Hi all,
I'm experiencing odd readings from my coolant temp sensor - the needle will bounce up or down, occasionally reading max temp. When I turn my headlights on, hit a window switch, put on my turn signal, WOT acceleration, anything power-related with the car induces this. If the car just idles or cruises the reading is steady. I suspect a grounding issue, but IIRC the coolant temp sensor wires go back into the loom so I'm not sure where to look. Also could this be a bad sending unit? Not my first conclusion but I might have a spare to swap in. Any help or ideas you all could contribute would help greatly!
*1988 BMW M3* - Current project *1987 Airflow vert project thread* - 400bhp, Eurotuner Magazine Feature Car - Now on T5 *1987 SPG project thread* - Sold *1999 Lightning Blue 9³ Viggen* - Sold |
| Sponsored Links | ||
Advertisement | ||
If you have a spare, swap the sensor. Iirc it sends a variable ground to the guage ie. one wire.
I have had good results by..........
tightening the connectors on the back of the instrument cluster and applying a coating of solder to the ribbon. It has been mentioned before that the ribbon will and it does, melt very quickly. Being a electronic technician, I had some flux, low temp solder and a temp controlled station to use........ BEWARE, IF YOU ATTEMPT THIS, YOU ONLY GET ONE GO AT IT! If you go to far, you'll be needing a new cluster
------------ ODE to the N\A "I have not TURBINE to compress my buttocks, O lord, Pity will be thine when thoust can crap on with boost. We of the 'N\A - N\A' knowst nil of the pulling glory, Yea, to post, thy blight the day of those who pressurise their pipes, Alas, suck be mine that my chariot breathes, Strike me down for mine is an unworthy existance" |
Thanks guys, turned out to be bad grounds as I thought. Tightened things up and voila, perfect instruments!
| Sponsored Links | |
Advertisement | |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
