window goes up, then down halfway - SaabCentral Forums
Old 29-07-08
bartholomew bartholomew is offline
My Saabs: '03_9-3_SS_ARC_BLK tranny blown and sold
Default window goes up, then down halfway
so about two weeks ago, my driver side rear window would go up all the way, then instantly go back down about halfway. i can get it to close, but all manually, as in i have to flick the switch the other way to get it to stop going up. Then in the past couple days, the driver's side front has starting doing the same thing. this happens everytime. I think this may something to do with pinch protection, but i dunno what. ive tried everything i can think of, including cleaning out the rubber around the window. has anyone had this happen ot them before?
Old 29-07-08
JonV JonV is offline
Saabista
My Saabs: 03 Vector
You did reset the Pinch Protection?
Old 29-07-08
how do i reset pinch protection?
Old 29-07-08
Molitoth's Avatar
Molitoth Molitoth is offline
My Saabs: '04 9-3 Aero BSR-3 /// '78 99 Turbo
Resetting the battery then opening/closing your windows should reset them.
Molitoth's Garage
http://www.cardomain.com/ride/2978715
Old 29-07-08
Saabista
My Saabs: 03 Vector
You do not need to disconnect the battery and that DOES NOT reset the PP......Do this:
With Ignition on, raise and lower the window fully twice holding the switch in the full down or up position, on the second closing hold the switch up until you here a chime. Do this for each window that has to be reset.
Disconnecting the battery is a sure way to "Un set" all the Pinch Protection and a few other things.
Old 29-07-08
i fi reset the battery, willl i need to reset the radio? will it even work, or will i need to go to the edealer and get a code?
Old 29-07-08
Saabista
My Saabs: 03 Vector
There is no code you have to re-set on an SS for the radio....if you disconnect the battery you will have to reset all of the windows.
Old 29-07-08
Chiliman Chiliman is offline
My Saabs: 05 Saab 9-3 AERO, 01 Viggen
That happened to my car. What the dealer did was hold the button windowlocking button while holding up the window. no need to do anything with the battery.
Old 29-07-08
Saabista
My Saabs: 03 Vector
Just follow the directions in post 5 or check P.101 in your manual, there the same directions.
Old 04-08-08
jgarrett83 jgarrett83 is offline
New Member
My Saabs: '04 9-3 Arc 2.0T
My driver side window was doing this as well. When I brought it in for service at the dealership, they said it had to be reset and would cost $90! I'm so glad I passed.
Old 04-08-08
Highnndry Highnndry is offline
My Saabs: SAAB 04 9-3 ARC
I must be doing something wrong. Help please....
First, The locking button the one behind all the window button with an "X" mark. Should the light be "on" on this button?
This is what I did,
1. I turned off the car and then
2. turned the key to the on position.
3. All the lights came on without the engine revving.
4. I hold the locking button with one hand and closed the window with another.
5. Still holding the locking button, I pulled down the window all the way.
6. Still holding the window locking button, I closed the window but it came back down.
7. Waited to hear any beep but nada...
Which step am I missing? Should let the locking button go once the window closes after step 4?
@JonV, when you say ignition on, do you mean that the car is running? As in the engine is revving?
Old 04-08-08
Saabista
My Saabs: 03 Vector
Just have the Key in the On position, no need to have the engine running.
You don't have to hold any buttons except the one on the window you are setting, Raise and lower the window twice while holding the switch in the appropriate direction. On the second closing just hold the switch up till you here the Chime.
Old 04-08-08
aerojon's Avatar
aerojon aerojon is offline
Smile
This is what I did,
Sit in car with doors closed and ignition on(no need to start engine)then
down,up,down,up & hold about 3-5 seconds later should hear the bleep
this needs to be done on all windows...
ICM3 13sp system now with bluetooth audio streaming..
Old 04-08-08
Saabista
My Saabs: 03 Vector
Would anyone else like to explain it for the fourth time?
or .....Just follow the directions in post 5 or check P.101 in your manual, there the same directions.
Old 05-08-08
I guess my Saab needs the soft gentle touch of Jonv cause I can't get this window reset. This is what I did now:
1. Key is in the "on" position, engine not running
2. Hold the window button until the window rolls all the way down.
3. Hold the window button up until the window rolls all the way up, well the window rolls up and then rolls down quarter way.
4. Hold the window button until window rolls down.
5. Hold the window button until it rolls up, well it rolls up and then rolls down quarter way. I still kept on holding the button up until I hear any beep but nada.
6. I tried for the third time same thing but no go.....
Every time I reset my window by the dealer, within a week another one goes haywire..... really drives me nutz
Old 05-08-08
Saabista
My Saabs: 03 Vector
Sounds like this is a hardware problem, your doing it right. I'd insist they replace the regulator or the whole assembly, Warranty I hope or it will be a few hundred. If you've been paying for the failed resets I'd demand restitution.
Old 05-08-08
Vector-SS's Avatar
Vector-SS Vector-SS is offline
My Saabs: 2006 9-3 Aero Vtuner Stage 0 Rev 2.0
Garage
Had this issue come and go twice and solved it by simply disconnecting the battery. Not only do you get your windows back, but a new beast
Old 05-08-08
Saabista
My Saabs: 03 Vector
If I am re-reading right, it's not always the same Window? So that eliminates a sensor/motor or regulator problem in one specific door. Sounding like a software glitch of some sort. The full re-boot might work, but I bet that's what the dealers been doing to solve it for a week or so at a time.
Old 05-08-08
Ambisaab's Avatar
Ambisaab Ambisaab is offline
My Saabs: 03 9-3 Aero BSR Stage 1 & JR Filter
Disconnect the battery or remove fuse 5 from the fuse panel on the (as you sit in the car) left side then follow the reset instructions as in the earlier post. It's probably just a glitch...thats part of what makes these cars so interesting My 03 does it now and again for no obvious reason! There is a bulletin about this and it says it's something to do with the trim/window guide alignment being messed up..hey ho !
I'll shut up now !
http://www.cardomain.com/ride/3053734
Old 06-08-08
coolcut's Avatar
coolcut coolcut is offline
My Saabs: '04 9³ Arc
Does this need to be done on the sunroof too?
