MAP sensor?? - SaabCentral Forums
Old 30th July 2008
r14l21's Avatar
r14l21 r14l21 is offline
My Saabs: 2000 9-5 aero (old) 1999 9-3 JSP stage 4
Default MAP sensor??
my car is at the shop today, and the codes are calling for it to have a MAP sensor replaced, but the thnig is apparently a 99 9-3 doesnt have a map sensor for its engine.. and i know that my engine is a swapped one, but im just not sure what year it is from.. its a 2.3 liter, and the turbo and everythng is not stock, just the engine, if anyone could help that would be great!
Old 30th July 2008
Saabohème's Avatar
Saabohème Saabohème is offline
My Saabs: 2008 9-3 SS 2.0 6Spd JZW Stage 1
ALL Saab turbocharged engines have a MAP sensor. On the 9-3 and NG 900 it is mounted on the strut tower bar and has a vacuum hose connected to it along with a small wiring harness:
Old 30th July 2008
r14l21's Avatar
that is exactly what i thoguht. but the garage seems to think they are never wrong, and told me they called the saab parts dealer and they even told him that they dont have one for that car
Old 30th July 2008
r14l21's Avatar
do you know where i could get one from?
Old 30th July 2008
Saabohème's Avatar
Dude, I don't know what I was thinking. The T5 is a speed density system and thus has a MAP sensor, while T7 and later use an AMM (air mass meter). Sorry, I just wasn't paying attention to what cars you have and assumed you were T5.
Old 30th July 2008
soccerrplyr's Avatar
soccerrplyr soccerrplyr is offline
My Saabs: 1999 9-3vig clone 2000 9-3vig clone 19t
Garage
Find out if your car is a 2.0 or 2.3. Here's one for a 2.0 http://www.eeuroparts.com/Main/PartD...px?id=9132374A
Old 31st July 2008
r14l21's Avatar
the garage is trying to find the vin on the engine to figure out what year and swap it was.. im assuming its a 2.0, as they do not make 2.3 for 9-3 not including the viggen before the new models? please correct mme if im wrong, and it is a t5 engine sorry for the confusion..idk if this helps at all, but another thing i was going to have done was change the o2 sensors, but buying them from saab dealers is outrageous, just wondering if anyone knows where i can grab one for both banks for a little less money thanks!
Old 31st July 2008
Saabohème's Avatar
OK-if it is in fact a T5 (and you know this because T5 has no AMM in the low pressure intake tract) then it absolutely must have a MAP.
02 sensors can be had for cheap if you get the universal kind that you have to splice in. You cannot however order any yet because you don't know what motor you have yet.
In the very first post you stated you have a transplanted motor that is 2.3 liters. Now you state it is definitely T5. If both statements are true, then you may have 2.3 T5 from a 9000.
I think you would be well served to get stamping nos. off the block and head and see for sure what you have in there.
Old 31st July 2008
r14l21's Avatar
thank you for your information, im sorry about saying 2.3 before i must have been confused with my 9-5 aero lol. for some reason i thought this car had a 2.3 swap but i know for a fact its not a 9000 engine so we can cancel that, and i also know its from another model 9-3 so that should slim it down a bit. I thought/knew all along that they had a map sensor, but these people keep trying to tell me it doesnt.so i will figure out exactly what year, becxause i assume a 2000 egnine would be a little different from the 99?
also, i have been told the universal o2s arent great in how they fit many cars so sometimes it can have not the most accurate of readings?
thanks
Old 1st August 2008
r14l21's Avatar
anyone else have any helpful info? thanks!
Old 1st August 2008
Shirozina Shirozina is offline
My Saabs: 2002 9-3 aero 5spd 3dr
99 would be T5 - it's highly unlikely that the car has a T7 engine management transplant as the amount of work involved is substantial. Universal O2 sensors will work but it must be a 4 wire as the T5 earths the sensor through the ECU and check the heater resistance is the same or it will throw a CEL. The part number for a T5 map sensor is 9132374. Dealer prices are likely to be outrageous so try to get a used part from a breakers.
2002 9-3 Aero 3dr 5spd
Old 1st August 2008
Saabohème's Avatar
This is manifestly true. Conversion to T7 is an extremely painful electrical nightmare. As for the MAP sensor itself, soccerplyr's link to eeuroparts shows a new ScanTech sensor for a mere $85.00. Not too bad. The OEM Bosch is $160.00 on SaabSite.
Old 3rd December 2015
kielbasa kielbasa is offline
My Saabs: 9-3 2.0T Convertible, Black 170A, MY2000
Has anyone cleared map sensor ?
I just took it off and I'm wondering if I should pry this plastic box open using a screwdriver just like that? ?I'm just afraid not to damage anything here.
EdT EdT is offline
My Saabs: 1997 900S Coupé, 2003 9-5 Linear Combi
I would think the MAP sensor has a sealed chamber and some form of transducer. That means that opening it up is a bad idea. And there's nothing to clean, really.
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
