How many quarts of oil does the 2.0T take and - SaabCentral Forums
Closed Thread
Old 16th July 2003
finklejag's Avatar
finklejag finklejag is offline
Default How many quarts of oil does the 2.0T take and
Does the manual say to use 0W-30 :-??
I been using Mobil 1 0W-40 in my last four 1.8T's with no problems. My cars never burned one ounce of oil.
I always read that 40W oil is the best for turbo cars.
I know for a fact that Mobil 1 0W-30 does not meet European ACEA A3
Only Mobil 1 0W-40 and 15W-50 do.
The Castrol we get in the states suck. I think Autozone is stocking the new 0W-30 Syntec from Germany. It does meet ACEA A3.
I like Kendall but it is so hard to find.
Quick reply to this message
Old 16th July 2003
saabvec's Avatar
saabvec saabvec is offline
Just did my oil change last week and mine took 5 3/4 q.
Old 16th July 2003
finklejag's Avatar
Wow 6 quarts for a 4 banger
What weight oil did you use :-??
Old 16th July 2003
deniss's Avatar
deniss deniss is offline
My Saabs: '08 9-3 Combi 2.0T 6-sp
always used 10w-30 in my turbo car (not saab) - that's what mechanics would recommend. one mechanic in california (who was really good) advised us to switch to 10w-40, but he did say that this type of oil isn't good for cold winters. maybe i misunderstood something there... any ideas?
Old 16th July 2003
saabvec's Avatar
The recommendaed - 0W-30
Old 17th July 2003
Mickey Mickey is offline
I am trying to do a conversion from Quarts to Litres.
How many quarts make a US gallon?
Old 17th July 2003
finklejag's Avatar
4 Quarts makes a gallon
1 liter makes 1.0567 liquid quarts
1 liter makes .90081 dry quarts
Old 17th July 2003
finklejag's Avatar
808 just posted this
http://www.genuinesaab.com/psi/03oil-service.htm
It looks like Saab has to use full synthetic on the 9-3 SS.
They can use semi-synthetic on the 9-3/convertible and 9-5.
I will keep using Mobil 1 0W-40. I will bring in 6 quarts for them to use.
Old 17th July 2003
Thanks Finklejag.
That is A LOT of oil. About 6 litres! Whew!!
Old 17th July 2003
TwoSwedes TwoSwedes is offline
per the manual, 6 quarts of Mobil 1 0-30. Mine took exactly 6 qts.
ACEA B3 was developed to reduce emissions, as one aspect. However, the ECOTech was designed to be an emissions friendly motor; as such it does not have an EGR which the ACEA B3 standard reflects for other new engines that do.
Old 17th July 2003
Cosmicflash Cosmicflash is offline
My Saabs: '09 9-3 SS Aero XWD
I didn't know it was for emissions? The "Shear Index" of an ACEA A3 oil is the distinguishing factor between lower rated oils which allows a longer change interval I believe. Perhaps there are other factors I wasn't aware of. BTW, the "B" rating you refer to vs. the "A" rating is for diesels, "A" is for gasoline vehicles.
Also a 30W is very difficult if not impossible to get an ACEA A3 rating so I doubt the Saab 0W 30 has it.
Old 1st June 2010
f2racer f2racer is offline
From the manual for a 2006:
Oil capacity, including filter (oil change)
Petrol engine, 4-cyl. ________________ 6.3 qts. (6.0 l)
Petrol engine, V6 __________________ 6.0 qts. (5.7 l)
Old 1st June 2010
volcomstone2262's Avatar
volcomstone2262 volcomstone2262 is offline
My Saabs: 06' 2.0T
umm ok..
Old 1st June 2010
Diggs's Avatar
Diggs Diggs is online now
My Saabs: 2003 9³SS Linear
Question
Why are you dragging up 7 year old posts?
The answer is almost always....Tech2
Closed Thread
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
