How to get Wax off my black plastic trim? Nothing works! - SaabCentral Forums
Old 20th September 2008
Nickshu's Avatar
Nickshu Nickshu is offline
My Saabs: 07 9-3 SportCombi 60th Anniversary
Default How to get Wax off my black plastic trim? Nothing works!
I've tried Peanut Oil and Peanut Butter, but I can't seem to get the white wax stains off the black door and bumper trim on my 9-3. Any other tricks out there that work??? Peanut oil has always worked for me on other cars, but for some reason on the 9-3 it doesn't work.
Nick -- Saab-less for the first time since 1991.
Current cars: '13 Volvo C70 retractable hardtop; '13 Subaru Outback 3.6R SAP; '64 Corvair Monza Spyder (factory turbo) Convertible
Prior Saabs: 86 9000T, 91 9000CD, 93 900S, 95 900S, 07 9-3 SportCombi 60th Anniv Edition
KrOlDoG8's Avatar
KrOlDoG8 KrOlDoG8 is offline
My Saabs: '03 9-3SS (Linear)
I have gone the traditional route and had no real results either. I've tried WaxBlaster, Back to Black, and some other treatment from Mothers with no luck and I cant understand why.
Anyone, any good ideas??
zippyluvssaab's Avatar
zippyluvssaab zippyluvssaab is offline
My Saabs: Black 2008 9-3 2.0T Aero
I used a product called Trim Shine by Stoner. It seems to be working okay but its raining today so I am gonna see if it ends up running down the side of my car or not. Mothers Back to Black does run down the side of the car after a single shot of rain and, in my experience, useless.
Heres a link http://www.trimshine.com/
zippy
PS I didnt just spray and walk away though, I gave the trim a good buffing with a clean microfibre cloth.
Diggs's Avatar
Diggs Diggs is offline
My Saabs: 2003 9³SS Linear
Creamy peanut butter
The answer is almost always....Tech2
sbl sbl is offline
My Saabs: Formerly, 2003 Saab 9-3 Arc
Griot's Garage Dried-on Wax Remover
Works pretty well. But peanut butter should work too.
SidewaysD's Avatar
SidewaysD SidewaysD is offline
My Saabs: 03 Saab 9-3 Turbo, and 89 Saab 9000
Chuncky peanut butter is better, Natrual Scrubbers.
>>Pat<<
Abarth's Avatar
Abarth Abarth is offline
My Saabs: na
Organic always! of Goober.....
Nickshu's Avatar
Read original post. Tried it. Didn't work....strange plastic they used on these cars. Wax I used was Maguiar's Cleaner/Wax liquid put on with my orbital buffer.
AlbertaDrew's Avatar
AlbertaDrew AlbertaDrew is offline
My Saabs: 06 2.0T STG 1 (SOLD) - 88 Vert Project
Back to Black
tsksaab's Avatar
tsksaab tsksaab is offline
My Saabs: '89 900 S
Polymer or plastic eraser. Also works well on rubber trim.
epsilon93 epsilon93 is offline
My Saabs: '07 9-3SC 2.0T
Try peanut butter oil with an old toothbrush. Those fine bristle ones will work better. The wax is stuck in the pores of the plastic textures.
robhurlburt's Avatar
robhurlburt robhurlburt is offline
My Saabs: 2003 9-3t (OOW)
black wow???
Old 21st September 2008
cavedudejeff's Avatar
cavedudejeff cavedudejeff is offline
My Saabs: 2005 9-3SS Linear
get wax off of your black door trim...?
THATS EASY!
swap your plastic trim with some poor suckers down the block...
You can always take it off (it pops off) soak it in hot water and then do the peanut butter and brush thingie
titeness titeness is offline
My Saabs: 2004 9^3 SS
Peanut Oil would have a high molecular weight, try Isopropyl Alcohol.
brunp's Avatar
brunp brunp is offline
My Saabs: none
Interesting that the Peanut Oil method worked when I had my '04 Linear. Mind you.....shortly thereafter, I installed the AERO kit, so I do not know how long that would have lasted.
Current Car(s): 2006 BMW 325i, 1998 BMW 328is
Past Cars:
2007 Saab 9-3ss AERO
2004 Saab 9-3ss Linear
2003 PT Cruiser
2001 Volvo S40
1990 Honda Accord EX-R
mrbrett's Avatar
mrbrett mrbrett is offline
My Saabs: '06 9 3 2.0T
A pink school eraser will take the white marks off the trim, then use a soft brush to dust off the eraser derbris.
JAGMAN JAGMAN is offline
My Saabs: 2007 9-3 Aero
Mr. Clean Magic Eraser is the answer. It works with almost no effort. Don't wet the sponge, just use it dry.
There is nothing else that works well, I've tried everything.
Magic Eraser! It is the tool of choice amongst detailing forums. Besides, the point is to clean off the trim, not put peanut butter on it...
Nickshu's Avatar
Thanks for the tips. I was able to get it cleaned off today. I started with the MagicEraser (thanks for the tip JAGMAN) which removed the wax, but left a whitish haze on all the black trim. I then followed up with creamy peanut butter and scrubbed it in with a toothbrush, let it set for 15-20 minutes, then washed the car to get it all off. After I washed the car I scrubbed again with a light coating of peanut oil on a toothbrush, then cleaned it with a damp cloth. Looks good finally!!!
Thanks!
Acidradio's Avatar
Acidradio Acidradio is offline
My Saabs: 2004 9³ Arc
How do you take it off? Can you just yank it off? I'd like to take the trim off my car but I've never tried just taking it off because I don't want to risk breaking it.
I loved the airplane so much, I had to buy their car!
Old 27th July 2009
verso's Avatar
verso verso is offline
My Saabs: 2005 9-3 Arc
Is the MagicEraser followed by peanut butter still the best way to remove wax from the trim?
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
