| Saab 9-5 Workshop Saab 9-5 Workshop (1997 to 2010) Technical Forum |
So my ACC just threw up a code finally after not properly working for quite a little time now.. 1____19 came up and after quite a bit of searching, I found out there are only two threads on it that gave me a little help but not much. I'm having trouble finding the part that I need to replace. Anyone?
| Sponsored Links | ||
Advertisement | ||
Bump. This is probably the hardest part to find ever...
Confused....
So you are looking for a circulation pump? According to this website: http://www.saab9-5.com/faq_acc.htm that's where your problem is... I'll look for a part nuimber when I get to my EPC.... Then you should be able to order from the internet.... |
Well... time to replace that and my coolant bypass valve... at the same time.
My car throws the code 19 nearly every time, and I don't even have a recirc pump on my 4-cylinder!!!
If you have reason to believe your pump is bad, then change it. But it may also simply be a weirdness in the ACC software - like mine. |
| Sponsored Links | |
Advertisement | |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
