front brake pads changing... - SaabCentral Forums
Old 17-05-08
turbobedaine turbobedaine is offline
My Saabs: 9-3 ss 2003, Ng900s
Default front brake pads changing...
That sound stupid but how do we remove the front galliper to change brake pads?
I see 2 male e20 torx bolt,and 2 females torx,,,,,,,,,,,,,,,
wich ones i removed
thank
Old 17-05-08
Our1stSaab Our1stSaab is offline
My Saabs: 04 9-3
wich ones i removed
thank
I too was going to attempt to do my brakes today but I don't have the E20. I think the E20 removes the back bracket and the female ones are for the front part of the pad bracket so probably the E20. I have an set of E bits coming from amazon.
Old 17-05-08
robhurlburt's Avatar
robhurlburt robhurlburt is offline
My Saabs: 2003 9-3t (OOW)
i can't be positive because of the brief description, BUT:
i believe the E20 is the caliper carrier bolt. This holds the brake piston to the car, and needs to be removed to change the rotor.
If you are ONLY changing the pads, YOU DO NOT NEED TO REMOVE THIS!
PM me if you need more help, i would be more than happy
Old 18-05-08
so i guess i should remove the 2 females torx bolts on the galiper........
Anywone know the size of those bolts?
thanks
Old 18-05-08
crash808 crash808 is offline
My Saabs: 2005 9-3 Linear
if you're just replacing the pads and not the rotors, then you only need to remove the guide pins. they're the torx bolts with the little plastic caps on them. it's been a little while since i've changed mine, but i think they're t18.
http://www.mngtravel.net
Old 18-05-08
my guide pins were allen heads, size 7 or so.
same with my buddies MY04
Old 18-05-08
Ok the 2 little plastic caps have a torx bolt under them......i didnt notice...........
thanks a lot
Old 18-05-08
My Saabs: 04 9-3
Oops I forgot thesaabsite had a write up on the procedure. I finnaly found it and did realize that I'm just doing the pads now here is the linky:
hxxp://thesaabsite.com/93/93frontpadreplacement.htm
replace xx with tt to get there I can't remember if the rules on the site allows outside links.
cheers
Old 18-05-08
hmmm. mine were definitely torx, and i checked my torx set and they were either t30 or t40, which is about a 7mm allen size.
Old 18-05-08
My Saabs: 04 9-3
I just finished pads on all four. Thank you Autozone for the tool rental to get back calipers backed off.
I've noticed my brakes feel softer now, but no more grinding. I bleed all for wheels and the pedal is stiff but when the car is off but when I drive it the pedal wants to go to the floor when the car is sitting still. The brakes seem to work fine though
This is my wife's car so I didn't notice if this is new but is this normal??
Old 19-05-08
JBob's Avatar
JBob JBob is offline
My Saabs: 2003 9-3SS 2.0t Vector, Steel Grey (OOW)
Post
No they aren't. A 7mm allen will fit, but it's not the right one.
They are definately T40 torx. Try it!
