| Saab 9-3 & NG900 Workshop Saab 9-3 & NG900 (1994 to 2002) Technical Forum |
I wrote to the forum a couple of weeks ago concerning the cel coming on intermittently. I then bought the Elmscan 5 USB diagnostic tool and - after a whole bunch of dramas installing it - identified the above fault codes.
P0705 comes up as a generic Transmission range sensor 'A' circuit. P1312 is ignition coil knock detection cyl 1 and 2 and the cause is quoted as wiring open circuit/short to positive, ignition coil assy, ECM. P1334 is as 1312, but cylinders 3 and 4. As the car seems to have no change in performance, and the cel and transmission warning light seem to be weather dependent, (they appear after it has been raining) I am guessing there are one or two connections that are occasionally making a bad contact. Can anybody help with their possible locations? I should have pointed out that I have a 2001 Aero convertible Last edited by stewartbaldwin; 03-09-08 at 04:04 PM. |
| Sponsored Links | ||
Advertisement | ||
From http://www.saabcentral.com/forums/sh...ad.php?t=92156 I get:
P0705 Transmission Range Sensor Circuit Malfunction (PRNDL Input) If the tranny is working fine, then that's baffling. It seems like a malfunction at the shifter input would cause some weirdness. The knocking codes could be a sign of a failing DIC, but I'm just guessing there. |
P0705
Gear selector position sensor, control module inputs faulty or absent. Shift-lock relay faulty, This is right from alldata, the shift lever switch is either out of adjustment not making the appropriate connections, or the shift lock relay is bad (doubt it) or the connector is dirty or shorted, As for the other codes they point directly to your DI Cassette. The knock sensors (2 Each) are in the DI cassette itself and when the DI cassette goes it will either 1-go right now or 2-suffer a slow painful death. So what I would do is 1. Get under the car and look for the connector to the shift switch and clean and inspect for chaffing and obvious defects and repair or replace and 2. replace the DI cassette with a new one and keep your old one as a last resort spare. |
Just saw a P0705 on a 01 the other day..my first. Checked with a couple of techs and they say theyve never seen this code be anything but a bad range/neutral safety switch. Changed the switch(its under the battery)code gone...all gouda.The others...make sure of "correct" plugs and gap.
@Darren- There was wierdness regarding P0705...CEL and tranny light came on, went into some kind of "limp mode". Seemed like it was stuck in 3rd?
Only US diesel?? 03 93 Cosmic Blue Also Black 06 93 Combi, White 89 900TCV Last edited by dzlsabe; 08-09-08 at 11:32 PM. Reason: Add |
Thank you all very much for the information. I read on another thread that my main dealer should have the equipment to test the DIC as a separate unit. I called them and explained the situation, and they immediately said the DIC was about to fail.They then asked me for the chassis number, checked this and said I could have a free DIC!. Apparently there was a recall and my car had never been done. They also said there was another item that had not been done and they would do this at the same time. Result! For anybody in the middle of England, The workshop reception at Holdcrofts in Stoke on Trent has always been extremely helpful. They also made all the right noises about bulkhead cracks.
When I take the car in this week, I will ask them about P0705 and the unit under the battery. Last edited by stewartbaldwin; 08-09-08 at 05:23 PM. |
| Sponsored Links | |
Advertisement | |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
