Pump: Walbro, OEM model Fuel injectors: Stock Fuel Rail and Lines: Stock Flywheel: Stock (resurfaced during clutch job) Clutch: Spec stage 2 Transmission Gearset: Stock Transmission LSD: None Tranny mount: Stock Gear shift lever: Stock Oil: ??? Probably time for a change. Front Brake Discs: Stock Rear Brake Discs: Stock Front Brake Calipers: Stock Rear Brake Calipers: Stock Suspension Shocks: Stock Springs: Stock Strut Brace Front: None Strut Brace Rear: None Sway bar front: Stock Sway bar rear: Stock Bushings: Stock (time for an upgrade) Wheels Brand: Stock SuperAero Wheels Offset: OEM Bolt pattern: 4x108 Hubcentric adapters?: None... ? Wheel Size: 16 Tires Brand: Bridgestone something or other. Tires Size: OEM Other custom mods: broken seat adjustment gear Horsepower range: Dyno'd at the wheels with 227hp/293tq. Best mod: Finally waxed the car. Now it looks like a shiny faded red turd. next mod: 3" DP, then full 3" exhaust, then T5 Suite stage 3 tune, and possibly better IC. Tires in the spring, then focus on the suspension, bushings, etc. Probably leave it at engine stage 3 and enjoy. __________________
*SAABCentral NEW ENGLAND CREW Member 008* (now in NC) T5Suite2.0 Stage 3+, Full DIY 3" exhaust w/Magnaflow, Spec stage 2+ clutch, "Custom" airbox mod, Forge BPV, DIY strut brace, Poly bushings, various powder-coated goodies |
Model: Saab 9000 Airflow.
Year: 1990 Turbo: HX40 Super #16 Pistons: Stock Rods: Stock Crank: Stock Block: Stock Head Bolts: Stock Head Gasket: Stock Head Valves: Stock Head work: None Valve Springs:Stock. Lifters: Stock Hydraulic Cams: Stock Exhaust Manifold: Tubular header. Intake tubing: stock Exhaust: 3" JT turboback, small mods. Intake: stock Blow off Valve: None Wategate/WG actuator: 50mm HKS replica Intercooler: Some chinese cheap 600x300x76mm ECU tune: custom tune by Hook and Seb from ecuproject MAP sensor: 4bar VEMS Boost Control: T5 APC Fuel pump: Walbro 255lph Injectors: 850 cc/min Turbo Pressure: 2 bar / 29 PSI Torque mount bushings: Powerflex Bottom mounts: Stock Oil: Flywheel: stock lightened (very much) Clutch: modded stock with dual springs Tranmission Gearset: Standard with 4.45 final drive, OMG how slow it is Transmission LSD: None Tranny mount: Powerflex Gear shift lever: modded stock. Oil: Who the hell knows whats inside there. Front Brake Discs: Stock. Rear Brake Discs: Stock. Front Brake Calipers: Stock. Rear Brake Calipers: Stock. Front Brake pads: Stock Rear Brake Pads: Stock Brake Lines: Stock Brake fluid: dot4 Suspension Shocks: Koni yellow adjustables Springs: H&R 40mm lowering Strut Brace Front: none Strut Brace Rear: none. Sway bar front: stock Sway bar rear: stock Bushings: stock Wheels Brand: TSW Hockenheim R Wheels Offset: I don't remember Bolt pattern: Stock Hubcentric adapters?: Rear 28 mm Wheel Size: 16 Tires Brand: Cheap Tires Size: 225/50 R16 Other custom mods: Horn moved out of airflow, throttle body coolant loop deleted. Small bodywork in front to fit intercooler. Horsepower range: No idea Best mod: Full Talladega kit: plastics, rear wing, seats and steering wheel. Worst mod: Mostly everything I do |
Updated.....
Model: Saab 9000 Cs Aero Year: 1994/5 Turbo: garrett gt 3071 .86 ar Pistons: Wossner Rods: Verdi Crank: Stock balanced Block: Stock Head Bolts: Stock Head Gasket: Stock Head Valves: +1.5mm ex +1mm inlet Head work: stage 3 (race ) ported 3 angle valve Valve Springs:80% uprated Lifters: Stock Hydraulic. Cams: 264's I think Exhaust Manifold: Maptun tubular manifold Intake tubing(like to throttle body, from filter to turbo):3 " yleee pipe N/a intake manifold Downpipe: maptun 3" Exhaust: custom 3" SS Intake: 4" with ITG MC60 Blow off Valve: synchronic Wategate/WG actuator: Stock Intercooler: Mapun 50 mm ECU tune: Stage 7+ custom tune maptun MAP sensor: 3 bar map Boost Control: Stock APC valve. Turbo Pressure: 1.9 bar Torque mount bushings: Poly Bottom mounts: solid Oil: royal purple 0/20 Fuel Pump: bigger walbro I believe ..came with the maptun stage 6 kit Fuel injectors: 630cc Fuel Rail and Lines: Stock Flywheel: lightened 20% Clutch: Specs 3+ Tranmission Gearset: Maptun 6 speed with 4.05 FD Transmission LSD: quaife LSD Tranny mount: poly Gear shift lever: stock.with Genuine Saab Quickshift Oil: royal purple synchromax Front Brake Discs: Ap 330 mm discs Rear Brake Discs: Stock Front Brake Calipers: AP 4 pots. Rear Brake Calipers: Stock Suspension Shocks: Koni adjustable ,almost full soft at the front and almost full hard at the back+airbag supplemental springs Springs:Rok Strut Brace Front: chrome Strut Brace Rear: abbott one piece Sway bar front: stock. Sway bar rear:sas 1" Bushings: Stock Poly Wheels Brand: Team Dynamics pro race 1.2 Wheels Offset: 25 mm Bolt pattern: Stock Hubcentric adapters?: None Wheel Size: 17 Tires Brand: toyo t1r/r888 for trackdays Tires Size:235 40 zr 17 Other custom mods:custom turbo outlet pipe Horsepower range: 485 hp last dyno (maybe a touch more with the outlet pipe mod Best mod: tubular manifold next mod Quick steering rack
9000 aero stg 7 266k miles 500 hp six speed ! 9000 cs 2.0 stage 6 350 hp track slag 900 t16s classic 184k 9-3ss 2009 turboX sportwagon 69,000 miles |
Where can I get the following:
Shocks: Koni Adjustables. Springs: B&G Lowered springs And how does your drilled airbox with K&N work for you? From what I heard, open filter is better... What do you think? |
| Sponsored Links | |
Advertisement | |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
