right speaker channel - SaabCentral Forums
Old 10-09-01
rizzo1001 rizzo1001 is offline
I just noticed today that the right channel is not working correctly. Sound is comming from the right side, but it is barely audible. Anyone?
Old 10-09-01
Simon's Avatar
Simon Simon is offline
Administrator
My Saabs: I've had a few...
Ask a stupid question, but it's got nothing to do with the balance or fader has it!?
Simon.
Old 10-09-01
DanF.'s Avatar
DanF. DanF. is offline
My Saabs: 1997 9000 Aero 5-speed
Check the connections behind the head unit. Make sure that every thing is tight.
Good luck.
*SAABCentral NEW ENGLAND CREW Member 008* (now in NC)
T5Suite2.0 Stage 3+, Full DIY 3" exhaust w/Magnaflow, Spec stage 2+ clutch, "Custom" airbox mod, Forge BPV, DIY strut brace, Poly bushings, various powder-coated goodies
Old 10-09-01
Carl Carl is offline
The speaker connectors are fairly straight forward, at the speakers and at the headunit. But as Paul says, check your fader controls. Don't always think the worst, we have all done it in the past, haven't we? anyone?
Saab 900 Carlsson 16v Turbo
Old 11-09-01
Yeah, its not the fader controls, and everything seems to be tight behind the head unit, any thing I should be looking for specificly, the weird thing is that they come in, but very softly, maybe a misfunction in the head unit of sorts... Its not the speakers, because I just put new ones in the otherday.
Old 11-09-01
erik's Avatar
erik erik is offline
My Saabs: MY01 9-5 Aero Estate Auto
Another possibility could be that in certain radios, mainly older ones, the inbuilt amplifier has fuses to regulate power output. This was so that the radios which were considered then to be powerful didn't blow the lesser speakers. Try opening the headunit and look for the amplifier. Usualy found next to the heatsink(long or fat piece of finned metal. Look closely at the circuitry around it, there maybe two or four small glass radio fuses(usually 2A if you have to replace them). If not the headunit may have simply blown the right channel amplifier. The reason why i think it could be fuses as the sound doesn't necessarily go away but seems very quiet, distant, almost like you are listening to a LW radio broadcast. Best of Luck!
Ex 900 Carlsson owner (booHoo!)
Now - MY01 9-5 Aero Estate Auto, Cosmic Blue. Loads of Gadgets and Fast
Old 11-09-01
sounds very plausible, im going to go check it out now. thanks.
edit, I took a look and cant find any glass tubes, not suprisingly though, its the 88 clarian unit, maybe the right channel is gone, oh well...
matt
<font size=-1>[ This Message was edited by: rizzo1001 on Sep 11, 2001 9:54pm ]</font>
