GS 3" DP (v.2) for Viggen - Noise gone - SaabCentral Forums
Old 15-09-08
Route246's Avatar
Route246 Route246 is offline
My Saabs: 01 Viggen 'vert.
Default GS 3" DP (v.2) for Viggen - Noise gone
I was fighting a banging noise during low-speed cornering and under-geared acceleration. Thought it was suspension related, but turned out that the DP was hitting the subframe. Loosened the connector, jammed a used exhaust hanger between the DP and the subframe, re-tightened. Pried the exhaust hanger out, and confirmed increased clearance and no more the "Ga-ga-ga-ga-ga" noise.
Now, the oval tailpipe is ****-eyed (argh!).
Need to find a happy equilibrium. Any tips for exhaust adjustments, anyone?
James | Route246 | SAAB Club of Seattle (SCS) on fb / CarDmain page
2001 B235R CV - KONI S&S, Rack Brace (GS), 6pt. Brace (GS), 22mm ARB (GS),
PU Bushings, BSR exh., 3" Race Cat, Intake & Pipe (GS), v.2 DP (GS), Strut Brace (GS),
SPEC Al Flywheel, Forge BV (GS), ETS FMIC (GS), 34R Red-top
Old 16-09-08
99HOT93's Avatar
99HOT93 99HOT93 is offline
My Saabs: 1999 Saab 93 SE HOT manual
I had a similar problem- my saabsport rattled heavily against the thin exhaust heat shielding surrounding it. Had to both bend back the heat shielding and adjust the amount the "slide together tubing" connection of the saabsport was pushed together. For some reason I've had difficulty pushing it together a whole lot.
I would try adjusting this part of the exhaust because it directly affects how far left or right the final tailpipe and tip hang. It's hard to do, but has helped somewhat.
**just noticed you have BSR catback not saabsport... I'm assuming your exhaust pieces hook up in a similar fashion
Mable: 1999 9-3, Stage 3
Lots of goodies...
Old 16-09-08
Route246's Avatar
Thanks for the input, HOT.
An interesting set of intertwined variables under the car... Fix the tailpipe alignment but lose the DP clearance, turn the pipe(s) and the DP is OK and the tailpipe turn the other way and the pipe hangs too low for hangers...
I'll eventually find a happy place for all parts involved. eventually...
Old 16-09-08
99HOT93's Avatar
I feel you pain Route. How does ur BSR sound anyway, havn't seen many guys with that one? I remember when I was torn between that and the saabsport.
Lots of goodies...
Old 16-09-08
Route246's Avatar
Originally Posted by 99HOT93
How does ur BSR sound anyway, ...
I've not had the pleasure of hearing what a Saabsport system sounds like, but even at WOT, the BSR sounds deep and "civilized" (know what I mean?). I've heard some exhausts that are much more raspy, and while I do have a certain affinity for that purposeful sound of a single muffler & cat-less exhaust, I don't like to draw too much attention, so I still have two silencers and one cat.
The 3" JT monster-of-an-exhaust that I had on my c900 was throaty at idle, and gurgly in a "dry" way under load. I was never able to confirm it first hand, but my tail-gating brother told me that he saw puffs of flame when the throttle was let off of (I ran a bit rich with an atmospheric BOV). Definitely lots of excitement in that car... I often miss her.
Now, I really enjoy the subdued exhaust tone of my 9-3. Maybe it's my age
