Great a few problems (Throttle position sensor code P2135) - SaabCentral Forums
Old 19th September 2008
Interceptor's Avatar
Interceptor Interceptor is offline
My Saabs: 97 9k Aero
Default Great a few problems (Throttle position sensor code P2135)
Okay started after my car wash. Not sure if that has anything to do with it. Engine light comes on, then on the free way my cruise is not working. Get off the freeway and the sob is in limp mode up until around 30 mph. Man, I like my Saab but damn it, 55k on it. I will get the code read here in a bit but this does not sound good.
robhurlburt's Avatar
robhurlburt robhurlburt is offline
My Saabs: 2003 9-3t (OOW)
did you wash the engine bay?
Nope....@#$@# car..Sorry not too happy at this moment. I have really bad luck and this was not a good time for me.
Ugh, the OBD II is reading error. C'mon....
Gomo187's Avatar
Gomo187 Gomo187 is offline
My Saabs: 2006 9-3 Aero BSR Stage 2
If youve got an intake it may have accidentally breathed in enough water to mess with the MAF. Happened to me on a previous car.
Svenska Aeroplan Aktie Bologet
Its dry, I went through the auto wash as usual. Not sure still if that is whats causing things.
Did a battery unhook for 30 minutes and the car is fine. Light is off limp is gone and cruise works. Wow I was sweating bullets. Hmmm Good song. Darn Saab gremlins.
Old 20th September 2008
Loki's Avatar
Loki Loki is offline
My Saabs: 06 9-3 Aero
Dave Mustaine seems like he'd be a Saab guy.
I don't know he is a little uptight I think, maybe a benz owner?
Kandiru's Avatar
Kandiru Kandiru is offline
My Saabs: 2008 Turbo X Sedan 6-Speed Navi
Get a little Actron pocket OBD2 port scanner, it will show you the code, then you could look it up on the web.
http://cgi.ebay.co.uk/ACTRON-OBD-II-...3286.m20.l1116
Also, ebay has a truckload of WIS up to 2007 TechII DVDs. All you need is a USB to OBD2 cable and you are ready to diagnose.
http://cgi.ebay.com/ebaymotors/Saab-...mZ220281055917
I don't dare do TechII mods on my 2008 car, but the 2007 data apply very well to my car, so i was able to remove trims, fix a door squeak with ease. The pictures are great, makes work on the car a breeze.
Love WIS, a very nice interface, much better than the Volvo web based interface with 10 passwords, that cost $15 for 3 days of use.
UltimatePedals, USASpec PA-20GM iPod/Connects2-BTAV1, Llumar ATR15 tint rear, H&R spacers, Borbet-XL/Dunlop M3 18x8" winters, SAAB Euro Badge, Ital black frames, TurboX watch and driving gloves...Dart Vader's own anyday now
Ok, the problem is back. I reset the battery again and its off but it happened at a standstill. So your saying a standard OBD II will not work? I will have to head to Autozone I guess.
P2135 code. TPS pedal switch....Hmmm.....
throttle positioning sensor????
Did you hand in your TPS reports?
Lmao...ahhh the best movie. Pffttt, not right now I have a meeting with the bobs. Man I need some of the vets on here to help. Do I need the TPS switch or a pedal tps switch???? If its the tps switch on the throttle body, can I buy one seperate or the whole damn throttle body? I can't seem to find the switch anywhere on the web.
Ok...Any ideas peeps? .
striker2005's Avatar
striker2005 striker2005 is offline
My Saabs: 2005 Aero Loaded
Default Answer
Get it to the Saab dealer garage. Sometimes you gotta bite the bullet and let them do it.
ctrlz ctrlz is offline
Location: Ocean City NJ, 03 Vector 2.0T 6spd, BSR Stg 1
From the WIS:
P2135
Throttle position sensor circuit; Plausibility fault between circuit 1 and 2
Symptom:
Fault indicator lamp
Cruise not working
limp home
Fault criteria:
Difference in voltage between throttle position sensors 1 and 2 is 4-8%, depending on position of throttle (4% for unactuated pedal, 8% for depressed pedal)
System reaction:
Correction of mass air flow/combustion for fuel calculation is blocked
Limited acceleration and idle function
Cruise control blocked
Secondary air switched off
WIS basically advises checking the wiring harnesses for breaks/shorts.
This is a bit of a weird one. I would remove the plastic engine shroud and see if anything got wet.
We have had some other TPS problem threads lately. I have described elsewhere (paraphrased the WIS, actually) how this works. Basically the combined output of TPS1 and TPS2 always sums to 5 V. This checksum is used by the ECM for fault detection in the TPS.
I can't find the TPS part number in the EPC. I'm not sure it's separate from the throttle body. The EPC implies that it is. It refers you to section 2-5500, which is charge air plumbing. Unfortunately the TPS is not shown there!! Maybe someone else can find this part #.
Old 21st September 2008
Thanks for the info.....Can someone point me to where the throttle body is located? I have the cover off and man I cannot find the bugger. The dealer route is not an option right now $$. So I need to see if I can get the tps switch located or replace the whole throttle body if that is the case. Seems to be a problem for our cars.
Found the throttle body.....Now trying to find out if there is two tps....One on the throttle body which I can see and one at the pedal...I am thinking so since the code came up as tps pedal switch fault.
Remove engine cover. As you face car note large charge air hose coming off right side of intercooler. Follow hose to intake manifold. It attaches to throttle body, which is bolted to intake.
To the right of my hand in this photo:
http://www.saabcentral.com/forums/at...achmentid=2207
BTW, I decided to start renaming these threads once the DTC (diagnostic trouble code) is retrieved. Hopefully that will make it easier to find things using the forum search function in the future.
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
