Can 16-inch and 15-inch wheels be swapped? (9-3 and 9-5) - SaabCentral Forums
Old 08-09-08
tedrussell tedrussell is offline
Default Can 16-inch and 15-inch wheels be swapped? (9-3 and 9-5)
My son has a 1999 9-3 with 15-inch wheels. I am about to sell a 2000 9-5 with 16-inch wheels. The 9-5 has good tires and my son needs new ones. I'm not expecting to get much for the 9-5 anyway. The tires can't be swapped but I would like to know if the wheels can. Are there any potential problems putting the 16-inch wheels on the 9-3? Or putting the 15-inch wheels on the 9-5?
Old 08-09-08
messiguy01 messiguy01 is offline
My Saabs: '00 Viggen 5dr BCB Stg1
Don't see why not. Been running these 9-5 wheels for a month. Little understeer, which I like, and there may be a little rubbing at full lock if you're running 60 series. Throw and go.
Old 08-09-08
Jeremy R.'s Avatar
Jeremy R. Jeremy R. is offline
My Saabs: 1997 900SE Talladega coupe
You may want to take the 9-3 to a dealer and have them set the speedometer and odometer calibration for 16" wheels afterward, but even if you don't, they shouldn't be off by much. 16" and even 17" wheels were both options on the 9-3, so the car's fine with them.
Old 08-09-08
Saaboheme's Avatar
Saaboheme Saaboheme is offline
My Saabs: 2008 9-3 SS 2.0 6Spd JZW Stage 1
Larger wheels get lower profile tires. The differences nearly net out for the outer circumference of the wheel/tire combo. The biggest difference is if the contact patch is more than 1/2 inch wider. This may require front end alignment to adjust toe-in, castor and camber (especially camber).
Old 09-09-08
Thanks for the answers. Messiguy, where does the rub occur?
Old 09-09-08
turbo4life turbo4life is offline
My Saabs: 1999 9-3
I have 17" on my 99 93, had speedo re-calibrated. No problems. Even have car lowered.
