water well behind driver is filling in heavy rain storms. It only happens when the car is level. I went to the dealership last night because i had the usual gap above the driver side rear passenger door. He fixed the gap and explained to me that there is a rubber seal inside the door that is leaking. Does anybody have ANY idea on how to fix this? I am going insane. All door seals are still very soft and buttery smooth.
This is where the water pools up and flows over ![]() Ran some tests by just spraying water on the window ![]() Ran some tests with spraying on the gap and holding a towell to stop water from running down window and off to side to be sure water is entering in here ![]() Tried sealing off Rubber sound barrier with duct tape to stop water from entering the door ![]() Didn't work ![]() Water inside the sound barrier ![]() ![]() top of door ![]() How is water supposed to be properly diverted away from that area? It didn't matter if i sprayed the top of the door or the window, water always came in. I did fill that gap on the top of the door with caulk and it did work for a bit. Unfortunatly that black strip keeps on moving, and it created a gap again with the caulk and i think that is how the leak started. You can see how far it has moved since yesterday. Does anybody know how to fix this friggin problem? Last edited by robhurlburt; 24-07-08 at 08:53 PM. |
| Sponsored Links | ||
Advertisement | ||
You might want to look into getting new rubber lineings for your door. It seems that because you have that little rip, it looks like its alowing water to get under the window.
its not a rip though....there are 2 seperate pieces. the one towards the front of the car moves on me
unless you are talking about a different piece than the plastic pieces above the door |
Well if its two pieces of rubber, then they could have been pulled away from each other, due to opening, closing, grabbing, etc. So you could try pushing those together. I honestly dont think you will be able to do that with your hands, but i dont really know what else you could use.
Just pump some silacone in the gap
Miles to Date: 178,000 ish No major problems, Replaced My 1st set of breaks @ 130,000, they lasted for ever. |
I have a 2005 with the same problem. After the third time taking it into the shop, they replaced some kind of seal in the rear door and it stopped the leak. I also have the gap, which is still there, in the trim. This didn't seem to be the cause of the problem. There are some other threads here that talk about this, but give a myriad of solutions.
Good Luck! |
going to the dealer on tues with the door panel off. hopefully he can point me in the right direction. still looking for more options though!
The Door Gasket is disintegrating, a bunch of us have had this issue.
which gasket? mine still seem to be buttery smooth. No cracks or anything
well we had another storm today, sure enoug it go f*ckin soaked. I am going to try and put plastic in between where the door and rubber shield is, so the water doesn't even have a chance to get to the rubber part and leak over
| Sponsored Links | |
Advertisement | |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
