| Saab 9-3 & NG900 Workshop Saab 9-3 & NG900 (1994 to 2002) Technical Forum |
Almost finished with my 9-3's audio install. So far I've replaced the head unit, front speakers and door speakers. I made my own adapter for the DIN plug and it works well. Sounds way better than before but needs a few tweaks.
First off the dash speakers are getting too much bass. I noticed that the factory dash speakers are very stiff which probably dampens low frequencies, but the Kappas i put in are quite sensitive. My head unit dosent have a high-pass filter (just about the only thing it dosent have) so I may just install simple bass blockers to cure that. The other issue is that the door speakers arent loud enough. I put in CDT Audio 6.5" woofers (they're gorgeous) but they're apparently a little thirstier than the factory drivers. They sound clean (dont sound like the amp is under-powering them) but what I essentially need to do is turn the gain up. I'm not sure if the factory amp has a gain control on the outside, but I think it's very likely that it has one on the inside. Most amps (aftermarket too) have adjustment pots on the PCB. Has anyone ever seen inside one of these amps? I'd rather stay with the factory amp as it makes life simpler. It should definitely be powerful enough for the job. If all else fails I may try to get a 4 channel amp small enough to fit in the factory location.
'94 Mazda Miata '96 BMW 328i |
| Sponsored Links | ||
Advertisement | ||
There are gain controls on the factory amp. If you take it out, you'll see three or four holes on the backside of it that let you stick a screwdriver in and turn the pots inside. Two are for gain, and the crossover is also slightly adjustable. Since they're not labeled outside, you'll probably want to take the bottom off to see which one's which. The circuit board is labeled, at least.
YES YES YES!! THANK YOU! That makes this 10x easier (and cheaper).
i find it odd that you went with CDT speakers, a new head unit - but not a new amp. i glanced around the website, and the 6.5 components seem to like around 150 WRMS... i'm not sure that the factory amp can hit this (or even close), and even if it can, if it will sound good doing so. i think you would probably find a decent aftermarket amp (100x2 or more clean watts, or 75x4) would really open up the sound. just my opinion.
I think the stock amp is 40 watts??
It's 35 watts per channel RMS, which is actually just fine for driving a pair of 6.5" woofers. Wattage ratings on speakers mean nothing, and the stock amp can easily bottom out some woofers on heavy bass tracks. I tested out quite a few before settling on the ones I have. Besides, there are maybe one or two aftermarket amps that can fit in that small space.
| Sponsored Links | |
Advertisement | |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
