Simple steps to more power? - SaabCentral Forums
Go Back   SaabCentral Forums > Classic Saab 900, 1979-1993 & 94 Convertible > Classic Saab 900 Performance, Mods & Tuning
Classic Saab 900 Performance, Mods & Tuning Covers Tuning & Performance modifications for the Classic Saab 900
Old 28-07-03
gbsaab gbsaab is offline
Default Simple steps to more power?
So far I've got an upgraded apc, 3.0 fpr, K&N filter and messed with the f & p pots and I'm running about 3/4 into the red, which the car will hold for a few seconds, then drops to half red - are there other simple steps that I should be doing to be getting more power, outside of better injectors, fuel chips and stuff like that?
Old 28-07-03
Oil_Eater Oil_Eater is offline
My Saabs: 1991 SPG Berol Green
There is a trick you can do to the pressure retard capsule on the distributor.
You will have to search for it, because I don't have it bookmarked.
After that, you can upgrade your intercooler. Some use 9000 while others use Volvo intercoolers.
Old 29-07-03
tevid's Avatar
tevid tevid is offline
more gas wouldn't be bad, the engine knocks because there is more air than gas coming in, i'd say get some upgraded injectors
www.900aero.com has some good info on this
Old 30-07-03
Deans88SaabT16 Deans88SaabT16 is offline
A rising rate fuel pressure regulator should do the trick.
Old 01-08-03
Kirkpatrick Kirkpatrick is offline
find the hose that goes from the APC solenoidj to the wastegate, disconnect it and then plug it. Now go out for a spin and floor it, you should have much more power, until the overboost cutoff sends you throught the windshield
BTW-this suggestion was a joke and actually doing this can result in serious damage to A) Your engine B) Your Turbo C) Your tranny. Don't try it at home, or anywhere else for that matter.
-Sam
