'Check Gear Box' Light - Almost every morning...Always when - SaabCentral Forums
Old 2nd March 2002
Saab900s-PGH Saab900s-PGH is offline
New Member
95 Sabb 900S - I turn the car off and start again,sometimes 2 or 3 times and then it works fine. I changed the Transmission fluid - no change. The parts guy says that there is no filter in this automatic transmission.
Any ideas?
Thanks in advance for any help!!!!
patrick_mchugh_pgh@yahoo.com
Old 6th April 2002
kevinkis kevinkis is offline
Check Gear Box light on with 1995 900 SE conv that I bought used just yesterday. It wasnt on after I picked up and drove the car from the dealer yesterday, but now its on whenever I used the car today. Any odeas as to what's up?
Old 15th April 2002
I had a Saab mechanic (on his own now in NY) check out the "Check Gear Box" lite problem, which also put the car into winter mode (limp home mode). It went away after the car was warm, but he tested it with the Tech 2 tool which confirmed that a "auto safety switch (or something like that) needed to be replaced. The used Saab dealer (Delafield Motors in Schenectady, NY) that I bought the car from that same week paid the $300+ for the work and for the part, whcih I bet was over $100. It's hard to get to, under the battery and under some steel framing on the right hand side. Works fine now.
Old 5th July 2002
Matt900Cab Matt900Cab is offline
New Member
I had a similar problem on my 900s Cab. It is apparently the range switch for the gearbox which controls the gear changes, when it is stuffed it puts the car in limp mode. It also caused my car to shudder a bit while stationary and in gear ( especially with the aircon on) feeling like it wanted to change gears. The switch can be cleaned and regreased as a possible fix but you might as well replace the switch. Did this with mine and the car runs great now.
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
