temp sensor? engine coolant thermostat? or two different issues.. - SaabCentral Forums
Old 16th June 2008
blinktude's Avatar
blinktude blinktude is offline
My Saabs: '03 9-5 Aero, '02 Trailblazer
Default temp sensor? engine coolant thermostat? or two different issues..
so past few days, I get fill coolant message on the SID and my temp gauge would often go down to blue cold or stay at 7-8 clock position.
I check coolant and there was plenty. The ring inside the coolant tank moved fine when I poked it. Are they two different problems or are they sensor issue?
Old 16th June 2008
Kermit's Avatar
Kermit Kermit is offline
Saabista
My Saabs: 04 9-5 Vector 2.2Tid
I'd start with the thermostat and see if that cures the problem. Dropping temp gauge is usually stat related, it should be at 9 o'clock when fully warmed up so the stat may be stuck open.
Old 16th June 2008
blinktude's Avatar
thanks for the reply kermit
driving to work today and CEL poped up. stopped at autozone to get codes read and it poped out two.
P0116 and P0725.
Looks like P0116 is the engine coolant temp sensor
http://www.saabcentral.com/forums/sh...ighlight=p0116
would that throw fill coolant message on the SID?
Old 16th June 2008
gghh gghh is offline
My Saabs: BMW 530D Touring xDrive
No Low Coolant message with P0116. Change Thermostat and Sensor and check the heater bypass valve.
Old 20th June 2008
blinktude's Avatar
what is heater bypass valve and what should I look for?
Old 20th June 2008
Al's Red Wagon's Avatar
Al's Red Wagon Al's Red Wagon is offline
My Saabs: 1999, Cayenne Red 9-5, 2.3 Wagon
This may help.... http://www.fixmysaab.com/9-5_repair/...ps=2&nointro=1
Old 22nd June 2008
blinktude's Avatar
turns out my coolant level was below the min line.
I added some water in there and now the message doesn't show up anymore
Old 22nd June 2008
planosaab's Avatar
planosaab planosaab is offline
My Saabs: 99 9-5 TD04 270hk::2000 Viggen 5-Door
Default agreed
still check your coolant bypass valve its black has a round disc top with 3 hoses coming off its mounted on the firewall drivers side between the brake res and the manifold its a b-i-t-c-h to really get a good look at but I just phsyically do a good finger wipe around the whole thing to check for coolant, they are prone to leak and easy to replace but because of where it sits the coolant never visibly makes it to the ground so it is very hard to diagnose without the knowledge of the problem with them....I got the low coolant display on my sid 6 or 7 times before I figured it out with the help of this board too of course lol...thanks everyone.
I love your avatar classic game ski was....hehehe
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
